Guide: How to set good power limits in the BIOS and reduce the CPU power draw
Pro
By now, and not only since threads like these, many Intel users will have heard (or have found out) that a lot of Intel CPUs have a very high power draw that can really push the CPU cooling capabilities to the limit and beyond. There used to be a time where a cheap tower air cooler would be enough for any CPU available for that socket. That era pretty much ended with the i9-9900K, the first "monster", and then from 10th gen onward, Intel really started pushing the higher-up CPU models to the absolute edge. Causing higher and higher power draw, which has now gotten ridiculously high with the 14th generation like the 14900K.
Note that Intel also recommend certain power limits for different CPU models, but those are more or less arbitrary, they have nothing to do with your individual cooling capabilities. One thing i would say, there is no benefit in allowing more than ~250W for any CPU, not even a 14900KS. Because it will always make the CPU run more inefficiently from that point onward (at the very latest, for other CPU models even earlier). That's then "junk power draw" or "junk performance", meaning the power draw still keeps increasing a lot, but only for minimal performance gains, it basically just ruins the efficiency. So even with a high-end 360mm AIO, you will not tend to see me recommending limits higher than 253W.
Check the performance too:
Yes, because it is needlessly fighting the outcome of undervolting. By lowering the voltage, you are trying to do the best thing you can do to the way a CPU operates (as long as it stays stable), and IA CEP is working against it because it detects a deviation from a narrow "normal" range it tries to uphold. But we are know that lowering the voltage is not dangerous (quite the opposite), so we should not let IA CEP interfere in this instance. Furthermore, using an updated BIOS with the fixed Intel microcode will prevent the voltage spikes that can cause CPU degradation, so that's already the main line of defence. The recommendation to keep IA CEP enabled comes from a time way before BIOS updates with this new microcode were available, plus it was meant for default BIOS settings, not for hand-optimized settings. Here is more circumstantial evidence that disabling IA CEP should not cause the current to go crazy. So when you see the performance going down the drain when lowering "CPU Lite Load" below Mode 10 or so, simply set IA CEP Support to [Disabled], nothing bad will happen.
What to do when the option "IA CEP" is not available, for example on B660?
Let's recap: If IA CEP is available and there's a severe performance drop (e.g. Cinebench score cut in half) when lowering the CPU Lite Load mode below a certain point, then IA CEP has to be disabled, simple as that. But on some boards, like most B-series chipset boards (B660, B760), IA CEP is not available as an option. What then?
There's two possibilities:
1) Performance stays the same when you lower CPU Lite Load (which is what you want, but usually only happens on Z-series boards where IA CEP is not available as a setting), or:
2) Performance drops off a cliff once you lower CPU Lite Load significantly enough (which is bad, and would be the case on most B-series chipset boards).
In other words, on a B-series board, where the setting is not available or ineffective, that severely limits the undervolting capabilities. So in that case, if the option is not available and you notice a performance drop below a certain mode, you either have to use the lowest CPU Lite Load mode that still keeps the full performance (often around Mode 9 or 10), or you have to use a more sophisticated undervolting method that tries to "dance around" IA CEP becoming active, using a combination of different settings. But that is quite complicated, and sadly, the bottom line is, with a B-series chipset board it's very difficult to achieve a similar undervolting result as with a Z-series board. No matter the undervolting method, at some point, IA CEP will "bite".
Note that this method is "officially recommended" by MSI now, see
this blog entry!
For the Z890 boards with Core Ultra, due to the many architectural changes in Core Ultra, i cannot promise the same results, especially since the power draw reading in HWinfo (CPU Package Power) can be inaccurate due to the way Core Ultra is designed. It can be "calculated wrongly" depending on some other settings. So for now, i can only guarantee proper results up to 14th gen. I've used this CPU Lite Load setting all the way back from my old 9600K, across generations in between, and up to my current 13th gen, it's always the same procedure to optimize it.
My other guides:
Guide: How to find a good PSU
The following is for geeks only, others can stop reading :)
In CPU Lite Load Advanced, you can select values for AC and DC Loadline separately, without having some preset combination which can have the wrong DC Loadline value. So now you can set the DC Loadline so it results in the correct power draw numbers. Doing that involves using HWinfo Sensors, creating full CPU load, then looking at the CPU's VID requests (in the "current values" column), which is the voltage the CPU asks for from the board, and comparing it to the current VCore value (note that i don't mean current as in Amperes, i mean current as in, actual live values, not Min/Max/Avg). If those are near-identical, the correct DC Loadline value has been found. The correct DC Loadline value depends on the LLC mode, another setting which influences the voltage (and not to be confused with CPU Lite Load / CLL, completely different). A table of the AC/DC loadline values is here, but it's only a rough one, because each board model is built differently and would also need a bit different values, presumably.
However, this last step doesn't quite pan out in my ow testing on a PC I was building for someone. Because even if i set CPU Lite Load "Advanced" AC Loadline to 1 (the lowest possible value) and select a mild LLC setting like Mode 7 (where the VDroop is still relatively big), i can't get anywhere near the low voltages and low power draw under full load that i can reach with just a lowered CPU Lite Load mode and keeping LLC on Auto. I'm talking a coupled dozen Watts difference here under full load, measured at the wall. In other words, lowered CPU Lite Load with LLC on Auto results in the lowest possible VCore and power draw under full load (while staying stable) in my testing, which is arguable one of the most important scenarios for which to keep the power draw low (to avoid cooling problems and improve the CPU's efficiency).
The board makers are historically mostly interested in performance, not efficiency or really caring about the temperatures. In the past, the three presets have been even worse, with the middle option already setting way too high power limits, which does nothing to ensure safe temperatures for most people. So you can have a profile that's too limiting (this is what OEMs use, making PCs for companies, where they strictly adhere to Intel's baseline power limit recommendations, so they can use appropriate coolers and don't have to use expensive cooling solutions), then a profile that's already too much perhaps, and then the maxed out profile. Other board makers have more fine-grained power limit presets(*) now, but still, the best way is to do it manually, like step 1) of the guide.
The board makers historically set PL1 (the long power limit) equal to PL2 (the short limit), so the performance would be kept high indefinitely (but with it the power draw). Since Alder Lake, Intel basically said PL1 = PL2 as well, because they now set the PBP = Processor Base Power (ex-TDP) and MTP = Maximum Turbo Power to identical values. For example, 12600K had 150W, 12700K had 190W, 12900K had 241W. Then, in the wake of the voltage spike issue (when they still had no idea what was causing the CPU degradation), Intel released one set of recommendations for BIOS defaults, aimed at board makers (but also somewhat at end users), later superseded by a second set of recommendations (some of which are already obsolete). But those also included power limits, with some different values noted for PL1/PL2 again. So Intel tried to clamp down a bit more on the board makers for the first time, suggesting their laissez-faire approach was part of the degradation problem (it turned out to be bugs in the Intel microcode, oops). But for sure, the board makers' very generous defaults were generally not a very good idea.
The problem now is, Intel seems to have gone back to not caring much about what the board makers set in their BIOS, and it's up to the end users to find good settings that make their CPUs behave a bit better. I'm doing my best to help people with this guide, i know it's not perfect, i know it can be a bit overwhelming for inexperienced users. It's unfortunate that so much tweaking and testing is involved to make a CPU run well. But this is the price we have to pay for chasing higher and higher performance, i guess, as Intel were resting on their laurels for too long without any meaningful innovation in CPU design. Apart from the hybrid design (P- and E-cores) with 12th gen, but otherwise mostly relying on pushing the frequencies higher and higher. Well, Core Ultra was a first step in the right direction, but it's not exactly selling like hot cakes, so they have to come up with something better.
You can try disabling that if gaming is the main thing for you, but usually it won't make that big of an improvement, and you can obviously lose performance and efficiency in some other workloads besides gaming. So personally i wouldn't do it.
Thank you very much! One last question: I ended up choosing CPU Lite load mode 9 and disabling IA CEP; will test for stability in my games but am I safe with that mode and having IA CEP disabled? (safe as in, can I damage my CPU with those settings?). Also, what would be a safe vcore value for my 13700k? Because sometimes I see it a little higher than 1.4V. Lastly, what would be signs of instability? And if I experience those, is it safe for my CPU?
Thanks in advance!
You can probably lower it even more, but you have to test the stability indeed, and it's best to use special CPU stress tests for this, such as OCCT. Gaming will not really produce enough stress for the CPU, it's of course fully stressing the GPU, but for the CPU, you can only see if it crashes or not. Whereas a CPU stress test will check the calculation results continuously and report any small error right away.
There is no danger from this, on the contrary: Lowering the voltages is the best thing you can do for your CPU, pretty much. For an i7/i9, you will see quite high VCore sometimes, that's just how the cookie crumbles when it has to run at such high frequencies. Just try to lower it as much as you can using that method, until you find the first hint of instability. The lowest fully stable mode you find, i would then add another step for the mode, to not be on the edge of stability. Any error in any stress test like OCCT, Prime95 Torture Test or whatever else, and it's not fully stable anymore. As well as obviously any type of crash, BSOD, or unusual behavior.
If you do step 2) properly, you will lower the mode enough to experience the first instability, this has to be done to know how far you can lower the mode. This is not dangerous for your CPU whatsoever, and nothing should happen to the Windows installation either. Going at it slowly, step by step lower, ensures that the instability will not be severe. Plus you can raise the mode right away again. The instability with too low of a voltage is normal, but that instability is the only risk, and it's of course temporary as you would raise the mode shortly thereafter.
Then however, once you found the lowest fully stable mode and added an extra step for stability headroom, you can truly enjoy the ideal circumstances for your CPU: It will now use the reasonably lowest voltages, so it will use less power, stay cooler, become more efficient, and have at least the same performance (if not even becoming a bit faster if it's hitting the power limits).
Think about doing this with your car's engine, if you could lower the fuel consumption this easily (or with an EV, lower the energy consumption), while keeping the same acceleration and performance, without downsides for longevity (on the contrary), it would be an absolute no-brainer! You just have to find out where you have to stop lowering before the engine starts to stutter.
Yes I know, but having the MOBO makers set a 1.7mOhm load line spec as default is completely irrational from this perspective. Like I said.. this is intended per data sheets and laptops using a similar core config. PL1=PL2 isn't default.. Which completely skews how much heat this thing will put out and why I'm essentially questioning the logic of what intel allows and doesn't allow. It should have been a wake up call to require an Intel "DEFAULT" setting. 2nd setting could be "Intel performance" for example.. Just replacing "MSI's performance" pre load spec.
There seems to be relevance to ICCMAX with these setting as even MSI hasn't bothered to updated the "unlimited profile "since it goes below default 1.1mOhm on 129K.
Don't forget, they were originally blaming US factory oxidation. It's clear that they didn't understand the root issue in the beginning, which is completely mind boggling to me.
I'm partial to agree that the main degradation issue stems from a spike of power across the 12/16 e-core parts as these are the Raptor SKU's that are most impacted. (High clocks also a concern) Intel's solution seems to be pushing a 1.55~v cap and allowing more power so stuff doesn't crash.
I can't recall seeing a 14600K or 13600K having an issue on older BIOS' with a more optimized default load line. > 1.1
On the bright side, I checked warranty per SN and it's 5 years for new purchases. So any new raptor carries that "insurance policy"
Edit: had some time and pop'd the CPU into an ASUS board. Seems to read 1.1 by default.. So I'll assume this is an MSI thing.
Hello, good morning.
I wanted to ask if the latest BIOS update 7D91vHH for the Tomahawk Z790 motherboard already includes the Intel uCode 0x12F microcode.
Well yeah, the board makers set that stuff relatively freely, depending on what they want to prioritize, stability at the cost of efficiency or vice versa. Not saying it automatically becomes unstable if they were to set lower default values for MSI, because in the past, with lower defaults, it worked perfectly fine for almost everyone. And as we see in this thread, healthy CPUs can have huge undervolting headroom. But when it comes to already degraded CPUs, those can benefit from higher added voltage to regain some stability. It's just that they shouldn't take those as the yardstick for the defaults, they should think more of the users with healthy CPUs, and don't go so high with the defaults.
Yes, of course. See the changelogs: You see in the previous beta version vHH1, it was added. So in the stable version vHH(0) that follows (this is the unusual MSI numbering), those previous changes are also included.
Decided to pop the 146K back into the MSI board today. (Z690 Tomahawk). Soo..... If you default the board to factory and set the 512A "unlimited profile", AC/DC LL will default to 0.5/0.8!!
Essentially proves AC/DC LL is relevant to ICCMAX setting.. It just seems MSI got lazy with the 400A performance profile since it defaults 1.7mOhm (THIS IS BAD). ASUS Z690 TUF is 1.1 with similar 400A setting. (387A, cant exactly change unless you set it manually).
Yes, that indirectly means the the MSI "unlimited profile" is safer as far as max voltages go.. and runs inevitably cooler. Peaks low 1.4~ VCORE around 1.3V Similar to a 12900K with .8/.8.
If you run this board/cpu with intel default or MSI performance, you're basically killing the CPU (ironic). VCORE hovers 1.42+v with 1.5v+ peaks. Completely inverted.
I assume these boards were all designed around a .8 LL threshold factoring 512A and Intel told them to default. At least thats what I'm gathering. Forced mode 9 (.80/.80) with a 400A max. I'll be content if this doesn't have any performance issues long term.
Interesting find. But luckily, if people go by this guide, they don't need to worry about the defaults, they can set something optimized specifically for their CPU. Someone said before, the board makers should implement a semi-automated optimization process with the help of some Windows tool, to help users find out proper settings for the power limits which fit well for their cooling, and voltages which fit well for the silicon quality of their CPU. You know, they could semi-automate overclocking in the past - Intel's XTU anyone? Straight from the source - but nobody's designed something like that for efficiency optimization. Of course we won't see such a thing anytime soon (if ever), but wouldn't that be nice. No more silly defaults which are not a good fit most of the time. For now, people will have to put up with some manual labor, but it's worth it.
I'm in a rather strange situation.
When I run tests in Prime95 with Corsair's iCUE software open, the CPU stress test crashes my PC as soon as it starts.
When the software is closed during the test, I don't experience any crashes, and I can run Prime95 for 30 minutes without any problems.
I tried changing the CPU Lite Load mode from 3 to 4, but it still crashes right at the beginning when iCUE is open. However, when it's not active, the test runs perfectly without any errors in modes 3 and 4.
Is this more of a software compatibility issue, or should I be worried about my processor?
I should mention that Cinebench R23 and 2024, on the other hand, work perfectly every time with iCUE open.
I have an Intel 14900k processor.
My motherboard is an MSI Z790 Carbon Max WiFi II.
Corsair DDR5 6400MHz CL32 64GB RAM (32x2)
Power Limit 1: 253W
Power Limit 2: 253W
CPU Current Limit (A): 307 and 350A (I tested both; the test works perfectly under both (A) limits without iCUE, but it crashes when it's open)).
CPU Light Load Mode: 3 and 4
AI CEP disabled
Power Limit 1: 253W
Power Limit 2: 253W
AI CEP disabled
I can't say for sure, but your problem looks like it's caused by iCUE. It's not the first time I've seen iCUE cause problems.
Hello folks,
I'm new here, i am using 17400K - MSI Z690-Pro DDR4 - Thermalright frozen warframe 360 - CORSAIR VENGEANCE RGB PRO 3600CL18 16GBx2
I read somewhere that undervolt right way will get better performance and better latency. I only gaming (CS2-Valorant).
So which PL1-PL2-IccMax-LLC-CPU Lite Load i should confirgure here
Do I need to turn off Hyper-Threading, turn off Intel Turbo Boost Max Technology 3.0 and disable IA CEP support/IA CEP support for 14th
Thanks
You simply can go by the guide, it will explain it step by step. Your CPU should be the 14700K, and with a 360mm AIO, your power limits will be anywhere between 200-250W, while still having good temperatures under full load with Cinebench, and IccMax of 307A. That's a good starting point. HT you can leave on, Turbo Boost Max and IA CEP Support you can turn off (the latter basically must be turned off for step 2 of the guide).
these values seem OK with my spec. I also have 12700K and using same mobo and AIO , what values should I put for this.
Depends on your temperatures in the Cinebench test as per step 1). Again somewhere between 200-250W should be good, 307A, and then you can go to step 2) and start lowering the mode for CPU Lite Load while checking the stability. Once you have found the first unstable mode, go back up by one step and re-test, and if it's fully stable again, go back up by one more step to have some stability headroom, and that will be your final setting for this.
Hello, good afternoon. I have a question that I haven't been able to answer by searching online or asking artificial intelligence. When you update the BIOS and the Intel Management Engine is also updated, you then have to install the Management Engine Software on Windows 11. My question is, does this software affect the processor's voltage in any way?
No, has nothing to do with any voltages. You also don't have to install the full ME software, it's enough to update the driver. You get the latest from here:
(usually either one of the top entries with the latest date).
You can extract the CAB file, then update via device manager, system devices, Intel Management Engine Interface, update driver. Or installing the CAB file should also do the trick.
Okay, thanks. Doesn't the installer provided by Intel automatically select the version installed in the BIOS? The IMEI versions listed on motherboard manufacturers' websites are quite outdated.
No, the versions for the ME firmware in the BIOS and the ME driver in Windows are different. The Windows ME drivers each support a range of different major ME firmware versions. For example, you can't install the latest ME drivers when your board's ME firmware is too old (like 11.xxx), but you can easily install them on several of the most recent generations with ME firmware 16.xxx and such. For a board using an older ME FW, you would use older ME drivers which still supported it, but then they also updated the drivers a bunch of times within those older versions, if that makes sense. I know, it gets a bit complicated.
Anyway, having a recent enough ME FW is the most important. Having the very latest ME drivers isn't that important in comparison. And the board makers don't put a high priority on always listing the latest ones, plus they tend to list the full ME software which most people don't even need. They would be ok with just the bare driver, which is a couple hundred KB instead of couple hundred MB.
I currently have the Z790 Tomahawk motherboard with the latest BIOS version installed, and I understand that the ME firmware will also be updated. The thing is, I installed the driver from Intel's website and not the one provided by MSI. Everything works fine, but according to you, it's probably not the best option. Should I uninstall it and reinstall the one provided by MSI?
No, you misunderstood. I said that the board makers - like MSI, ASUS etc. - will often not update the ME driver they have on their website that frequently, and they tend to offer the entire ME software which most people don't need. The link I gave a couple posts above this is from the Microsoft Update Catalog, which tends to list the latest ME driver (and just the driver) that is publicly available. So that is the one you want to install, with the method I mentioned. Then you don't need the driver that MSI list. In fact, if you installed their full ME software (couple hundred MB large), you can uninstall that first, and then just install the small driver from the Microsoft site.
Okay, thanks. I'll save the link in my browser along with the version I have installed in case there are future updates. I don't really know what the benefit of this driver is, but I have five other production MSI computers that don't have it installed and they work fine. All I'm interested in is whether this driver provides overall system stability. Thank you.
