Guide: Fixing bent pins in the CPU socket
Pro
This is an overview of what it takes to fix bent pins in a modern CPU socket (or at least attempt to fix them).
One of the most common things to go wrong with a motherboard is to have some bent pins in the CPU socket. After all, modern sockets are LGA sockets, usually with around 1000-2000 tiny contact pins, which are very prone to bending with even the slightest mistake during CPU installation.
So first, a note about correct CPU installation, to prevent any pins from being bent to begin with.
There's two generally accepted methods of installing the CPU in the socket: The common one is to use one hand, thumb on left side (or right side if you're left-handed), index finger on the other, gripping slightly more from above instead of underneath (so there's no risk of touching the pins), gently lowering it flat into the socket. All this with the protective plastic cover still being on top of the opened socket mechanism, because it's supposed to be left on, it snaps off by itself once the socket mechanism is closed.
Sort of like this:
The other method is shown here in this video.
It's easy to accidentally bend pins during the CPU installation if the CPU is not carefully lowered flat into the socket (or anchored on one side), or making some other mistake like taking off the protective plastic cap before installing the CPU. Installing the CPU into an LGA socket with its very sensitive pins is the most critical moment of building any system, akin to open-heart surgery. Touching the pins with one corner of the CPU first, or the CPU "bouncing" on some pins, can already bend pins in that area.
CPU installation FAQ by ASUS: [Motherboard]How to install CPU on Motherboard? | Official Support | ASUS Global
The protective plastic cap/cover, both on Intel and AM5, is specifically designed to be pushed outwards and pop off once the lever is closed when the CPU is installed.
Taking the socket cover off manually before the CPU installation is risky, because the socket pins underneath are exposed.
With even just one bent pin, let alone a couple, it can cause any number of symptoms, including weird, seemingly inexplicable ones. But especially once there is something quite severe, like an entire RAM channel not recognizing any modules, the socket pins have to be checked. The most common explanation would be that there are bent pins in there.
There are pinmaps or pinouts available for various sockets, such as Socket AM5. A lot of pins on the right side of the socket go via PCB traces (data lines on the motherboard) to the contacts in the RAM slots. A lot of pins on the bottom area of the socket go to the first PCIe slot and first M.2 slot, which are always directly connected to the CPU. So with some bent pins, depending on the affected ones, the PC can still boot up ok, but there can still be various problems. With a bent pin in a more critical position, the PC might not boot up at all anymore.
Identifying bent pins:
Not as easy as it sounds. I recommend taking macro photos with a smartphone or a camera, and if they have a good macro mode / good magnification, that can help a lot. Alternatively, using a magnifying glass, and trying to look from a low angle, with a strong light coming from different directions. If there is some break in the pattern of the pins, some different reflection, then it's a hint that some pins might be bent.
Here is an example of bent pins in the socket, the few pins that look different from all the others (click to enlarge):
The best thing is to upload some photos to an image hoster (because of file size) and link them here, even in this thread, for us all to take a look at it. Sometimes bent pins are so difficult to spot that I even missed one or two in the past, and I've looked at a lot of such photos. So you always want as many pairs of eyes inspecting it as possible. Reason being, with any kind of weird trouble, should there really be bent socket pins, it's almost guaranteed they will be responsible for the trouble, and troubleshooting other things would be a waste of time.
Fixing bent pins:
This has to be done while looking through a magnifying glass with a strong magnification and plenty of light, ideally one that is on a goose neck and has an integrated ring light. A 5x magnification is not enough in my experience, it would have to be a 10x magnification at least. Ideal would be a special microscope, but a strong magnifying glass is the next best thing.
Attempting to fix bent pins is done by carefully nudging (not pulling) the pins back into position. The important part is the golden tip of the pins, they have to form a grid. The pin can look a bit crooked later, as long as the tip of the pin is roughly within the grid position again. Now, grabbing them and forcing them back into position, that should be left to experienced hands only, it would almost have to be done in one motion and very gently, because a pin can easily break off. Gentle prodding/pushing or "massaging" them in the right direction is usually the best idea. No bending back and forth though, or only once or twice, because metal fatigue could lead to them breaking off.
Bends where the pin stays mostly straight, and is just bent to the left or right / up or down, those are generally easier to correct and carry less risk. The risk increases if the pin has a complex bend or is bent over backwards onto itself, because the actions required to unbend it might lead to it breaking.
As for the tool to "massage" the pins, it obviously has to have a very small tip, for example a small precision screwdriver. I've also seen a report about using a Q-tip, where you cut the cotton ends off, put the little hollow tube over the bent pin, and "guide" it to the correct position like that, that seems like a promising and gentle enough approach. But I cut a Q-tip in half and they're not made of hollow plastic anymore, it's now some hard paper-based material. Plus, it's still rather big, the pins are absolutely tiny.
Other tools can also work, like tweezers with small enough tips. Whatever is small enough to manipulate a single socket pin and that can push it in the proper direction. Sometimes it can also be good to work with two tools, one to rest the pin onto at the top, and the second tool pushes further below at the pin, to correct a bend.
This video here is probably one of the most useful ones, showing examples of how to fix pins:
I don't recommend using a knife though, at least not the cutting edge, because any slight cut in a pin won't be good, it may lead to the tip breaking off.
There's also this video where Alex from the NorthridgeFix channel is working on some socket pins:
He also has plenty more of such videos. I recommend watching several videos to get an idea how to approach it, and get some confidence about the procedure.
However it's done, the end goal is that all the socket pins look as similar as possible again, both in position and in height. It doesn't have to be 100% exact, because the contact pads underneath the CPU allow for some tolerance. Also, the CPU is pressing on the pins, so a tip of a pin can be a bit higher than the others, it will be pushed down on anyway. But it should at least all be quite similar to the surrounding pins.
One thing about MSI's warranty: MSI always tend to see it as customer-induced damage, due to the socket being inspected in the factory and the plastic cover protecting the pins afterwards (see MSI pins inspection video). So it normally isn't covered by their warranty, and they would return the board as-is. And that's understandable from their point of view, because after all, if someone dents their new car by hitting a pole by accident, they cannot take it to be fixed under warranty either.
I wouldn't say it's all the user's fault though, because when a process is so prone to mistakes like CPU installation on an LGA socket, they probably should've come up with a better solution for installing the CPU in there by now. Most people never noticed causing any damage, they only see the debacle once they take the CPU out and look. So it's way too easy to mess up for the end user without even realizing it.
Trying it myself - success despite failure:
I finally had a board in my hands that had a bent pin in the socket. I was pretty sure this was the case, because the entire memory channel A (slots A1+A2) was out of order, and the user ran their RAM in slots B1+B2 as single-channel, cutting the RAM bandwidth in half. The system was quite old anyway (using 2x 4 GB DDR3), so the overall risk was pretty low, making this a good guinea pig for fixing bent pins.
So I took off the cooler, took out the CPU, and inspected the socket closely:
I marked the expected position with the green dot, and the bent pin with the red arrow.
The bent pin was in the bottom right corner, and we can see the PCB traces (data lines) snaking from the CPU socket over to the RAM sockets. This was surely the culprit for the first two RAM slots not working.
The pin was bent over backwards onto itself. This is one of the worst bends, because when trying to bend it fully the other way again, the risk of it breaking off is quite high. It's much preferred if the pin is just bent sideways or downwards, for example. But hey, we have to deal with it. On the plus side, the pin is on the very outside, that's the best position for fixing it.
After the first attempt of fixing it:
That didn't go as planned. The pin was very folded, and my attempts to unfold it somehow made it also bend sideward. There is now already metal fatigue on the weakest part of the pin, where it has that additional bend upwards for the tip. So the following was almost inevitable, after some additional - what I thought was quite careful - nudging:
The tip broke off. I removed it with a magnetized precision screwdriver. Now, there was only once chance: Project Hail Mary. That is, bending the stub, the remainder of the pin, further upwards, in hopes that it will reach the correct contact pad of the CPU (once the CPU presses down on the pins). So that's what I did:
The different reflection shows that the partly-broken-off pin is now at a steeper angle. Let's see what the board says when I mount everything, put the RAM into the correct A2+B2 slots, and boot to BIOS:
Well, what do we have here... complete success! Where the RAM was previously only recognized in the B-channel slots, it now works in A2 as well, putting the memory system into dual-channel mode and doubling the bandwidth again. Further RAM testing with Memtest86 and Windows memory diagnostic gives a clean bill of health, no further issues in preliminary testing.
What's the moral of the story? It's always worth a try to fix bent pins.
This post is meant as a reference link that I can give people, that hopefully includes some useful information. But people are also welcome to post their socket photos here, if they suspect they have bent socket pins, and ask my (or all our) opinion on fixing them. I hope I can help some people fix their pins!
You can try use injection needle (ideally ones that are not sharp) to gently move it with minimal risk and best to try move it above few times to get it in hand.
Also, not all pins are used and some have duplicate functions so unless they are in risk of touching other pins it might be best just to leave it.
PS: I prefer to use both hands when inserting CPU, one hand can slip, two less likely.
Yes, basically any tool that ends in a small enough and precise enough tip to manipulate socket pins with.
You, mean, practice in the air above the pin first? Good idea. Anything that can give more confidence.
Quite correct, however, usually people are not even immediately aware that there are bent pins in the socket, they only notice a problem first. For example, the PC won't pass POST and won't boot to BIOS, there is no RAM detected in one or two RAM slots, things like that. Then they post here, we tell them to check the socket pins if all the usual troubleshooting like a BIOS update etc. doesn't help, and then they notice the disaster. So, in those cases, the pins will have to be fixed for it to work properly.
Now, as for bending some pin(s) on accident and immediately noticing it - then you could maybe look up the pinmap first, and check what the pins do. A lot of VSS (ground) pins are redundant for example. But still, I would try to fix the bent pins first, I would not just mount the CPU and see what happens. Because mounting the CPU means that the pins get pressed on, which can make some bends worse.
Also, if a pin is just bent to the side a little, the fix is quite easy, just push it to the left or right a bit, there is comparatively little risk of it breaking off. Same when it's just pushed down, just bend it up from underneath a bit. Where it gets a bit hairy is when a pin is bent over on itself, or any kind of complex bend where it has to be unbent. This is when a pin can break off, as demonstrated in my little experiment at the end. If there is such a badly bent pin, and it doesn't seem important according to the pinmap, then it could be worth seeing what happens.
