GTX 1650, Monitor 27 inch, 4K possible?
bubulle78154d02da
Hello
I have a graphic card MSI Geforce GTX 1650. Can i use with it a 27 inch monitor and 4K ?
Thank you for your help
Herve
badboy2k
that card type has:
HDMI 2.0b = (3840x2160) 4K UHD at 60 Hz
Display Port 1.4a = (3840x2160) 4K UHD at 120 Hz
darkhawk
What are you trying to use it at 4k for? Just for the desktop/windows? Or were you thinking of doing games at 4k?
If it's just the desktop/browsing, then yeah, it'll probably work just fine.
If you're hoping it'll run games at 4k with that card.....I wouldn't count on it.
bubulle78154d02da
Badboy and Darkhawk, thank you very much for your help. It's not to play in 4K, just for pleasure to have a better definition on a 27 inch monitor.
So, i can use it for a 4k monitor 27 inch. Thanks again.
