GT780R Wifi Card Replacement
allknowingeye
STAFF SERGEANT
I am thinking of upgrading the Wifi card in my GT780R. It's a basic N that can't seem to do more than 70mbs with a double bonded channel. I would like to be put in a 3X card. Does anyone know if this is possible. I didn't see any documentation about where the wifi card is located and if it would be accessible for replacement.
yes you can replace the wifi card.
Its a 2 wire mini card. I myself put in a intel 6230
It is located under the touch panel by the power button.
there is a guide on how to do this on internet somewhere, by gentech pc I think.
Looking right now I am looking at doing the same thing.  Did you have a guide or anything on disassembly?  Did you replace the antenna or just the card?
