Guide: How to set good power limits in the BIOS and reduce the CPU power draw
Pro
By now, and not only since threads like these, many Intel users will have heard (or have found out) that a lot of Intel CPUs have a very high power draw that can really push the CPU cooling capabilities to the limit and beyond. There used to be a time where a cheap tower air cooler would be enough for any CPU available for that socket. That era pretty much ended with the i9-9900K, the first "monster", and then from 10th gen onward, Intel really started pushing the higher-up CPU models to the absolute edge. Causing higher and higher power draw, which has now gotten ridiculously high with the 14th generation like the 14900K.
Note that Intel also recommend certain power limits for different CPU models, but those are more or less arbitrary, they have nothing to do with your individual cooling capabilities. One thing i would say, there is no benefit in allowing more than ~250W for any CPU, not even a 14900KS. Because it will always make the CPU run more inefficiently from that point onward (at the very latest, for other CPU models even earlier). That's then "junk power draw" or "junk performance", meaning the power draw still keeps increasing a lot, but only for minimal performance gains, it basically just ruins the efficiency. So even with a high-end 360mm AIO, you will not tend to see me recommending limits higher than 253W.
Check the performance too:
Yes, because it is needlessly fighting the outcome of undervolting. By lowering the voltage, you are trying to do the best thing you can do to the way a CPU operates (as long as it stays stable), and IA CEP is working against it because it detects a deviation from a narrow "normal" range it tries to uphold. But we are know that lowering the voltage is not dangerous (quite the opposite), so we should not let IA CEP interfere in this instance. Furthermore, using an updated BIOS with the fixed Intel microcode will prevent the voltage spikes that can cause CPU degradation, so that's already the main line of defence. The recommendation to keep IA CEP enabled comes from a time way before BIOS updates with this new microcode were available, plus it was meant for default BIOS settings, not for hand-optimized settings. Here is more circumstantial evidence that disabling IA CEP should not cause the current to go crazy. So when you see the performance going down the drain when lowering "CPU Lite Load" below Mode 10 or so, simply set IA CEP Support to [Disabled], nothing bad will happen.
What to do when the option "IA CEP" is not available, for example on B660?
Let's recap: If IA CEP is available and there's a severe performance drop (e.g. Cinebench score cut in half) when lowering the CPU Lite Load mode below a certain point, then IA CEP has to be disabled, simple as that. But on some boards, like most B-series chipset boards (B660, B760), IA CEP is not available as an option. What then?
There's two possibilities:
1) Performance stays the same when you lower CPU Lite Load (which is what you want, but usually only happens on Z-series boards where IA CEP is not available as a setting), or:
2) Performance drops off a cliff once you lower CPU Lite Load significantly enough (which is bad, and would be the case on most B-series chipset boards).
In other words, on a B-series board, where the setting is not available or ineffective, that severely limits the undervolting capabilities. So in that case, if the option is not available and you notice a performance drop below a certain mode, you either have to use the lowest CPU Lite Load mode that still keeps the full performance (often around Mode 9 or 10), or you have to use a more sophisticated undervolting method that tries to "dance around" IA CEP becoming active, using a combination of different settings. But that is quite complicated, and sadly, the bottom line is, with a B-series chipset board it's very difficult to achieve a similar undervolting result as with a Z-series board. No matter the undervolting method, at some point, IA CEP will "bite".
Note that this method is "officially recommended" by MSI now, see
this blog entry!
For the Z890 boards with Core Ultra, due to the many architectural changes in Core Ultra, i cannot promise the same results, especially since the power draw reading in HWinfo (CPU Package Power) can be inaccurate due to the way Core Ultra is designed. It can be "calculated wrongly" depending on some other settings. So for now, i can only guarantee proper results up to 14th gen. I've used this CPU Lite Load setting all the way back from my old 9600K, across generations in between, and up to my current 13th gen, it's always the same procedure to optimize it.
My other guides:
Guide: How to find a good PSU
The following is for geeks only, others can stop reading :)
In CPU Lite Load Advanced, you can select values for AC and DC Loadline separately, without having some preset combination which can have the wrong DC Loadline value. So now you can set the DC Loadline so it results in the correct power draw numbers. Doing that involves using HWinfo Sensors, creating full CPU load, then looking at the CPU's VID requests (in the "current values" column), which is the voltage the CPU asks for from the board, and comparing it to the current VCore value (note that i don't mean current as in Amperes, i mean current as in, actual live values, not Min/Max/Avg). If those are near-identical, the correct DC Loadline value has been found. The correct DC Loadline value depends on the LLC mode, another setting which influences the voltage (and not to be confused with CPU Lite Load / CLL, completely different). A table of the AC/DC loadline values is here, but it's only a rough one, because each board model is built differently and would also need a bit different values, presumably.
However, this last step doesn't quite pan out in my ow testing on a PC I was building for someone. Because even if i set CPU Lite Load "Advanced" AC Loadline to 1 (the lowest possible value) and select a mild LLC setting like Mode 7 (where the VDroop is still relatively big), i can't get anywhere near the low voltages and low power draw under full load that i can reach with just a lowered CPU Lite Load mode and keeping LLC on Auto. I'm talking a coupled dozen Watts difference here under full load, measured at the wall. In other words, lowered CPU Lite Load with LLC on Auto results in the lowest possible VCore and power draw under full load (while staying stable) in my testing, which is arguable one of the most important scenarios for which to keep the power draw low (to avoid cooling problems and improve the CPU's efficiency).
For a 14900K(F), a 240mm AIO is almost borderline, we'll see what it can deal with later, probably somewhere around 200-220W. But first priority is full stability.
As i said, try to completely on defaults, with whatever high CPU Lite Load mode they have as a preset. Until we have a stable baseline, we can't do much else, you can't do the second step before the first.
i did complete defaults and it just does nothing... i am quitting this process and will try to make a rma at intel. i incremented a lite load above the one i used that worked and the default that was 12 and it just crashed... nothing to to here any more
Hello, good morning!
I wanted to ask a question about the GHz limitation on the p-cores. This would be for a work configuration, not for games.
The processor in question is a 14900K with a B760 Tomahawk motherboard, and I have applied the CPU LL 10 and disabled the IA CEP and it works at 5.7GHz, which is very good. But I wanted to do some tests reducing the GHz, and I don't know specifically in which section I can apply it so that it doesn't work at more than 5.4GHz and I can do the performance tests. Please, could you tell me in which specific section I can configure it. Thanks
Sure. Press F7 to use advanded view in the BIOS. Go to OC, set "OC Explore Mode" to [Expert].
Set "P-Core Ratio Apply Mode" to [Turbo Ratio] if you want to set the multiplier directly,
or [Turbo Ratio Offset] if you want to set -1, -2 etc. multiplier offsets (-100 MHz, -200 MHz etc.).
Usually an offset is easier to understand, so in your case, set everything under "P-Core Ratio" to -3 if you want all boost clocks to be 300 MHz lower.
Think this only works when the core is unlocked. Couldn't do it with mine, but I like too. I have the auto mode and still getting 5.4GHz. It's only harder to OC and keep it there at the end of a stress test.
Actually, your CPU's multipliers are unlocked as with any -K series CPU, but maybe it's the fact that you're using a B-series board (not a Z-series one) that you cannot change the multipliers like you want. To be honest, for a 14900K, i wouldn't be messing with a B-series board anymore, even though your B760 Tomahawk is the one B-series board that's quite good. But normally, when you get this high-end of a CPU model, you can get a Z-series board to go along with it.
Going to tell you my founding. The Z790 unlocked 13600 can be manually set at low speed at first, and the 13900 locked (same board) I could not be set at low speed. Why, you might ask... In my belief, it is in the lack of advanced CPU configurations. The only thing that can cross my mind is therminal points and something how it changes the speed. I will post the differences between the two cores and send pictures I took. I will get back to you in a moment.
therminal points : Just found out that my 13600 can be set at lower speed without therminal points.
Look the variety of things with the 13600
Now for the 13900K (locked) this is it.
A lot less for 300dollar more! Other architecture (add TBMT 3.0) yes, and don't know what is going on here, because a friend of me with an Asus board can set the terminal points. So I flashed it to the new bios H.E0, but still the same. Looks more like a config for a 5 years ago. It did the best I could to work with the automatic option but limited in speed when it comes to stability with the lack of features (Voltage-points is missing too).
Changing turbo changes nothing to the speed. It even lowers it on my 13900K with the best config I could... LOCKED what does it mean? That it can't go over the 5.7GHz?
Whoops, yeah, my mistake, i misunderstood the issue. I thought this was related to this post somehow:
But of course, when you use a Z790 board, what i posted about the B-series boards cannot be the explanation.
It's weird that there's such a difference with the options between those CPUs.
No, I am glad for him it worked. But adjusting the speed isn't an option for me. Other CPU, other motherboard.
Some info about my specific hardware.
Greetings.
a small remark, I speak English fluently, but only with Google translate) so don't be surprised if there are strange expressions)
MSI MAG Z790 TOMAHAWK MAX WIFI Motherboard
Intel Core i7-14700K processor
DEEPCOOL LT720 cooling system
Bios E7E25IMS.A80 (latest)
Cinebench R23 Tests
Corona Benchmark
(for now, I don't want to lose performance, then I'll adjust for stability with other tests (Linpax, prime95, etc.))
according to the manual, I reduced PROCESSOR consumption via CLL normal (mode 4 (AC/DC = 0.15 / 1.1)), but in this mode the frequencies do not reach their standard values (P - 5.5, E - 4.3)
with CLL mode 4 values:
temp max - 74 / avg - 72,
V core max - 1.264 / V core avg - 1.125,
VIDs max - 1.337 / avg - 1.112
Power max - 227 W / avg - 195 W
P/E - 5.3 / 4.1
and, accordingly, the performance is lower
CbR23 - 33 970 +-
Corona - 11 020 000 +-
The frequencies do not rise above 5.3 and 4.1
but if you set CLL mode 10 (AC/DC = 0.5 / 1.1) and set Core Voltage offset to -100, then performance increases, frequencies reach their values of P - 5.5, E - 4.3
CbR23 - 35 568 +-
Corona - 11 420 000 +-
frequencies P - 5.5, E - 4.3 stable
*frequencies are stable only in benchmarks, the Aida64 test was launched, in the test the frequencies began to drop to P- 5.4 / E - 4.2
after that, I raised the CLL by 1 step, i.e. set CLL = Mode 11 ( AC/DC = 0.6 / 1.02 )
and set offset -0.125
according to HWiNFO, the temperature, voltage, and power remained the same as with CLL mode 10 (see the results above)
, the results are the same in benchmarks +-
BUT in the Aida64 test, the frequencies became stable at P - 5.5 / E - 4.3
The LLC was not used.
I did the test and the performance dropped when using it, while the temperature and power increased.
can you help me figure out why it happens that the frequencies don't rise to their values (5.5 / 4.3) without offset?
aren't these settings dangerous for the processor?
OC / Advance CPU Configuration
BCLK 100MHz Lock on = Enabled
Long Duration Power Limit = 253
Short Duration Power Limit = 253
CPU CUrrent Linit = 307
CLL (CPU Lite Load Control ) = advance (
AC LL = 0.5
DC LL = 1.02 (slightly lowered so that Vcore and VIDs were the same)
CPU Under Voltage Protection = Disabled
IA CEP Support = Disabled
IA CEP Support for 14th = Disabled
OC
CPU Core Voltage Mode = Offset Mode
CPU Core Voltage offset Mode = - (By CPU)
CPU Core Voltage offset = 0.100
with these settings, I get the following values
with CLL mode 10, offset - -100 values:
temp max - 80 / avg - 77,
V core max - 1.240 / V core avg - 1.182,
VIDs max - 1.292 / avg - 1.183
Power max - 242 W / avg - 230 W
P/E - 5.5 / 4.3
or is it better to limit the downgrade only through CLL?
perhaps you need to enable or disable some setting?
if anyone is interested, here is the CLL mode table for MSI MAG Z790 TOMAHAWK MAX WIFI (incomplete) (after updating the BIOS, CLL 16 mode (AC/DC - 1.1/1.1) was displayed as standard)
| mode | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 |
| AC | 0,05 | 0,10 | 0,15 | 0,20 | 0,25 | 0,30 | 0,35 | 0,40 | 0,50 | 0,60 | 0,70 | 0,80 | 0,90 | 1,00 | 1,10 |
| DC | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 |
By now, and not only since threads like these, many Intel users will have heard (or have found out) that a lot of Intel CPUs have a very high power draw that can really push the CPU cooling capabilities to the limit and beyond. There used to be a time where a cheap tower air cooler would be enough for any CPU available for that socket. That era pretty much ended with the i9-9900K, the first "monster", and then from 10th gen onwards, Intel really started pushing the higher-up CPU models to the absolute edge. Causing higher and higher power draw, which has now gotten ridiculously high with the 14th generation like the 14900K.
In the BIOS, first press F7 to switch to Advanced View, then go to "OC\Advanced CPU Configuration" and set the values. Then check in Windows if the temperatures under full load are ok. If not, lower the values until you stay away from the >90°C range. Then the cooling is protected and there is no dependence on thermal throttling.
Note that Intel also recommend certain power limits for different CPU models, but those are more or less arbitrary, they have nothing to do with your individual cooling capabilities. One thing i would say, there is no benefit in allowing more than ~250W for any CPU, not even a 14900KS. Because it will always make the CPU run more inefficiently from that point onwards (at the very latest, for other CPU models even earlier). That's then "junk power draw" or "junk performance", meaning the power draw still keeps increasing a lot, but only for minimal performance gains, it basically just ruins the efficiency. So even with a high-end 360mm AIO, you will not tend to see me recommending limits higher than 253W.
Short guide: Just manually set a lower mode for CPU Lite Load. Your only limit for lowering it would be the point where the CPU becomes unstable because the voltage becomes too low. Once you see instability in any CPU stress testing tool (i list a few further down below), or even in normal workloads like Cinebench already, then back off one step and test the next higher mode (so for example Mode 3 -> 4). Once you find the lowest stable mode (say if Mode 4 is stable), i recommend to actually set it one mode higher than that (Mode 5 in this example), to have stability headroom and not be on the edge of stability. If you see a big performance decrease from lowering the mode by a bunch of steps, then you need to disable the option "IA CEP" (it's on the same BIOS page as all the other options mentioned here). Done.
Yes, because it is needlessly fighting the outcome of undervolting. By lowering the voltage, you are trying to do the best thing you can do to the way a CPU operates (as long as it stays stable), and IA CEP is working against it because it detects a deviation from a narrow "normal" range it tries to uphold. But we are know that lowering the voltage is not dangerous (quite the opposite), so we should not let IA CEP interfere in this instance. Furthermore, using an updated BIOS with the new 0x129 microcode will prevent the voltage spikes that can cause CPU degradation, so that's already the main line of defense. The recommendation to keep IA CEP enabled comes from a time way before BIOS updates with this new microcode were available, plus it was meant for default BIOS settings, not for hand-optimized settings. Here is more circumstantial evidence that disabling IA CEP should not cause the current to go crazy.
What to do when the option "IA CEP" is not available?
We know now, if IA CEP is available and you notice a severe performance drop (for example Cinebench score getting lower), then it has to be disabled, simple as that.
But what if IA CEP is not available as an option on your board? Then there's two possibilities, which you can't influence:
1) Performance stays the same when you lower CPU Lite Load (which is what you want, and is the case with my configuration), or:
2) Performance drops off a cliff once you lower CPU Lite Load enough, or otherwise try to lower the core voltage (bad, this would severely limit the undervolting capabilities).
If the option is not available and you notice a performance drop, then you either have to use the lowest CPU Lite Load mode that still keeps the full performance (often around Mode 9), or you have to use a more sophisticated undervolting method that tries to "dance around" IA CEP becoming active, using a combination of different settings. But that is beyond the scope of this guide.
For the Z890 boards with Core Ultra, the BIOS looks a bit different, but it seems to have pretty much the same options at least, and i would assume CPU Lite Load works in a similar manner. However, due to the many architectural changes in Core Ultra, i cannot promise the same results, especially since the power draw reading in HWinfo (CPU Package Power) can be inaccurate due to the way Core Ultra is designed. It can be "calculated wrongly" depending on some other settings. So for now, i can only guarantee proper results up to 14th gen. Personally, i've used this CPU Lite Load setting all the way back from my old 9600K, generations in between, and up to my current 13th gen. Always the same procedure to optimize it.
However, MSI themselves are now saying how useful this setting can be, here's an example from their new Z890 boards:
So apparently, it's "all systems go" on Z890 and Core Ultra as well. I just haven't seen much about it yet, the Core Ultra CPUs don't seem that attractive at the moment.
My other guides:
In CPU Lite Load Advanced, you can select values for AC and DC Loadline seperately, without having some preset combination which can have the wrong DC Loadline value. So now you can set the DC Loadline so it results in the correct power draw numbers. Doing that involves using HWinfo Sensors, creating full CPU load, then looking at the CPU's VID requests (in the "current values" column), which is the voltage the CPU asks for from the board, and comparing it to the current VCore value (note that i don't mean current as in Amperes, i mean current as in, actual live values, not Min/Max/Avg). If those are near-identical, the correct DC Loadline value has been found. The correct DC Loadline value depends on the LLC mode, another setting which influences the voltage (and not to be confused with CPU Lite Load / CLL, completely different). A table of the AC/DC loadline values is here, but it's only a rough one, because each board model is built differently and would also need a bit different values, presumably.
The second criticism: It has been said that CPU Lite Load sometimes cannot be lowered as much when you don't also tweak the LLC mode. That's because, when keeping LLC mode on Auto, it results in a big VDroop (VCore reduction under high CPU load, to prevent an overshoot when the high CPU load suddenly stops and the voltage regulator has trouble reacting fast enough, causing a voltage overshoot if VDroop was not applied). So with CPU Lite Load, when lowering the mode there, the VDroop also has to be taken into account. Let's say we have to stay at CPU Lite Load "Normal" Mode 5, because otherwise, together with the big VDroop, the voltage under load wouldn't be enough for stability. But when we then look at low- to mid-load scenarios, VCore might be slightly higher than necessary for stability, whereas without such big of a VDroop, it might've been stable on Mode 2 or so. So what has then been suggested is to also set the LLC to something more aggressive (starting from LLC Mode 8 and going up towards Mode 1, it gets more and more aggressive in preventing VDroop, but Mode 1 is far too aggressive, usually you'd never go beyond Mode 4 or 3).
However, this last step doesn't quite pan out in my own recent testing on a PC i'm building for someone. Because even if i set CPU Lite Load "Advanced" AC Loadline to 1 (the lowest possible value) and select a mild LLC setting like Mode 7 (where the VDroop is still relatively big), i can't get anywhere near the low voltages and low power draw under full load that i can reach with just a lowered CPU Lite Load mode and keeping LLC on Auto. I'm talking a coupled dozen Watts difference here under full load, measured at the wall. In other words, lowered CPU Lite Load with LLC on Auto results in the lowest possible VCore and power draw under full load (while staying stable) in my testing, which is arguable one of the most important scenarios for which to keep the power draw low (to avoid cooling problems and improve the CPU's efficient
Very informative post. Out of curiosity I have a an MSI edge WiFi z690 DDR 4 motherboard paired with an i5 12600KF. what current limit do you suggest? In the motherboard it is set at 400A, which I think is overkill. Am I right? If yes, what number do think is safe?
Greetings.
Cinebench R23 Tests
Corona Benchmark
P/E - 5.3 / 4.1
CbR23 - 33 970 +-
CbR23 - 35 568 +-
AC LL = 0.5
OC
P/E - 5.5 / 4.3
Better to leave BLCK, CLL and PLL alone and keep as much as possible in auto settings or enabled.
Evrything is safe if you don't play around with voltage - and frequency limits, if you keep thermal throttling enabled and try to avoid it.
with default settings, the temperature is 15-20 degrees higher, the power is higher, the frequencies are lower, the performance is lower, and there is throttling.
I think this is wrong, and that's why the instructions in the header are written on how to fix it.
and after these changes, it got better, if we take into account that the temperatures are lower, the frequency is higher, the power is lower and there is no throttling.
I just don't understand some points that are not covered in the post, which I would like to clarify.
In stead of auto in advance CPU configuration, use enabled. Your don't have control over your system. Expert mode you have? Then set it to 165, 128s 250w and 512A en 30 , but when the cpu watage in HWinfo is to low you need the lower it. Then set the max temp on let say 95deg and lower the voltage with steps of -0,005V.
yes, I have expert mode enabled.
do you mean reset everything to default, and then set power limits (168/250) and current (512 (isn't that too much? intel recommendations it says 307 or 400 A)). and then undervolt the processor only using offset? do I need to use LLC for this?
Save your OC profile first. You put a lot of work in it. Then default would be a good starting point. I would start at 500, then lower it so you will temp will go up much fast. You don't want it to go to fast, it will have a negative impact on the long duration frequency. Like I sad leave LLC at auto and enable new technologies, so you are sure there are on.
