Guide: How to set good power limits in the BIOS and reduce the CPU power draw
Pro
By now, and not only since threads like these, many Intel users will have heard (or have found out) that a lot of Intel CPUs have a very high power draw that can really push the CPU cooling capabilities to the limit and beyond. There used to be a time where a cheap tower air cooler would be enough for any CPU available for that socket. That era pretty much ended with the i9-9900K, the first "monster", and then from 10th gen onward, Intel really started pushing the higher-up CPU models to the absolute edge. Causing higher and higher power draw, which has now gotten ridiculously high with the 14th generation like the 14900K.
Note that Intel also recommend certain power limits for different CPU models, but those are more or less arbitrary, they have nothing to do with your individual cooling capabilities. One thing i would say, there is no benefit in allowing more than ~250W for any CPU, not even a 14900KS. Because it will always make the CPU run more inefficiently from that point onward (at the very latest, for other CPU models even earlier). That's then "junk power draw" or "junk performance", meaning the power draw still keeps increasing a lot, but only for minimal performance gains, it basically just ruins the efficiency. So even with a high-end 360mm AIO, you will not tend to see me recommending limits higher than 253W.
Check the performance too:
Yes, because it is needlessly fighting the outcome of undervolting. By lowering the voltage, you are trying to do the best thing you can do to the way a CPU operates (as long as it stays stable), and IA CEP is working against it because it detects a deviation from a narrow "normal" range it tries to uphold. But we are know that lowering the voltage is not dangerous (quite the opposite), so we should not let IA CEP interfere in this instance. Furthermore, using an updated BIOS with the fixed Intel microcode will prevent the voltage spikes that can cause CPU degradation, so that's already the main line of defence. The recommendation to keep IA CEP enabled comes from a time way before BIOS updates with this new microcode were available, plus it was meant for default BIOS settings, not for hand-optimized settings. Here is more circumstantial evidence that disabling IA CEP should not cause the current to go crazy. So when you see the performance going down the drain when lowering "CPU Lite Load" below Mode 10 or so, simply set IA CEP Support to [Disabled], nothing bad will happen.
What to do when the option "IA CEP" is not available, for example on B660?
Let's recap: If IA CEP is available and there's a severe performance drop (e.g. Cinebench score cut in half) when lowering the CPU Lite Load mode below a certain point, then IA CEP has to be disabled, simple as that. But on some boards, like most B-series chipset boards (B660, B760), IA CEP is not available as an option. What then?
There's two possibilities:
1) Performance stays the same when you lower CPU Lite Load (which is what you want, but usually only happens on Z-series boards where IA CEP is not available as a setting), or:
2) Performance drops off a cliff once you lower CPU Lite Load significantly enough (which is bad, and would be the case on most B-series chipset boards).
In other words, on a B-series board, where the setting is not available or ineffective, that severely limits the undervolting capabilities. So in that case, if the option is not available and you notice a performance drop below a certain mode, you either have to use the lowest CPU Lite Load mode that still keeps the full performance (often around Mode 9 or 10), or you have to use a more sophisticated undervolting method that tries to "dance around" IA CEP becoming active, using a combination of different settings. But that is quite complicated, and sadly, the bottom line is, with a B-series chipset board it's very difficult to achieve a similar undervolting result as with a Z-series board. No matter the undervolting method, at some point, IA CEP will "bite".
Note that this method is "officially recommended" by MSI now, see
this blog entry!
For the Z890 boards with Core Ultra, due to the many architectural changes in Core Ultra, i cannot promise the same results, especially since the power draw reading in HWinfo (CPU Package Power) can be inaccurate due to the way Core Ultra is designed. It can be "calculated wrongly" depending on some other settings. So for now, i can only guarantee proper results up to 14th gen. I've used this CPU Lite Load setting all the way back from my old 9600K, across generations in between, and up to my current 13th gen, it's always the same procedure to optimize it.
My other guides:
Guide: How to find a good PSU
The following is for geeks only, others can stop reading :)
In CPU Lite Load Advanced, you can select values for AC and DC Loadline separately, without having some preset combination which can have the wrong DC Loadline value. So now you can set the DC Loadline so it results in the correct power draw numbers. Doing that involves using HWinfo Sensors, creating full CPU load, then looking at the CPU's VID requests (in the "current values" column), which is the voltage the CPU asks for from the board, and comparing it to the current VCore value (note that i don't mean current as in Amperes, i mean current as in, actual live values, not Min/Max/Avg). If those are near-identical, the correct DC Loadline value has been found. The correct DC Loadline value depends on the LLC mode, another setting which influences the voltage (and not to be confused with CPU Lite Load / CLL, completely different). A table of the AC/DC loadline values is here, but it's only a rough one, because each board model is built differently and would also need a bit different values, presumably.
However, this last step doesn't quite pan out in my ow testing on a PC I was building for someone. Because even if i set CPU Lite Load "Advanced" AC Loadline to 1 (the lowest possible value) and select a mild LLC setting like Mode 7 (where the VDroop is still relatively big), i can't get anywhere near the low voltages and low power draw under full load that i can reach with just a lowered CPU Lite Load mode and keeping LLC on Auto. I'm talking a coupled dozen Watts difference here under full load, measured at the wall. In other words, lowered CPU Lite Load with LLC on Auto results in the lowest possible VCore and power draw under full load (while staying stable) in my testing, which is arguable one of the most important scenarios for which to keep the power draw low (to avoid cooling problems and improve the CPU's efficiency).
Yes, the PC will run fine of course, usually Windows Update might install some old ME driver or something. It's not like it will still have a question mark in the device driver, so you know there's some generic driver installed for it. It's like when you do a fresh install of Windows and don't bother to install any drivers, not even the chipset drivers, graphics drivers or anything. The device manager will be full of generic names and question marks with unknown devices. Sure, Windows Update installs a couple quite outdated drivers for the graphics card for example, but Windows still might not be able to set up the power-saving states properly for everything, so the power draw might be higher, you have bugs in the old drivers and whatnot. On the surface, such an installation still runs fine, but running fine and running optimally are not nearly the same.
Updating/installing the ME driver probably doesn't do much most of the time, certainly nothing that makes you feel a difference during use, but the ME itself is quite a powerful low-level subsystem on Intel platforms, so it also can't be completely neglected. But as long as you do BIOS updates every once in a while to also get the latest ME FW, that's the more important part.
Respected citay. Perhaps you could share your thoughts on how to properly configure 15th generation processors in the BIOS on Z890 boards. Of course, without any guarantees, but it would be interesting.
There is not really a 15th gen, Intel refer to it as Core Ultra, they wanted to stop with the generation naming. The problem with Core Ultra is, I don't have one, nor have access to one, and from the posts here on the forum, "CPU Lite Load" works a bit differently there.
There's threads like these and these which dive into Core Ultra undervolting, but with not that many users to gather data from, it's difficult to distill a good method that works well for everyone. So at the moment, this guide is primarily for 9th-14th gen. With Core Ultra, they have changed so much about the architecture, no wonder they don't simply call it 15th gen, it behaves differently, it's not always the usual behavior we have known for many years from Intel CPUs.
I don't plan on getting a Core Ultra soon, certainly not at this time, because I would need a new DDR5 kit for it, and prices are crazy, looks like they will stay this way too. As soon as I have gathered enough knowledge, I will be sure to include something, but at the moment, I cannot help that much.
I mean, I could give some general hints that apply to any system, for example under Settings\Advanced\Power, I always set ErP Ready to Enabled, or under Settings\Boot, I set all Fast Boot options to Disabled, and of course there's my fan curves guide, but stuff like that doesn't optimize the CPU. For this I don't have enough information at the moment.
1. How to disable IA CEP in B660M Mortar DDR4 (I5-13600K) ?
I just modified the guide with some new wording that should clear it up better:
2. If i Flash newest bios Can I disable IA CEP in B660M Mortar DDR4 (I5-13600K) ?
No, it's basically a chipset limitation, imposed by Intel. For any significant under- or over-anything (undervolting, overclocking...), they want you to buy a Z-series chipset board.
But you should use the latest BIOS version anyway, since you have a true 13th gen CPU. This should not be run on an older BIOS version (unless you're just one or two versions behind).
Anyway how can i undervolt ?
My I5-13600K eating more voltage (1.3V++)
I need to drop voltage to reduce temperature without performance loss
Previously
1. Use cpu lite load and load line calibration temperature reduce but performance loss
2. Use cpu core voltage offset go under -0.030 V system not stable at all
B660M Mortar DDR4 (7D42v1E)
Well, you can undervolt slightly, only lowering CPU Lite Load to mode 9 or 10. That's about it. You will have to check in Cinebench when the performance loss becomes drastic, usually it's right below that mark. Also see the results from here. Any other undervolting method you try, you will also find similar difficulty. On the B-series boards it's like that, unfortunately.
i am still looking for optimized settings with my 14700K and MSI Z690 Pro DDR4 and latest BIOS
i tried 250-250-307A or 400A and CPU Lite Load to Mode 9 (with HT on) and the temp too high >90 celsius
If temperatures are too high, you first have to do step 1) properly, setting good power limits. Just limiting the current in Amps is not enough, it's too imprecise. Your cooler has a certain amount of Watts worth of heat it can get rid of before temperatures become too high. You have to find this number with some Cinebench testing and set it for the power limits in Watts. This number will not change much anymore, unless you improve your cooling or the ambient temperature changes.
Then you can go to step 2) properly, and see how low of a mode your CPU is still stable at (with one more step of added headroom). Unless you already found that it becomes unstable at Mode 7 for example. Then you can stay at Mode 9. But set the power limits well for your cooling.
@citay
Okay what i did. I put PL1=PL2=200W, IccMax 307A, CEP disabled, HT on and CPU Lite Load 7, can't go lower due to Cinebench/OCCT crash
The temp around 85-90 celsius even i am using thermalright 360 frozen warframe
Can you show a HWinfo screenshot with the sensors expanded via <-> arrows? Let's see what's going on. Because a 360mm AIO should be able to deal with over 200W already.
If Mode 7 is unstable, and Mode 8 is the first stable one, yeah, you should use Mode 9.
That's the HWinfo screen I usually get, but that's why I always say, use the <-> arrows on the bottom left to expand the sensors. 😉
I need to see everything in one maximized window, it should look like this:
The Cinebench screenshot is not necessary, just the score as a number is enough.
Yes, that's the proper layout, but I need to see it after Cinebench. On that screenshot, CPU Package Power only went up to 65W, I need to see what happens around 200W. And also, you can expand the sensors of the SSDs, where it shows their temperatures. The more temperatures I can observe, the better.
Ok. But that's perfectly fine. At 250W limits (there's always a bit of overshoot of actual power draw), your cooling reaches its limit, which is normal for such an AIO. If you set the limits at 220W or so, it should stay below 90°C. Or you could set 220W Short, 200W Long limit. But it's normal that a 360mm AIO can get into trouble around 250W. What's the ambient temperature in your room?
Hi @citay , I tried 200W/220W and ICCMax 400A with CPU Lite Load 9, seem it stay below 80°C while cinebench. I also cap lA VR Limit at 1450.
My room always around 26-35°C .
Do I need to make change with the CPU Core Voltage Mode (Offset negative or Offset + Adaptive
You could even go 240->220W then. But:
This is very warm. So whatever your room temperature is now, compared to the hottest it can possibly get, you have to add that in your head too, because that's how much the CPU temperatures would also rise. But still, you will probably stay below 90°C. So in the end it's all good. You can leave the limits like they are, or set 220W for both, or 220 Long / 240 Short. But even performance-wise, it won't make such a big difference anymore. As long as you can let the 14700K get to ~200W, you will get most of its performance already.
Stability testing becomes more complicated then. It's enough to just lower CPU Lite Load, that's the easiest to test, because it has the highest impact for the highest CPU load. If you used VCore offset undervolting before, and now want to just lower CPU Lite Load, if you set VCore all back to Auto, you might be able to lower the mode for CPU Lite Load by another step, potentially. But test it properly with OCCT, Prime95 etc. As soon as you get instability, test the next higher mode, and if that is stable, add one more step for headroom.
Flash newest bios already. I use Intel Default profile (181w) Cpu lite load auto (Mode 18) temp is under 90°C
But my cpu not running At 5.1Ghz (Runing At 4.7Ghz) under heavy load.
How can i made my cpu running at 5.1Ghz ?
