GTX 1080 not recognized by z890 Mobo
Hi All,
So, I am trying to put GTX1080 to my PC:
  • CPU: Intel Core Ultra 7 265K
  • MOBO: MSI Pro z890-s WIFI
  • GPU: ASUS Strix GTX1080 A8G Gaming
It doesn't work. Motherboard doesn't recognize the card at all. It behavies as if the slot was empty. The GPU is fine (tested on other PC).
What I learnt so far:
  • Apparently Pascal is not compatible with GOP,
  • My motherboard doesn't have CSM / Legacy BIOS.
What I've done so far (I have access to other X99 platform):
  • - Update BIOS of GPU (86.04.60.00.AS03)
  • - Update DP driver on GPU (https://www.nvidia.com/en-us/drivers/nv-uefi-update-x64/) - apparently this should have added GOP to GPU...
  • - Tried every PCI-E slot,
  • - Turned of SecureBoot,
  • - Update BIOS of Motherboard (1.AE0)
  • - Changing PCI-E manually to PCI-E Gen 3 / 2
  • - Disabling FastBoot
  • - Disabling Resizable bar
I'm out of ideas and so is Gemini. Any help would be appreciated...
The GTX 1080 GPU is UEFI-compatible and should work on that motherboard
Please remove the CPU and inspect the CPU socket for damage.
Do you have another GPU you could test with
There is a possibility the Motherboard is faulty, or the PSU is
What PSU are you using
Did you do that in another (working) system and you got the confirmation of operation successful?
I only had gtx950 and to my surprise, it works with z890.
That points to a compatibility issue with GTX 1080.
MSI responded that it's basically not their problem and that they cannot guarantee the card would work.
Have you contacted ASUS as well?
So, I do have a small update.
I made a mistake when assesing if my GTX1080 supports UEFI based on GPU-Z. I saw a ticked checkbox what I thought mean "Yes". Only now that I installed GTX950 and opened GPU-Z, I see that the checkbox apart from having a "tick" inside, also needs to be highlighted in blue.... so, my GTX1080 doesn't support UEFI apparently which is super odd.
- Nvidia DP driver update said installation was succesfull.
- I also contacted ASUS today.
I will try flash the BIOS again, maybe to older BIOS instead of newest and check if UEFI shows in GPU-Z....any idea why my card might not have UEFI support? I thought GTX1080 had it as standard... even older GTX950 has it.... I bought the card used, so don't know its history...
