Guide: How to set good power limits in the BIOS and reduce the CPU power draw
Pro
By now, and not only since threads like these, many Intel users will have heard (or have found out) that a lot of Intel CPUs have a very high power draw that can really push the CPU cooling capabilities to the limit and beyond. There used to be a time where a cheap tower air cooler would be enough for any CPU available for that socket. That era pretty much ended with the i9-9900K, the first "monster", and then from 10th gen onwards, Intel really started pushing the higher-up CPU models to the absolute edge. Causing higher and higher power draw, which has now gotten ridiculously high with the 14th generation like the 14900K.
Note that Intel also recommend certain power limits for different CPU models, but those are more or less arbitrary, they have nothing to do with your individual cooling capabilities. One thing i would say, there is no benefit in allowing more than ~250W for any CPU, not even a 14900KS. Because it will always make the CPU run more inefficiently from that point onwards (at the very latest, for other CPU models even earlier). That's then "junk power draw" or "junk performance", meaning the power draw still keeps increasing a lot, but only for minimal performance gains, it basically just ruins the efficiency. So even with a high-end 360mm AIO, you will not tend to see me recommending limits higher than 253W.
Check the performance too:
Yes, because it is needlessly fighting the outcome of undervolting. By lowering the voltage, you are trying to do the best thing you can do to the way a CPU operates (as long as it stays stable), and IA CEP is working against it because it detects a deviation from a narrow "normal" range it tries to uphold. But we are know that lowering the voltage is not dangerous (quite the opposite), so we should not let IA CEP interfere in this instance. Furthermore, using an updated BIOS with the fixed Intel microcode will prevent the voltage spikes that can cause CPU degradation, so that's already the main line of defense. The recommendation to keep IA CEP enabled comes from a time way before BIOS updates with this new microcode were available, plus it was meant for default BIOS settings, not for hand-optimized settings. Here is more circumstantial evidence that disabling IA CEP should not cause the current to go crazy. So when you see the performance going down the drain when lowering "CPU Lite Load" below Mode 10 or so, simply set IA CEP Support to [Disabled], nothing bad will happen.
What to do when the option "IA CEP" is not available?
We know now, if IA CEP is available and you notice a severe performance drop (for example Cinebench score getting lower), then it has to be disabled, simple as that.
But what if IA CEP is not available as an option on your board? Then there's two possibilities, which you can't influence:
1) Performance stays the same when you lower CPU Lite Load (which is what you want, and is the case with my configuration), or:
2) Performance drops off a cliff once you lower CPU Lite Load enough, or otherwise try to lower the core voltage (bad, this would severely limit the undervolting capabilities).
If the option is not available and you notice a performance drop, then you either have to use the lowest CPU Lite Load mode that still keeps the full performance (often around Mode 9), or you have to use a more sophisticated undervolting method that tries to "dance around" IA CEP becoming active, using a combination of different settings. But that is beyond the scope of this guide.
For the Z890 boards with Core Ultra, the BIOS looks a bit different, but it seems to have pretty much the same options at least, and i would assume CPU Lite Load works in a similar manner. However, due to the many architectural changes in Core Ultra, i cannot promise the same results, especially since the power draw reading in HWinfo (CPU Package Power) can be inaccurate due to the way Core Ultra is designed. It can be "calculated wrongly" depending on some other settings. So for now, i can only guarantee proper results up to 14th gen. Personally, i've used this CPU Lite Load setting all the way back from my old 9600K, generations in between, and up to my current 13th gen. Always the same procedure to optimize it.
However, MSI themselves are now saying how useful this setting can be, here's an example from their new Z890 boards:
So apparently, it's "all systems go" on Z890 and Core Ultra as well. I just haven't seen much about it yet, the Core Ultra CPUs don't seem that attractive at the moment.
My other guides:
Guide: How to find a good PSU
The following is for geeks only, others can stop reading :)
In CPU Lite Load Advanced, you can select values for AC and DC Loadline seperately, without having some preset combination which can have the wrong DC Loadline value. So now you can set the DC Loadline so it results in the correct power draw numbers. Doing that involves using HWinfo Sensors, creating full CPU load, then looking at the CPU's VID requests (in the "current values" column), which is the voltage the CPU asks for from the board, and comparing it to the current VCore value (note that i don't mean current as in Amperes, i mean current as in, actual live values, not Min/Max/Avg). If those are near-identical, the correct DC Loadline value has been found. The correct DC Loadline value depends on the LLC mode, another setting which influences the voltage (and not to be confused with CPU Lite Load / CLL, completely different). A table of the AC/DC loadline values is here, but it's only a rough one, because each board model is built differently and would also need a bit different values, presumably.
However, this last step doesn't quite pan out in my own recent testing on a PC i'm building for someone. Because even if i set CPU Lite Load "Advanced" AC Loadline to 1 (the lowest possible value) and select a mild LLC setting like Mode 7 (where the VDroop is still relatively big), i can't get anywhere near the low voltages and low power draw under full load that i can reach with just a lowered CPU Lite Load mode and keeping LLC on Auto. I'm talking a coupled dozen Watts difference here under full load, measured at the wall. In other words, lowered CPU Lite Load with LLC on Auto results in the lowest possible VCore and power draw under full load (while staying stable) in my testing, which is arguable one of the most important scenarios for which to keep the power draw low (to avoid cooling problems and improve the CPU's efficiency).
@citay Sorry to bother you again with this one, but I could use some insight here. Since I raised my CPULL to 6, system seemed to be running stable with Intel Performance presets enabled (14700KF, 253W/253W/307A).
Yesterday, I ran into a weird, "sort of BSOD event", but I've never seen anything like it before. While basically idling (browser and a few file folders were open, but I wasn't doing anything at the time), a white, Win11-looking error-warning suddenly appeared, stating something along the lines of "Windows has encountered a critical error and needs to be/will be restarted automatically - please close all apps and save your work"... or something like that. There were no user input options in that box - so no "restart now" or "restart later"... don't think there even was an "OK" button.
Since I had never seen this one before, ever, I wasn't sure what it was and tried to open Win Reliability Report, which didn't even open and gave me some sort of "service not available"-error ... then the PC re-started on its own and without further warning.
I let the PC re-boot, then re-booted again manually, just for good measure and checked SFC - which reported no errors. I then went into the BIOS and raised CPU LL a step yet again (to "7"). That made things run quite a lot hotter in the stability tests I ran next, since Vcore/VIDs went up a fair bit.
Anyhow: Does any of what I describe up above re that dialogue-/error-warning-box sound familiar? I tried googling/pic-googling for it but since I run a German system, I didn't know what the text would've said on English installations and I never found any mention of this particular error-message or behavior. If I had to guess, I'd say this was some sort of "BSOD for the poor" where the system didn't crash outright, but was somehow able to keep things going at least for a while. When I checked the event-log and reliability report afterward, all I could find was "Windows was shut down incorrectly"-entry. I did check for new BSOD-entries, but BlueScreen View couldn't find one and there wasn't one listed in the reliability report, anyway.
S.
If you have any weird issues like this, the safe thing to do is what you've done, to presume that the mode was lowered a bit too much (even though it can be stable in a bunch of stress tests), so you have to "admit defeat" and raise it by one mode. It is hard to test all the different load and load-transition scenarios that can happen for a CPU, so some of the instability you may only find out randomly in normal use like this.
The 14700K is already very extreme (you can see that from the insanely high power draw when let off the leash), so i would say, after the 14900K and 13900K it is another relatively tough CPU model on which to lower CPU Lite Load by a lot of steps, especially when your specific CPU may not have the highest silicon quality to begin with.
But yeah, raise the mode by one step, this is all the advice i can give there, no need to research the crash for too long (until it repeats of course).
Thanks for that. I also went into the BIOS and set Intel Enhanced Turbo from "Enabled" back to "Auto" (should probably set it to "Disabled" now that I think about it), because that was one of the more important sounding changes I had made recently.
I was a bit weirded out by that particular crash-event as I'd never seen that particular error message - which made me go to paranoid thoughts how this might have been some sort of malware or something (possibly masquerading as a Windows error message) that caused this. On all the Windows PCs I've ever used (going back to Win 95, yikes! :D ), I think I've only ever seen "true" BSODs or outright freezes of the entire PC when I suffered crashes like that.
EDIT: After a bit more digging around on the webs, I was wondering about AC/DC load line calibration so I went and checked what mine were set at. I never touched those settings directly, so this must be either their default values and/or determined by my CPU Lite Load setting, I suppose?
Anyhow: Are these "normal" settings?
From what I found in other users' comments, especially the AC setting of 0.350 seems a bit on the low side? Any input here would be appreciated.
S.
Those are the normal values for the AC and DC loadlines when setting CPU Lite Load on "Normal" to Mode 7, like on this table. The lower the AC loadline, the less VCore is added to electrically compensate for certain things. If you overdo the mode lowering and the voltage is lower than required for the compensation with your particular CPU, you can encounter errors.
Well sure it's lowered, but we want to find the lowest point we can safely go to, so this is no surprise. On a 12700K i could recently go down to what is essentially Mode 4 or so, although i used CPU Lite Load "Advanced" for once, with AC loadline 30, DC loadline 103, corresponding to 0.3 mΩ / 1.03 mΩ (the DC loadline is much less important, that's just about getting the correct power draw numbers, but even on 0.8 mΩ in "Normal" it wouldn't be too far off). For my own CPU (i5-13500) i'm on AC 0.3 mΩ too. Each individual CPU can safely go down to a different mode. Any instability hints to raising the mode by one and seeing if it helped.
Your error, it was probably this message? https://blog.nirsoft.net/2009/11/27/very-weird-problem-on-windows-vista-and-windows-7/
^ It didn't look as Windows Vista/7 as this one, but.. yeah... the text was more or less the same. Whew... that's a load off my mind... well, sorta.. :)
hose are the normal values for the AC and DC loadlines when setting CPU Lite Load on "Normal" to Mode 7. Mode 6 would result in 0.3 mΩ / 0.8 mΩ, Mode 5 would be 0.25 mΩ / 0.8 mΩ... like on this table. The lower the AC loadline, the less VCore is added to electrically compensate for certain things. If you overdo the mode lowering and the voltage is lower than required for the compensation with your particular CPU, you can encounter errors.
Slight side note: Just to see what would happen, I went and set Lite Load to "Intel Default" (I'm still on a 0125 based BIOS, no 0129 for me yet) and... holy crap. It sets both AC and DC LL to 1.1 Ohm and ...
Those peak-numbers are basically the PC at idle.. no benchmarking or anything like that going on.
Not sure it's such a great idea to include the word "default" in this setting's name .. when it does *this*.. :D I'm not even going to bother running a benchmark like that and will go back to normal Light Load right after I post this.
This is almost as scary as how that CPU behaved when I first got it and ran it with MSI default power targets - only then it was drawing around 300W.. :D
EDIT: One trip to the BIOS later: If anyone's interested, that "Intel Default"-setting for CPU Lite Load apparently results in a setting of "15" - which seems insanely high and is three steps above the already pretty high default of "12" that this BIOS-version was set to after the flash.
S.
Yes, it's crazy, both how the CPUs are designed from factory, as well as some of the default settings these boards came with / still come with today. The situation has come to a point that, when you have a true 13th/14th gen, or really any i7/i9 as of late, then without updating the BIOS and optimizing at least some of the defaults by hand, you can have a system that will take your cooler on a wild ride and sometimes self-destruct slowly over time.
Just saw non beta 0x129 bios (aka, official) being released today. I'm at work so I can't check out if anything has changed right now, but hopefully MSI has tweaked it to perform better out of the box.
The "J" / 0129 BIOS for my board was released as a beta a couple of days ago, IIRC. Downloaded it but was too lazy to flash right away. Got around to it yesterday and even though I didn't expect another release so quickly, they had actually published a non-beta of that BIOS in the meantime:
Flashed the board with the non-beta this morning, reset all my settings and, so far, I've only done one all-core, 10 min run in CB23 and things seem fine. The score was pretty much exactly the same as with any of the other BIOS' I've ever used (within margin of error), but one thing that stood out to me was that Vcore now only got up to a max of exactly 1.35V - typical values during the test were well below 1.3V, BTW. Which kinda makes me wonder if that's the new microcode at work here ... I mean, capping Vcore at 1.35V?
VIDs stayed below 1.4V for most of the run but I started to get a slightly higher max value on a few cores towards the very end of the 10 minutes - nothing worrying, though. Vcore max also went up a fraction before the test was done (1.354V). CPU temp max never went above 74°C, power draw sat at around 205W and other temps were also looking quite normal.
That said: The BIOS still defaults to a CPU LL value of "12" - which results in 1.1 Ohm for AC and DC LLC - which, probably, would've ended up giving me high voltages and temp spikes into the 90s again, so I instantly went into the BIOS and changed all that back. I didn't touch load lines directly, but I did disable both CEP settings, which are set to "enabled" by default. Didn't even check what "Intel Default" for CPU Lite Load does now, but I suspect it will still result in a CPU LL setting of "15" and even more temp/voltage craziness (at least with CEP disabled?). *shrug*
Guess I'll be running some single core stress tests next as JayzTwoCents suggested in this here video to check for possible CPU degradation on 13/14 gen chips:
S.
I loaded it and as far as temp, etc it was the same as the beta bios, so no real difference there. Back to reducing lite load, etc. I did bump it to msi performance (253 / 400a) and rerun the benchmarks. Much better. Didn't see anything noticeable in voltages, so I'm leaving it there.
I also came to the realization that I'm at the point where I am probably going to switch to an AMD setup next year, so if I burn it up, I burn it up. 😈
I7-13700kf. I haven't had any issues with the processor, so I'm not too concerned at this point. I just want to ensure temps are staying reasonable under load and that's achieved.
Definitely not, something like a 14900K needs way more than that by default. The voltage spike limit is at 1.5x V (forgot the exact limit). Spikes are not that easy to catch on the sensors, the sensors are too slow.
A lot of the people talking about higher temperatures on the BIOS with the 0x129 microcode, they are probably seeing the effects of a higher default CPU Lite Load mode in the new BIOS compared to the older versions, as has been mentioned in some previous replies. So if they were to go by this guide, they could correct all that relatively easily, with the added benefit of having the voltage spike limit in place.
Just FYI: Been watching a couple of BuildZoid videos where he's on an MSI Z690 A Pro (running 0129) with a 14900K in it and that board will do some weird stuff on Windows startup. Since he has an oscilloscope hooked up he could show that Vcore would spike to around 1.58V at times - before the OS was even loaded. IIRC he said it might be an issue with the power delivery on this particular board. Nothing bad was happening once Windows was running - meaning 0129 was doing its job there. But his CPU was still getting crazy voltage spikes sometimes (when folks without an oscilloscope couldn't even know what was going on), so I wonder what that means for degradation - and if other boards from other manufacturers could have similar problems or if this was just a one off with one bad board.
S.
Microcode may be loaded during late stages of platform initialization by the BIOS, so there will be a short window where spikes can happen on the factory CPU code, until the 0x129 MCU is loaded into the CPU and the OS bootloader takes over. Also, i don't see how you could get much degradation from a spike or two during the early boot stage, when it could previously happen quite regularly, depending on the type of load.
I may have good news for all you 0x129ers out there.
BuildZoid replied to my question about the 1.55V limit and said that he believes he is seeing evidence that the voltage limit is STILL IN EFFECT even if you select one of the MSI CPU Cooler modes instead of Intel Defaults. The one caveat being that there is a brief period during boot up when the microcode is either not loaded or not working correctly. If it’s the latter then we may see further microcode updates. Either way, this reiterates the fact that undervolting, even with the 0x129 BIOS, is NOT a waste of time.
Two other points he made, included:
1. CEP is disabled by default when switching to the unlimited MSI mode, and AC_LL defaulted to 50 on his MSI Pro Z690-A DDR4 motherboard.
2. He observed that, even with the Intel Defaults mode, you can change settings like PL1,PL2 and IccMax without being kicked out of that mode.
So, if BuildZoid’s oscilloscope observations hold up, I think it’s pretty good news for us MSI users!
:beerchug:
EDIT: I should have stressed this point: BuildZoid's observations are particularly good news for those of you who wish to enforce manual all-core ratios in order to lower voltages beyond what can be achieved by undervolting alone. You can now do this without having to worry about disabling the 1.55V limit when you get kicked out of the Intel Defaults mode. The objective of manual all-core ratios can either be to downclock your CPU (to lower voltages across the board) or as an effective way to disable the Intel auto-boosting algorithms that cause higher voltages when boosting Single-core/Dual-core frequencies. I mean, why subject the potentially sensitive Ring[bus]/Cache to higher voltages just to score a few extra single threaded points. This is a very important point that is all too easy to overlook if you are new to the world of Raptor Lake and/or manual tuning Intel CPUs.
EDIT #2: If you like the majority of what the Intel Defaults bring you then there's no reason I can think of that is stopping you from manually reproducing those settings while in one of the MSI CPU Cooler presets/modes, especially now that we believe the 1.55V limit is unaffected by which CPU Cooler preset/mode you use. I would make one suggestion, though: If there is any doubt in your mind about what a particular Auto value defaults to then I would use the manual options to force that setting to what you intend to have active. In that regard, you may also need to keep an eye out for settings (when changed) that automatically impact other settings, especially when operating within the new Intel Defaults mode. This especially applies to settings that are set to Auto, where the actual values can change behind the scenes without your knowledge. A perfect example would be the LLC impedance value and the AC_LL/DC_LL relationship.
just wanted to add to the success stories.
updated BIOS today to latest with 0x129 microcode, followed OP's guide
Board: MPG z790 Carbon WIFI
CPU: 13900k
Cooler: Noctua NH-D15
CPU Lite Load: Mode 7 (default was like 12)
IA CEP: disabled (perf started degrading at mode 7 without this)
PL1/2: 253w or whatever the intel default was
getting 36k in cinebench (30k-31k before with thermal throttling to 100), maxes out at 90 degrees in benchmark, avg about ~75 in games.
I could probably go even lower on the modes but I had enough tinkering for today, pretty happy.
I'm getting mixed info on whether the current 0x129 microcode is the big one we've all been waiting for to fix the degradation issues or is there another one coming end of August?
Maybe my earlier post (one above) might answer your question. Where my head is at this time is that a combination of 0x129 and user undervolting should extend the life of your CPU considerably; I mean, it has to!
Any further BIOS updates will be gravy on the top!
CPU: 13900k
Hey mate! Why don’t you try disabling enhanced turbo and limiting the two cores that goes to 58?
