Guide: How to set good power limits in the BIOS and reduce the CPU power draw
Pro
By now, and not only since threads like these, many Intel users will have heard (or have found out) that a lot of Intel CPUs have a very high power draw that can really push the CPU cooling capabilities to the limit and beyond. There used to be a time where a cheap tower air cooler would be enough for any CPU available for that socket. That era pretty much ended with the i9-9900K, the first "monster", and then from 10th gen onward, Intel really started pushing the higher-up CPU models to the absolute edge. Causing higher and higher power draw, which has now gotten ridiculously high with the 14th generation like the 14900K.
Note that Intel also recommend certain power limits for different CPU models, but those are more or less arbitrary, they have nothing to do with your individual cooling capabilities. One thing i would say, there is no benefit in allowing more than ~250W for any CPU, not even a 14900KS. Because it will always make the CPU run more inefficiently from that point onward (at the very latest, for other CPU models even earlier). That's then "junk power draw" or "junk performance", meaning the power draw still keeps increasing a lot, but only for minimal performance gains, it basically just ruins the efficiency. So even with a high-end 360mm AIO, you will not tend to see me recommending limits higher than 253W.
Check the performance too:
Yes, because it is needlessly fighting the outcome of undervolting. By lowering the voltage, you are trying to do the best thing you can do to the way a CPU operates (as long as it stays stable), and IA CEP is working against it because it detects a deviation from a narrow "normal" range it tries to uphold. But we are know that lowering the voltage is not dangerous (quite the opposite), so we should not let IA CEP interfere in this instance. Furthermore, using an updated BIOS with the fixed Intel microcode will prevent the voltage spikes that can cause CPU degradation, so that's already the main line of defence. The recommendation to keep IA CEP enabled comes from a time way before BIOS updates with this new microcode were available, plus it was meant for default BIOS settings, not for hand-optimized settings. Here is more circumstantial evidence that disabling IA CEP should not cause the current to go crazy. So when you see the performance going down the drain when lowering "CPU Lite Load" below Mode 10 or so, simply set IA CEP Support to [Disabled], nothing bad will happen.
What to do when the option "IA CEP" is not available, for example on B660?
Let's recap: If IA CEP is available and there's a severe performance drop (e.g. Cinebench score cut in half) when lowering the CPU Lite Load mode below a certain point, then IA CEP has to be disabled, simple as that. But on some boards, like most B-series chipset boards (B660, B760), IA CEP is not available as an option. What then?
There's two possibilities:
1) Performance stays the same when you lower CPU Lite Load (which is what you want, but usually only happens on Z-series boards where IA CEP is not available as a setting), or:
2) Performance drops off a cliff once you lower CPU Lite Load significantly enough (which is bad, and would be the case on most B-series chipset boards).
In other words, on a B-series board, where the setting is not available or ineffective, that severely limits the undervolting capabilities. So in that case, if the option is not available and you notice a performance drop below a certain mode, you either have to use the lowest CPU Lite Load mode that still keeps the full performance (often around Mode 9 or 10), or you have to use a more sophisticated undervolting method that tries to "dance around" IA CEP becoming active, using a combination of different settings. But that is quite complicated, and sadly, the bottom line is, with a B-series chipset board it's very difficult to achieve a similar undervolting result as with a Z-series board. No matter the undervolting method, at some point, IA CEP will "bite".
Note that this method is "officially recommended" by MSI now, see
this blog entry!
For the Z890 boards with Core Ultra, due to the many architectural changes in Core Ultra, i cannot promise the same results, especially since the power draw reading in HWinfo (CPU Package Power) can be inaccurate due to the way Core Ultra is designed. It can be "calculated wrongly" depending on some other settings. So for now, i can only guarantee proper results up to 14th gen. I've used this CPU Lite Load setting all the way back from my old 9600K, across generations in between, and up to my current 13th gen, it's always the same procedure to optimize it.
My other guides:
Guide: How to find a good PSU
The following is for geeks only, others can stop reading :)
In CPU Lite Load Advanced, you can select values for AC and DC Loadline separately, without having some preset combination which can have the wrong DC Loadline value. So now you can set the DC Loadline so it results in the correct power draw numbers. Doing that involves using HWinfo Sensors, creating full CPU load, then looking at the CPU's VID requests (in the "current values" column), which is the voltage the CPU asks for from the board, and comparing it to the current VCore value (note that i don't mean current as in Amperes, i mean current as in, actual live values, not Min/Max/Avg). If those are near-identical, the correct DC Loadline value has been found. The correct DC Loadline value depends on the LLC mode, another setting which influences the voltage (and not to be confused with CPU Lite Load / CLL, completely different). A table of the AC/DC loadline values is here, but it's only a rough one, because each board model is built differently and would also need a bit different values, presumably.
However, this last step doesn't quite pan out in my ow testing on a PC I was building for someone. Because even if i set CPU Lite Load "Advanced" AC Loadline to 1 (the lowest possible value) and select a mild LLC setting like Mode 7 (where the VDroop is still relatively big), i can't get anywhere near the low voltages and low power draw under full load that i can reach with just a lowered CPU Lite Load mode and keeping LLC on Auto. I'm talking a coupled dozen Watts difference here under full load, measured at the wall. In other words, lowered CPU Lite Load with LLC on Auto results in the lowest possible VCore and power draw under full load (while staying stable) in my testing, which is arguable one of the most important scenarios for which to keep the power draw low (to avoid cooling problems and improve the CPU's efficiency).
That now-obsolete recommendation stems from the very first set of Intel recommended settings (easily identifyable from there still being that "DC loadline must match AC loadline" text). That table was not only superseded by a second one (which didn't include that text anymore), but also, both those tables came out way before there was any microcode fix available for the voltage spikes. I have explained more about the timeline in this post. Today, this old recommendation "AC equal DC" is nonsense.
About your settings, you can combine different undervolting methods etc., just make sure it's all stable by properly stress-testing it (with Prime95, OCCT, CB R15 for example). Cinebench R23 is good for dialing in appropriate power limits and checking CPU performance, but it's not good as a stress test, because it's not that sensitive to instability. You can have CB R23 still running fine while OCCT would immediately throw an error.
Thank's!!! So my settings absolutely safety to my cpu, am i right? I done some stability test with ycruncher, occt, prime95 and all stable! And another question, as i know that msi llc auto equal to llc8? but with llc auto i have bsod instantly with ac=1, dc=110. On another case witl llc8 all fine.
Well, it's the end result that counts, so it's not too important what the default does, if it's behaving worse. For a test, you could remove your adaptive+offset undervolt, set LLC to Auto and see how much you can lower the CPU Lite Load mode in the conventional manner, then compare the end result (voltages / power draw / temperatures / performance) to what you get right now. Compare the two scenarios and see which one works better.
Thank's) I done this yesterday. For statistics(maybe be useful for another owners). If all set default, except pl1=200, and pl2=200, with only liteload(cep and undervolting off) my pc stable on liteload =7. In cb23 got near 33500 points with vcore =vid=1.30 for 5200mhz frequencie. i7-14700k temp in this case 80-85c(With Thermalrigth Phantom Spirit Evo). With ac=1, dc=110, llc=8, and adaptive +offest = -110, getting 35000 points on cb23, temp 80-85c but frequence 5400mhz-5500mhz, and vcore=vid=1.2-1.25(what i think good result). If lower Icmax from 307 to 249, then 32500 points, but temp MUCH lower, 70-75c. p/s sorry for my English)))
Looks like found good settings for your particular CPU then. About IccMax (CPU Current Limit), much lower temperatures obviously come from lower power draw due to it hitting the current limit before the power limits, and reducing voltages and frequencies further. So theoretically you could do an efficiency calculation, how many CB23 points you get from which amount of power draw, to determine if it's worth lowering IccMax. But unless you regularly have full load in daily use later, it probably doesn't really matter much.
I noticed that with undervolting with Lite Load, my CPU did not boost above 5,2 or 5,3 ghz in STALKER 2, but with manually setting AC/DC and LLC it did boost to 5,7ghz, it had the same voltage readings in hwinfo, but just lower clock speeds.
Any one else notice some gaming differences between the two methods?
Hello, i was looking at your guide to reduce my temps on my 11900k while gaming. I took down the Max Watt to 253W (it was in auto with 4095 max) just as you said but my "Max Current A" is stuck to 256A max. I cannot take it to 400A. My motherborad is an MSI Z590 Meg Unify. I would really appreciate you help. Thanks
Even when you select "Water Cooler" for the power limits, the CPU Current Limit does not go above 256A? Is it limiting (meaning, it doesn't reach the 253W power limits under full load)? What kind of power draw does it hit during a Cinebench run?
It seems like 256A might've been the limit on Z590? When i look at some BIOS screenshots, then it says 256A too:
But if it goes to 230W at least, you won't lose much performance from this, and if you do, then mainly in full multithreaded load like Cinebench. Other things like gaming should stay much below this kind of power draw.
Just installed an MSI z790 Carbon Max WiFi II with my 13900KS. I have MSI Performance Settings implemented in the BIOS. My cores are down clocking 200MHz in CB23 and I don’t know why. It’s not hitting the thermal limit. Also, the BIOS won’t let me edit the power or current limits, why is that?
To modify the limits, enter the numbers you want to set them to. For example type 250 and press enter, it should change it to that.
I'm trying to balance the power using amps vs offset with while the power is set at max. I mean, it's giving some awesome results, but I cannot get it fully stable.
I don't think I'm going about this the right way. Guess I'll give your guide a read and use that approach instead.
When doing heavy workloads, it's not unusual to see lower clock speeds. My i9 14900k clocks down to 5,3ghz instead of 5,7 but has the same R23 scores as everyone else's.
When I raise the voltage, the clock speeds go up (the current goes down, same power draw), but it generates slightly more heat for no extra performance.
i have a z690 a ddr4 with a 4090. i just swapped my old 13600kf for a 14900kf and when i boot into windows my pc restart with the newer processor. sometimes i get to input my login data then it freezes. what is wrong? i ma using the latest microcode bios 0x12b and also i set my clocks way lower with offset and even my voltage offset...
Start from default BIOS settings, load optimized defaults, with MSI cooler settings (middle option on the cooler selection screen). It should not have any instability like that, it may only overpower your cooling under load, but that can be taken care of by this guide. When it's stable, then you can work from there, trying to optimize it further. How are the CPU temperatures in the BIOS?
I am.going to get [***CENSORED***] up on new years party now but i can say in bios it s 35 celsius.
Middle option is performance right and top is intel
Yes. Also, it's better not to post your issue in several different threads. We can try to make it work properly in this thread, or you could also create a new thread, listing all your hardware including CPU cooler, PSU and so on, and we can figure it out there. But just posting in different seemingly related threads is just gonna lead to fragmentation, people there don't know what has already been tried in another thread etc.
BIOS temperature seems normal at least.
