Guide: How to set good power limits in the BIOS and reduce the CPU power draw
Pro
By now, and not only since threads like these, many Intel users will have heard (or have found out) that a lot of Intel CPUs have a very high power draw that can really push the CPU cooling capabilities to the limit and beyond. There used to be a time where a cheap tower air cooler would be enough for any CPU available for that socket. That era pretty much ended with the i9-9900K, the first "monster", and then from 10th gen onward, Intel really started pushing the higher-up CPU models to the absolute edge. Causing higher and higher power draw, which has now gotten ridiculously high with the 14th generation like the 14900K.
Note that Intel also recommend certain power limits for different CPU models, but those are more or less arbitrary, they have nothing to do with your individual cooling capabilities. One thing i would say, there is no benefit in allowing more than ~250W for any CPU, not even a 14900KS. Because it will always make the CPU run more inefficiently from that point onward (at the very latest, for other CPU models even earlier). That's then "junk power draw" or "junk performance", meaning the power draw still keeps increasing a lot, but only for minimal performance gains, it basically just ruins the efficiency. So even with a high-end 360mm AIO, you will not tend to see me recommending limits higher than 253W.
Check the performance too:
Yes, because it is needlessly fighting the outcome of undervolting. By lowering the voltage, you are trying to do the best thing you can do to the way a CPU operates (as long as it stays stable), and IA CEP is working against it because it detects a deviation from a narrow "normal" range it tries to uphold. But we are know that lowering the voltage is not dangerous (quite the opposite), so we should not let IA CEP interfere in this instance. Furthermore, using an updated BIOS with the fixed Intel microcode will prevent the voltage spikes that can cause CPU degradation, so that's already the main line of defence. The recommendation to keep IA CEP enabled comes from a time way before BIOS updates with this new microcode were available, plus it was meant for default BIOS settings, not for hand-optimized settings. Here is more circumstantial evidence that disabling IA CEP should not cause the current to go crazy. So when you see the performance going down the drain when lowering "CPU Lite Load" below Mode 10 or so, simply set IA CEP Support to [Disabled], nothing bad will happen.
What to do when the option "IA CEP" is not available, for example on B660?
Let's recap: If IA CEP is available and there's a severe performance drop (e.g. Cinebench score cut in half) when lowering the CPU Lite Load mode below a certain point, then IA CEP has to be disabled, simple as that. But on some boards, like most B-series chipset boards (B660, B760), IA CEP is not available as an option. What then?
There's two possibilities:
1) Performance stays the same when you lower CPU Lite Load (which is what you want, but usually only happens on Z-series boards where IA CEP is not available as a setting), or:
2) Performance drops off a cliff once you lower CPU Lite Load significantly enough (which is bad, and would be the case on most B-series chipset boards).
In other words, on a B-series board, where the setting is not available or ineffective, that severely limits the undervolting capabilities. So in that case, if the option is not available and you notice a performance drop below a certain mode, you either have to use the lowest CPU Lite Load mode that still keeps the full performance (often around Mode 9 or 10), or you have to use a more sophisticated undervolting method that tries to "dance around" IA CEP becoming active, using a combination of different settings. But that is quite complicated, and sadly, the bottom line is, with a B-series chipset board it's very difficult to achieve a similar undervolting result as with a Z-series board. No matter the undervolting method, at some point, IA CEP will "bite".
Note that this method is "officially recommended" by MSI now, see
this blog entry!
For the Z890 boards with Core Ultra, due to the many architectural changes in Core Ultra, i cannot promise the same results, especially since the power draw reading in HWinfo (CPU Package Power) can be inaccurate due to the way Core Ultra is designed. It can be "calculated wrongly" depending on some other settings. So for now, i can only guarantee proper results up to 14th gen. I've used this CPU Lite Load setting all the way back from my old 9600K, across generations in between, and up to my current 13th gen, it's always the same procedure to optimize it.
My other guides:
Guide: How to find a good PSU
The following is for geeks only, others can stop reading :)
In CPU Lite Load Advanced, you can select values for AC and DC Loadline separately, without having some preset combination which can have the wrong DC Loadline value. So now you can set the DC Loadline so it results in the correct power draw numbers. Doing that involves using HWinfo Sensors, creating full CPU load, then looking at the CPU's VID requests (in the "current values" column), which is the voltage the CPU asks for from the board, and comparing it to the current VCore value (note that i don't mean current as in Amperes, i mean current as in, actual live values, not Min/Max/Avg). If those are near-identical, the correct DC Loadline value has been found. The correct DC Loadline value depends on the LLC mode, another setting which influences the voltage (and not to be confused with CPU Lite Load / CLL, completely different). A table of the AC/DC loadline values is here, but it's only a rough one, because each board model is built differently and would also need a bit different values, presumably.
However, this last step doesn't quite pan out in my ow testing on a PC I was building for someone. Because even if i set CPU Lite Load "Advanced" AC Loadline to 1 (the lowest possible value) and select a mild LLC setting like Mode 7 (where the VDroop is still relatively big), i can't get anywhere near the low voltages and low power draw under full load that i can reach with just a lowered CPU Lite Load mode and keeping LLC on Auto. I'm talking a coupled dozen Watts difference here under full load, measured at the wall. In other words, lowered CPU Lite Load with LLC on Auto results in the lowest possible VCore and power draw under full load (while staying stable) in my testing, which is arguable one of the most important scenarios for which to keep the power draw low (to avoid cooling problems and improve the CPU's efficiency).
I saved the profile.
I agree, if you try a new strategy, it's better to start with standard values.
What do you mean by "500"? maximum current ? the default values are set to PL1 PL2 = 253W. and the maximum current is 307A.
I won't touch the LLC yet, I'll leave it in auto mode.
Yes, maximum current 500A for a 12gen. It will never get there. Do you have bios with microcode installed? And water cooling?
да, у меня установлен последний биос с последними микрокодами от intel (Bios E7E25IMS.A80 (latest)).
установлено водяное охлаждение DEEPCOOL LT720 cooling system .
Процессор Intel Core i7-14700K .
max cpu current 512A
long power 190W,
duration 128 Sec.
short power 280w
Since you have microcode, you maybe need to decrease the max CPU current to 320W
with these settings, I received the following data.
CbR 23 - 31 000 +- (I haven't received such a small value yet)
Corona - 10 740 000 +-
The frequencies are 4.8 and 3.8 on average
temp max - 90 / avg - 71,
V core max - 1.384 / V core avg - 1.163,
VIDs max - 1.474 / avg - 1.152
Power max - 305 W / avg - 198 W
P/E - 4,8 / 3,8
OSST avx2
temp max - 91 / avg - 71,
V core max - 1.232 / V core avg - 1.076,
VIDs max - 1.232 / avg - 1.061
P/E - 4,4 / 3,6
The power limit is exceeded in all tests.
Very informative post. Out of curiosity I have a an MSI edge WiFi z690 DDR 4 motherboard paired with an i5 12600KF. what current limit do you suggest? In the motherboard it is set at 400A, which I think is overkill. Am I right? If yes, what number do think is safe?
For your CPU it doesn't matter so much, but you can set 307A for example. It will probably never draw close to that anyway, that CPU model is quite tame compared to a 14th gen -K.
You replied this to user @396le12a202ab, who has a 14700K, which is an absolute monster of a CPU. Intel themselves state 400A as the maximum, and he doesn't have a 12th gen, so this should be the first hard limit that we should observe. I know this was probably just a simple mistake and you confused him with @oussHYK, but we probably shouldn't allow maxed out IccMax for a 14700K.
In stead of auto in advance CPU configuration, use enabled. Your don't have control over your system. Expert mode you have? Then set it to 165, 128s 250w and 512A en 30 , but when the cpu watage in HWinfo is to low you need the lower it. Then set the max temp on let say 95deg and lower the voltage with steps of -0,005V.
long power 190W,
duration 128 Sec.
short power 280w
By now you know he has a 14700K, and you still give this advice, violating probably the one Intel recommendation that might've been among the more important ones, with how they emphasized it (ICCMAX must never exceed 400A), see also here for example.
So the Current limit i would set at 400A, this is already generous enough. The power limits, as i explain in my first post, it doesn't make much sense to go above ~250W, because above that tends to be the area of "junk performance", very little performance improvement bought by too much higher power draw, which effectively just ruins the efficiency.
Secondly, what's with a 90W delta between Short and Long duration power limits? Almost as bad as the Intel values of 253W -> 125W, if you go by one of their possible defaults. With a powerful AIO, put the limit around 250W, and a drop to 190W after two minutes shouldn't be necessary.
This whole PL1/PL2/Tau has just been a little trick by Intel to look better in benchmarks anyway, remember? There were benchmarks like SuperPi and old Cinebench versions etc. that ran for less than half a minute, so instead of using a single power limit, they allowed a higher power draw for 28 seconds, then a lower number for when the load goes on for longer. Later, the newer benchmarks took a bit more time to finish, so they increased the Tau time to 56 seconds. And Intel gave out "reviewer guides" for the CPU launches where they told the reviewers to make sure to run the benchmarks from a long idle period, to avoid the cooler being "heat-soaked" and to avoid so-called EWMA from becoming a factor, which i explain here.
Then with the newer Cinebench versions like R23, they went for a 10 minute runtime which prevents the higher Short power limit from giving a big advantage. So what did Intel allow the board makers to do (or at least turned a blind eye to it, up until the CPU degradation issue was uncovered)? Allow crazy high power draw / Current all the time, by semi-defaulting to maxed out limits. And the i7/i9 CPUs run at inefficiently high clocks and core voltages to gain the upper hand in the launch reviews, they run out of their comfort zone from factory, essentially factory-overclocked.
That's why we have gotten into this whole dilemma with having to use high-end coolers to be able to extract most of the performance out of a CPU, and still having to set power limits. If thermal throttling wasn't implemented, then with average coolers most people have, any high-end CPU would die immediately under load, probably in less than a few seconds. This is a development that started only some years ago with the i9-9900K, the first "beast" of a CPU that was pushed very hard from factory. And it has gotten worse ever since, with the 14900K being a latest "low point" if you will, and Core Ultra being the first step in a long time to something more efficiently-running, from Intel specifically.
Anyway, i don't quite agree with these setting recommendations, to me it looks like something you came up with by tossing some dice..
Avg temp too low, so temp clime too fast. Think we discussed this before... Lower Max. current. If I could get my hands on it, I could tell for sure this isn't the way. But as you know, I am missing some advanced CPU features on my 13gen flagship. I am going to take a rest, didn't sleep for ages. See you tomorrow!
Greetings.
a small remark, I speak English fluently, but only with Google translate) so don't be surprised if there are strange expressions)
MSI MAG Z790 TOMAHAWK MAX WIFI Motherboard
Intel Core i7-14700K processor
Cinebench R23 Tests
Corona Benchmark
(for now, I don't want to lose performance, then I'll adjust for stability with other tests (Linpax, prime95, etc.))
according to the manual, I reduced PROCESSOR consumption via CLL normal (mode 4 (AC/DC = 0.15 / 1.1)), but in this mode the frequencies do not reach their standard values (P - 5.5, E - 4.3)
with CLL mode 4 values:
temp max - 74 / avg - 72,
V core max - 1.264 / V core avg - 1.125,
VIDs max - 1.337 / avg - 1.112
Power max - 227 W / avg - 195 W
P/E - 5.3 / 4.1
and, accordingly, the performance is lower
CbR23 - 33 970 +-
Corona - 11 020 000 +-
The frequencies do not rise above 5.3 and 4.1
but if you set CLL mode 10 (AC/DC = 0.5 / 1.1) and set Core Voltage offset to -100, then performance increases, frequencies reach their values of P - 5.5, E - 4.3
CbR23 - 35 568 +-
Corona - 11 420 000 +-
frequencies P - 5.5, E - 4.3 stable
*frequencies are stable only in benchmarks, the Aida64 test was launched, in the test the frequencies began to drop to P- 5.4 / E - 4.2
after that, I raised the CLL by 1 step, i.e. set CLL = Mode 11 ( AC/DC = 0.6 / 1.02 )
and set offset -0.125
according to HWiNFO, the temperature, voltage, and power remained the same as with CLL mode 10 (see the results above)
, the results are the same in benchmarks +-
BUT in the Aida64 test, the frequencies became stable at P - 5.5 / E - 4.3
The LLC was not used.
I did the test and the performance dropped when using it, while the temperature and power increased.
can you help me figure out why it happens that the frequencies don't rise to their values (5.5 / 4.3) without offset?
aren't these settings dangerous for the processor?
OC / Advance CPU Configuration
BCLK 100MHz Lock on = Enabled
Long Duration Power Limit = 253
Short Duration Power Limit = 253
CPU CUrrent Linit = 307
CLL (CPU Lite Load Control ) = advance (
AC LL = 0.5
DC LL = 1.02 (slightly lowered so that Vcore and VIDs were the same)
CPU Under Voltage Protection = Disabled
IA CEP Support = Disabled
IA CEP Support for 14th = Disabled
OC
CPU Core Voltage Mode = Offset Mode
CPU Core Voltage offset Mode = - (By CPU)
CPU Core Voltage offset = 0.100
with these settings, I get the following values
with CLL mode 10, offset - -100 values:
temp max - 80 / avg - 77,
V core max - 1.240 / V core avg - 1.182,
VIDs max - 1.292 / avg - 1.183
Power max - 242 W / avg - 230 W
P/E - 5.5 / 4.3
or is it better to limit the downgrade only through CLL?
perhaps you need to enable or disable some setting?
if anyone is interested, here is the CLL mode table for MSI MAG Z790 TOMAHAWK MAX WIFI (incomplete) (after updating the BIOS, CLL 16 mode (AC/DC - 1.1/1.1) was displayed as standard)
| mode | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 |
| AC | 0,05 | 0,10 | 0,15 | 0,20 | 0,25 | 0,30 | 0,35 | 0,40 | 0,50 | 0,60 | 0,70 | 0,80 | 0,90 | 1,00 | 1,10 |
| DC | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 | 1,1 |
can you tell me what the problem might be based on my first post?
P/E - 5.3 / 4.1
P/E - 5.5 / 4.3
So, higher frequencies, higher performance, higher power draw and higher temperatures when combining CPU Lite Load and Offset undervolting.
It probably means, when you purely used a lower mode for CPU Lite Load, that some other limit came into play, potentially the CPU Current Limit? This then limited the CPU's boosting abilities even before any power limits came into play. That could be one explanation. From your pictures, IccMax aka CPU Current Limit was still set to 307A there, for this beast of a 14700K it might somehow still be limiting more than you want, so you could try only CPU Lite Load, but with a 400A limit. I explained before why i don't want to recommend 512A (maxed out limit).
I've also seen a couple other reports about lower frequencies. The frequencies aren't even the most important, the most important is the resulting performance. For example in some theoretical stress test like AIDA, i wouldn't care too much about the frequencies. But your Cinebench score shouldn't drop too much, ideally it should even improve as you undervolt, as long as you are in a power or temperature limit and not in a Current limit.
Better to leave BLCK, CLL and PLL alone and keep as much as possible in auto settings or enabled.
Evrything is safe if you don't play around with voltage - and frequency limits, if you keep thermal throttling enabled and try to avoid it.
Actually I don't intend to rise the voltages, but rather undervolt the CPU. As I live in a very hot country especially during the summer (it can reach over 45 celcius). So yeah, room temperature is already high as you can imagine. Thermal throttling is a real nightmare, especially on very hot days.
So, yeah 12600KF isn't really an impressive CPU, when compared to the high end 13th and 14th gen CPUs. Yet even when I chose Tower cooler option in the OC menu, I was surprised that MSI decided 400A was a good number.. And we all know the motherboard manufacturers running loose with almost no restrictions or supervision from Intel. Leading to the insane settings implemented in their motherboards.
So, let's say I wanted to be on the safe side.
It's not an attempt citay. My 13600k stayed at 5ghz (ready to go) and 13900 at 5,4GHz, but less stable because of the missing features I can't adapted. After 10min it went to 4,9GHz and backup to 5. I more thinking of a 14gen needs more technologies enabled, and yeah some need to be manually tuning according to the cooling system. Before frequency stays there one by one need to be done by wachting indication that limits are reached as you sad. Newer Intel cpu's don't go up in temp anymore that easy.
@oussHYK don't worry, cpu can get 100°C, but you need to stay a 10°C bellow and keep an eye on the motherboard temp too. Good airflow/cooler and to less therminal past can influence that. But you want to make a mess from it eather. In general voltage need to be lower, but not that much all the time. When loads kick in, thats where the stability issue is, lower when and higher wen it goos up. And when it at full load you don't want it to decrease too much. By decrease I mean neg. offset. And leave the LLC at auto.
Yeah 400A seams much, but thats not one component. VRM's stages arround the cpu, but I am not an expert in that. ;)
Tuned mine in the summer at 35°C. No problem with that, bether to do it at the worst moment. But that's air temp, doesn't mean your board is in rest at 45°C.
Yes i know, IccMax is internal CPU current that takes into account some things from the VRM, so the number is higher than expected. But still, if Intel explicitly stated not to exceed 400A even for a 14900KS, we shouldn't go around saying just to max it out to 512A, like the board makers have done with their "unlimited" cooler profiles in the past. These days should be over. Today we don't want to increase everything anymore, we want to tame these monster CPUs so they can do their job efficiently and not cause such a big headache for the cooling.
About high room temperatures, it sometimes can almost directly translate in that much higher CPU temperatures. It also depends on the fan curves, but roughly, with 15°C higher room temperature than normal, you could have around 15°C less headroom, which is a huge change. I would almost worry more about myself though, >30°C room temperature is pretty brutal.
Hello everyone,
I updated my PC found not a stable job in the game (BSOD sometimes) and Throttling in the test.
After which I conducted these bios settings with recommendations and a test.
My setup is :
i9-14900K on MPG-Z790-CARBON-WIFI (BIOS v. 7D89v1E date 2024-10-08):
Changes from "optimized defaults"
Cullers - chose the medium option.
  • Enhanced Turbo: Disabled
  • Short Duration Power Limit (W): 200
  • Long Duration Power Limit (W): 200
  • CPU Current Limit(A): 307
  • CPU Lite Load Control: Normal
  • CPU Lite Load: Mode 7 (was at 16 on "Auto")
  • IA CEP Support: Disabled
  • IA CEP Support for 14th: Disabled
Benchmarking
Cinebench R23 10 min - is ok
CPU Package Temperature : 91C Max, 55C Average
Now in the load load 100% with temperature everything is fine, but the problem is as follows:
With any turning on of its value, the “CPU Lite Load: Mode” game does not start at all with knocking out BSOD.
Then I remove the value in auto (with which the temperature sometimes reaches 100) and this works, but sometimes BSOD occurs in the very process of the game.
What else can you try?
THX
Which cooler do you have? For a 14900K, it seems slightly on the weak side. Also, please list your other components like RAM kit model, GPU, PSU.
It could point to your CPU already having suffered degradation, from being exposed to voltage spikes for a prolonged period of time on an older BIOS version with buggy microcode.
Have you only just updated the BIOS to the one with the µcode 0x12B? Was it running for a long time on an older BIOS version? Then it's totally possible that the CPU has already degraded a bit. The 14900K, along with the 13900K, is the most affected CPU model for the degradation from voltage spikes.
Once there is degradation (basically, damage to parts of the CPU on a molecular level), the CPU becomes a bit unstable at voltages it was originally stable at. As every overclocker knows, when you have instability at a certain voltage, you have two main ways of regaining stability: Lower the frequency and/or increase the voltage.
So, if we assume for a moment that your CPU suffered degradation, then you have a conflict:
1) To achieve stability, it would need higher voltages, but 2), It is already overpowering your cooling, and raising the voltages just makes everything much worse.
MSI presumably already tried to add stability for some degraded CPUs by setting such a high default mode for CPU Lite Load (which already makes things a lot worse for people who have a stable CPU, as it just drives up the voltages -> power draw -> heat -> temperatures, while lowering performance if it's in a power/temperature limit). But since your CPU is still not fully stable at Mode 16, you'd have to go even higher.
First, to test if higher voltages aid stability, set a higher mode. Start with Mode 18 for example, maybe up to Mode 22. If you see that this can completely prevent BSODs, that could confirm the degradation. But of course it's bad to set it up like this, because instead of lowering the mode to make the CPU run more efficiently, you raise the mode and it gets even more out of hand. Your 200W power limits will prevent overheating, but you're sacrificing performance, because at higher voltages per frequency, the CPU will now hit the limits sooner.
So if all the above turns out true and your CPU only gains full stability at crazy high CPU Lite Load modes, then i would actually start an RMA of the CPU with Intel. Your only other option would be to lower the multipliers by a couple steps, so the CPU doesn't boost so high anymore, or to live with the downsides from having to raise the mode. But essentially, it won't be the same CPU anymore that you paid full price for, so i would most likely try to RMA it.
Good afternoon, thank you for your reply. (I'll try to explain how it was).
I upgraded a couple months ago, and immediately updated the bios (well that's how it's usually done).
I played in the evenings from time to time (I understand at these times and sometimes overheating occurred).
Only in one game sometimes there was BSOD (this game pubg), in other games at maximum settings such a problem was not (for example, demanding DOOM Eternal).
Then I got tired that pubg sometimes crashes with blue screen and I started to understand, at first I started AIDA test and saw 1-2% Throttling at full load and at first I didn't give it any importance, as I didn't really dive into it and understand, initially I thought it was because I set XMP profile 6000Mhz, then I removed it, but the problem didn't change, I still had a BSOD and not at the moment of game play, but in transitions-switching from game to lobby for example, or from lobby to game, but not in the process itself where usually the maximum load.
Then I still returned to the load test and once again saw 1-2% Throttling and started digging in the direction of the processor, found this forum and realized that the default settings were not quite right.
Then I started to use CINEBENCH R23 and HWM and pick up my configuration as described and came to the conclusion that when the tests are all OK in terms of temperature and set some value of CPU Lite Load below 16, the game does not start at all and immediately crashes with BSOD, but if I set - (“13900K/14900K should have 188W Short / 125W Long / 249A Current limit for the Baseline”) - then everything is fine and the temperature and the game does not crash, but only the performance in CINEBENCH R23 drops perhaps that just cooling can not cope, can we allow this option? or for what reason the game at the moment of start does not like other values of CPU Lite Load if I use them.
My config :
9-14900K on MPG-Z790-CARBON-WIFI (BIOS v. 7D89v1E date 2024-10-08 0x12B)
Cooler be quiet! Dark Rock Pro 4 (TDP 250w)
Corsair Dominator Titanium DDR5 64 Gb (6600 MHz) Memory (Kit 32 Gb x 2)
Corsair HH1000i power supply
GPU: GTX 1070 ((
And it turns out that if I tested and use CPU Lite Load as written here on the forum with a non-standard value, then BSOD occurs immediately when starting the game.
If the standard with CPU Lite Load it works, sometimes overheating occurs and the game crashes in BSOD (and not in the process of the game but in transitions-loads in the lobby from the lobby).
If I set “intel default settings” 13900K/14900K should have 188W Short / 125W Long / 249A Current limit for the Baseline profile then everything works but according to CINEBENCH R23 test results are less than when using Normal.
Is it possible to assume that nothing has degraded yet and just lacks cooling and that the game does not like CPU Lite Load with non-standard value for some reason?
If you set the conservative Intel default power/current limits of 188W/125W/249A, on your 14900K which natively wants to go way above that, then in order for the CPU to observe those limits, it cannot clock as high anymore. So, automatically, you will lose performance in Cinebench from this, because the CPU wants to stay below those limits that are set for it.
But also, remember what i wrote about the two methods of gaining stability, lower frequencies and/or higher voltages? Well, with those limits, you are indirectly restricting the boost frequencies, since the CPU would exceed the limits when boosting too high. So you have sacrificed performance in exchange for stability.
So, there is nothing here that contradicts the "CPU degradation" assumption. What you should do now, test what happens with an even higher mode for CPU Lite Load, if you can completely prevent any BSODs with that, which would prove to some degree that there is already true degradation. But set the limits to 200W/200W/307A for this, otherwise the too low power/current limits will prevent instability and limit performance.
Your cooler is actually better than i thought, even though the TDP is overstated (typical, they always state 20-50W too high, because they test under lab conditions). Maybe the airflow through the case is not ideal yet, what's your case and your cooling situation? Do you have a photo? On the other hand, 200W is quite something to deal with for an air cooler. Normally, for a 14900K, you'd want an absolute high-end air cooler (like be quiet! Dark Rock Elite) or a nice 360mm AIO. But you could work with this cooler, as long as the CPU is not degraded...
The GeForce 1070 is a bit of an odd one for this system, are you waiting on the 5070 or something? Doesn't really match up well at the moment.
Thanks, yes, that 1070 video card is left over from an old build and probably waiting for prices to drop on the 50x series)))
Right now the build looks like this, front 120 cooler, back 120 and two in the cooler and power supply, is this not enough for this build?
I just did a test with 200W/200W/307A and CPU Lite Load AUTO is 16.
Is there any sense to overestimate CPU Lite Load if there is already overheating up to 100% at 16, it will not spoil anything?
here is the result of the test (it is not very good in terms of temperature, is it?):
and here is the result after playing for 15 minutes, nothing has crashed yet, but this is not an indicator, just need to play longer, but it at least started without BSOD:
But if I reduce or set another value of CPU Lite Load below 16, the game does not start with BSOD...
Makes sense.
Holy smokes, that is an oldschool case, why haven't you gotten a new case for this system? This case hardly has any airflow, that case concept is from 25, 30 years ago!
Nowadays the modern concept is completely different, like this, a direct airflow path from front to back without drive cages, cables etc. in the way, and a lot more free space. You can't just put a 14900K into a case from several decades ago... when that case was available, the reviewers complained about the excessive power draw of a Pentium 4, which at the time was getting up to 80W or so, they are complaining that it's too difficult for normal end users to get rid of that much heat. And now you come with the 14900K, the most inefficient and power-hungry CPU ever, more or less...
So i would get a nice new case for this system. At the latest, when you want to use a modern graphics card in there, then this old case would be completely out of its element. You want a better airflow concept, less stuff in the way, more space.
Why HWmonitor? Use HWinfo, it's better (see the first post for the link and how to set it up).
But don't worry, the power limits (or thermal throttling, if necessary) will prevent the worst, even if you set Mode 20 or so for a test.
