Guide: How to set good power limits in the BIOS and reduce the CPU power draw
Pro
By now, and not only since threads like these, many Intel users will have heard (or have found out) that a lot of Intel CPUs have a very high power draw that can really push the CPU cooling capabilities to the limit and beyond. There used to be a time where a cheap tower air cooler would be enough for any CPU available for that socket. That era pretty much ended with the i9-9900K, the first "monster", and then from 10th gen onwards, Intel really started pushing the higher-up CPU models to the absolute edge. Causing higher and higher power draw, which has now gotten ridiculously high with the 14th generation like the 14900K.
Note that Intel also recommend certain power limits for different CPU models, but those are more or less arbitrary, they have nothing to do with your individual cooling capabilities. One thing i would say, there is no benefit in allowing more than ~250W for any CPU, not even a 14900KS. Because it will always make the CPU run more inefficiently from that point onwards (at the very latest, for other CPU models even earlier). That's then "junk power draw" or "junk performance", meaning the power draw still keeps increasing a lot, but only for minimal performance gains, it basically just ruins the efficiency. So even with a high-end 360mm AIO, you will not tend to see me recommending limits higher than 253W.
Check the performance too:
Yes, because it is needlessly fighting the outcome of undervolting. By lowering the voltage, you are trying to do the best thing you can do to the way a CPU operates (as long as it stays stable), and IA CEP is working against it because it detects a deviation from a narrow "normal" range it tries to uphold. But we are know that lowering the voltage is not dangerous (quite the opposite), so we should not let IA CEP interfere in this instance. Furthermore, using an updated BIOS with the fixed Intel microcode will prevent the voltage spikes that can cause CPU degradation, so that's already the main line of defense. The recommendation to keep IA CEP enabled comes from a time way before BIOS updates with this new microcode were available, plus it was meant for default BIOS settings, not for hand-optimized settings. Here is more circumstantial evidence that disabling IA CEP should not cause the current to go crazy. So when you see the performance going down the drain when lowering "CPU Lite Load" below Mode 10 or so, simply set IA CEP Support to [Disabled], nothing bad will happen.
What to do when the option "IA CEP" is not available?
We know now, if IA CEP is available and you notice a severe performance drop (for example Cinebench score getting lower), then it has to be disabled, simple as that.
But what if IA CEP is not available as an option on your board? Then there's two possibilities, which you can't influence:
1) Performance stays the same when you lower CPU Lite Load (which is what you want, and is the case with my configuration), or:
2) Performance drops off a cliff once you lower CPU Lite Load enough, or otherwise try to lower the core voltage (bad, this would severely limit the undervolting capabilities).
If the option is not available and you notice a performance drop, then you either have to use the lowest CPU Lite Load mode that still keeps the full performance (often around Mode 9), or you have to use a more sophisticated undervolting method that tries to "dance around" IA CEP becoming active, using a combination of different settings. But that is beyond the scope of this guide.
For the Z890 boards with Core Ultra, the BIOS looks a bit different, but it seems to have pretty much the same options at least, and i would assume CPU Lite Load works in a similar manner. However, due to the many architectural changes in Core Ultra, i cannot promise the same results, especially since the power draw reading in HWinfo (CPU Package Power) can be inaccurate due to the way Core Ultra is designed. It can be "calculated wrongly" depending on some other settings. So for now, i can only guarantee proper results up to 14th gen. Personally, i've used this CPU Lite Load setting all the way back from my old 9600K, generations in between, and up to my current 13th gen. Always the same procedure to optimize it.
However, MSI themselves are now saying how useful this setting can be, here's an example from their new Z890 boards:
So apparently, it's "all systems go" on Z890 and Core Ultra as well. I just haven't seen much about it yet, the Core Ultra CPUs don't seem that attractive at the moment.
My other guides:
Guide: How to find a good PSU
The following is for geeks only, others can stop reading :)
In CPU Lite Load Advanced, you can select values for AC and DC Loadline seperately, without having some preset combination which can have the wrong DC Loadline value. So now you can set the DC Loadline so it results in the correct power draw numbers. Doing that involves using HWinfo Sensors, creating full CPU load, then looking at the CPU's VID requests (in the "current values" column), which is the voltage the CPU asks for from the board, and comparing it to the current VCore value (note that i don't mean current as in Amperes, i mean current as in, actual live values, not Min/Max/Avg). If those are near-identical, the correct DC Loadline value has been found. The correct DC Loadline value depends on the LLC mode, another setting which influences the voltage (and not to be confused with CPU Lite Load / CLL, completely different). A table of the AC/DC loadline values is here, but it's only a rough one, because each board model is built differently and would also need a bit different values, presumably.
However, this last step doesn't quite pan out in my own recent testing on a PC i'm building for someone. Because even if i set CPU Lite Load "Advanced" AC Loadline to 1 (the lowest possible value) and select a mild LLC setting like Mode 7 (where the VDroop is still relatively big), i can't get anywhere near the low voltages and low power draw under full load that i can reach with just a lowered CPU Lite Load mode and keeping LLC on Auto. I'm talking a coupled dozen Watts difference here under full load, measured at the wall. In other words, lowered CPU Lite Load with LLC on Auto results in the lowest possible VCore and power draw under full load (while staying stable) in my testing, which is arguable one of the most important scenarios for which to keep the power draw low (to avoid cooling problems and improve the CPU's efficiency).
There's a YouTuber out there that he knows what he's talking about. One of the few really.
Well. It depends what you want to achieve. He does a mild all-core OC. That's the old-school overclocking way as opposed to per-core/per-load OC, but nowadays i wouldn't overclock most CPUs at all anymore, they tend to be too close to the limit now already (some, like the 14900K/KS, arguably could be above their limit from factory). He uses a negative AVX offset. He modifies the BCLK frequency from 100 MHz which is complete nonsene nowadays, but luckily he's well below the margin of error for his change, so it doesn't do anything. He sets the power limits to slightly above ~250W which i see as the maximum, again, his change is not dramatic, but above 250W is really "junk performance" territory. He does these tiny little tweaks (5W higher Short than Long duration power limit) which don't really amount to anything, probably just to give the impression that he "knows what he's talking about". Then he proceeds to tune all the V/F offsets manually, this is getting way too specific to his CPU sample, there is no way this can be in a general guide. On the positive side, he shows a bit how to stress-test and use HWinfo to check for thermal throttling. Then the rest of the video he showcases his results.
On the whole, tuning it so highly specifically, which obviously only fits for his CPU and his system and cooling, that is similar to someone posting their end result of settings here. It's nice to know, but not ideal for a guide for the general public. Some of the changes he does are "for show". The main thing that is achieved is the undervolt, and within the power limit "budget", of course that will lead to higher performance, that's exactly what this thread here is also about. He does this in a way that is probably a bit too complicated for the Average Joe, which creates more room for problems when users with different CPUs and systems attempt it.
The other video, he goes by the very first set of Intel recommended settings (easily identifyable from there still being the "DC loadline must match AC loadline" text), which as we know, came out way before there was any microcode fix available for the voltage spikes, so it raises this criticism. He doesn't seem to be aware that there was a second table that Intel released later, so he still insists on AC and DC loadlines matching and deducts points for the ASRock BIOS not adhering to that. BTW, kudos to ASRock, they have better power limit defaults for four different types of selectable cooler choices (air cooler, useless 120/140mm AIO, 240/280mm AIO and 360/420mm AIO), with some better-fitting values than MSI for sure.
He turns on "Ultra Fast boot", which if it's anything like on MSI, doesn't achieve much, but historically always has the potential of causing problems. He seems to like setting his fans to an aggressive fan curve, which again might not be ideal for everyone, i for one like my quiet system and will tune the fan curves accordingly.
Verdict: It's not that he does anything completely wrong (well, just a couple minor things). The overall idea is not bad, it's not too different from this thread. It's just that his way of getting there is like a DJ on stage, turning all the knobs ever so slightly, and people may think, wow, he's like a musical conductor. While yes, it's possible to tune the CPU in more detail than i show in this thread, i went for an approach that is probably much easier to follow, and thus able to reach more people. This whole matter is complicated enough, so when you can get there 90% of the way with one setting, that's the kind of guide that is required for these times.
And yeah, obviously he does everything on his ASRock board, whereas we're on MSI here.
while in one of the MSI CPU Cooler presets/modes
Speaking of which:
Do those cooler-presets affect anything else besides PL1/2 and ICCmax? IIRC, those three settings are all that's mentioned in the BIOS' preset-selection pop-up, but that doesn't have to mean all that much, I suppose?
2. He observed that, even with the Intel Defaults mode, you can change settings like PL1,PL2 and IccMax without being kicked out of that mode.
I'm on a Z690 Tomahawk DDR4, not on the Pro board BuilZoid's using, but I'm 99 percent sure that's how that setting always worked with most (all?) of the previous BIOS versions I've used (before my board ever got any "Intel Default" entries/settings). IIRC the "tower air-cooler" one was close or identical to what's now called "Intel Default". In any case: I've had that preset on "Water-Cooler" for a long while (meaning "no limits" I suppose), but I had also been setting PL1/2 and ICCmax manually for months and months. And those manual adjustments never changed the "cooler preset" entry in the OC-screen for me. Hence my question if those presets affect any other settings besides those three.
I'm getting mixed info on whether the current 0x129 microcode is the big one we've all been waiting for to fix the degradation issues or is there another one coming end of August?
From everything I've read and heard (and by glancing at my calendar), that's how I understand it. 0x129 should be the "big, end of August"-update. Hopefully, Intel have tested/are still testing the crap out of this and are satisfied with 0x129's effects on the issue, but I also wouldn't be surprised if they (and/or the board manufacturers) had to make more tweaks in the near future. Or, seeing how they seem to be firing employees left and right, perhaps they aren't really on top of things and all this is is just PR band-aids. I guess we'll never know.
I bumbled my way through some of those per-core-OCs with both the i5-12600K I used before and then with the i7-14000KF - it was probably mostly due to my general incompetence, but it seemed to me that besides some minor gains in benchmarks (which weren't that far above margin of error between runs), all it got me was much higher temps and power-draw (especially with the i7) and in some cases some trouble with stability. Don't get me wrong: It can be a fun challenge and I suppose it's very gratifying if you do manage to find a stable OC that delivers a half-way meaningful uplift without frying your chip .... but with the way these things seem to be set up from the factory these days, I wonder if there really is all that much dormant potential to be found in OCing.
S.
Just in case it helps anyone:
I-9 13900k
Z790 Tomahawk DDR5
H150i 360mm
Stability test done and 38k on c23.
Max temps of 83 after 10 min stress test.
PL1/2: 253W
ICCMAX: 400A
IA CEP DISABLED
ENHANCED TURBO DISABLED
MODE: Intel Default (it kicks me out but I was able to select it again so 🤷🏻‍♂️
Per Core Ratio Limit: every P Core to 55 (this way you avoid the two ones trying to reach 5.8)
Stats during test stability:
Max VID: 1.346
Average: 1.235
Max VCore: 1.178
Max Power Package: 297W (this confuses me as I have the limit to 253 and with 307 it works but when I changed it to 400A it seems my mobo allows the CPU to get more power than the limit?) Nevertheless, VID, VCore looks pretty healthy so I’m okay with this.
Just curious; does anyone knows why that happens even having PL to 253? The only change is 307A to 400A.
Speaking of which:
Good question - I’m glad you asked it. I think it goes like this: The newly introduced Intel Defaults mode changes more than just the settings you mentioned from the old Water Cooler, Tower Cooler, Boxed Cooler days. It also appears to change the CPU Lite Load mechanism (which impacts the AC_LL, DC_LL) and maybe even the LLC Auto value. And finally, we have evidence that it also changes CEP Auto to equal “enabled.” There may also be one or more other settings that change, and maybe even some settings we usually leave on Auto because they are very low level (e.g. PLL).
Unfortunately, we are left to guess because if a setting remains set to Auto (but the corresponding value changes) we don‘t often see these settings listed when you hit the Save and Exit button. In addition, many of the Auto fields don’t show you on the BIOS screen what the corresponding Auto value is. However, the information I stated above is, at a minimum, what BuildZoid and other members on this forum have observed during their testing. I’m not testing myself, but I try to filter the information for newcomers.
Now, the implication of the Intel Defaults mode changing more than just the PL1,PL2, and IccMax (like the old days) is that it means the renamed MSI modes (e.g. Tower and Water Cooler) have to change these new settings back to the old defaults that MSI liked, such as CEP disabled by default (under Auto).
I hope that answers your question. Just be on the lookout for Auto settings that do not align with your expectations. I’ve seen several reports that this new mode switching logic is still a little buggy. There are also implications for what the F6 - Optimized Defaults now change, too. And even a clear CMOS. But likely, and hopefully, they are at least consistent with the MSI BIOS - because I see reports of users struggling with the new Gigabyte BIOSes not switching settings back and forth correctly.
Bottom line: These CPU Cooler modes are much more invasive and special than they use to be. And they might not function 100% correctly due to the way this new code has been rushed out the door for so many motherboards. Forewarned is forearmed, right?
Yeah, I think this is pretty well known for MSI users. But I just wanted to reiterate it in case someone new to the platform has any doubt about the tune-ability of the new Intel Defaults mode. It’s become a very personal choice whether you stick to the new mode and try to improve upon it or whether you go over to the MSI modes and dial everything in manually. I believe you can do either and arrive at the same functionally, especially if that 1.55V limit stays in place. That’s what got me excited; we now have options. As I’m more the manual settings guy, myself, I’ll probably just adapt the MSI unlimited mode to suit my tastes, both for my 12700KF and my planned upgrade to a 14700K. Cheers!
Hey mate! Why don’t you try disabling enhanced turbo and limiting the two cores that goes to 58?
just tried cinebench and was within margin of error of my last test, which setting is the ICCMax you're using? is that the "current limit" or something similar? I dont see it in my bios edit: found it, made no difference either.
Exactly, they don't leave nearly as much unused potential on the table as they used to. It goes back to what i posted here (second paragraph). That's why, as soon as you have to add VCore to reach higher clocks - which will be required for any overclock that is remotely relevant - the power draw and thus the heat output will go through the roof, while the performance gains stay quite minimal. This will be the case with most i7/i9 models for sure. They are pushed so hard from factory on their voltage-per-frequency curve that when you try to go beyond that and even get a few percent better performance, the power draw can shoot up seveal dozen percent easily with not much to show for it. The CPU is already screaming for mercy.
In the linked videos, there was just very minor overclocking going on, the bulk of the performance improvements come from the CPU being power-limited (as it would be with most coolers), and with lower voltage-per-frequency can obviously clock higher within those power limit restraints. This is the mechanism by which the performance goes up when you undervolt. Power draw goes down, heat goes down, temperatures go down, performance goes up - the reason why undervolting (by whatever method) is one of the best things you can do for your CPU, if done right.
IccMax works with internal CPU currents, i think it can regulate things much faster than the power limits, that's why it's a bit difficult to fine-tune if you want some specific behaviour. The power limits are slower to react, i routinely observe an overshoot of 20W or so there for most people, but that's only for a short time, you should see the current/average values during full CPU load be much more around the actual values you set. So don't be too alarmed by the overshoot, it should just happen briefly before the power limit swings into action. No danger for your cooling.
Thanks so much mate!
I have not seen anyone here mentioned deidian's post from overclock.net about how CEP might prevent CPU degradation. I wonder if it is relevant ?
In theory yes. Very perfunctorily a CPU is a printed board at a extremely small scale with metal traces intended to be the electric circuit and an insulator(silicon substrate). The funny thing about them is that electrical resistance of materials changes with temperature and in CPUs the global tendency is: metals follow common behavior of having increased electrical resistance as temperature raises, but silicon being a superconductor has the odd behavior of lowering its electrical resistance as temperature raises. In a nutshell in a CPU as temperature increases the conductors in the circuit become worse at conducting current and the insulator becomes worse and being an insulator.
One electrical phenomenon related to electro-migration happening in this situation is events in which the current flows though the insulator rather than the traces, which can cause errors and in some cases physical damages to the insulator layer(CPU designs countermeasure this to tolerate the damages to a point and still keep working reliably, don't just go crazy with this). This phenomenon causes drops in voltage in sections of the traces circuits of the CPU when things don't go as intended. Enter CEP: which measures the CPU is getting the "right Vcore", there's probably a lot of Vcore measuring points across the CPU circuitry, and when that's not happening at some measuring point it assumes that current is leaking somewhere through the insulator and physically reduces the clock speed of the affected core. It reduces performance and also reduces the current flowing though the entire core, the latter effect stops the leakage phenomenon reducing odds of it causing permanent damages. The CEP clock speed reduction has the incidental effect of avoiding or making the core more tolerant to unexpected undershoot since they will trigger CEP clock gating: but this depends on the CPU configuration, for CEP the correct Vcore is the one references in the V/f curve, which can be changed.
This physics fact about them is generally speaking voltage reliability: a relationship between temperature and voltage in which 'degradation' is within the manufacturers warranty expectance.
Forgot to add this, although I'm not sure if it's really relevant:
i7-14700KF, 360mm AiO
MSI Z690 Tomahawk DDR4 Wifi
2x16GB G.Skill TridentZ (RGB ... for shame!), 3600/CL16 - XMP = ON
BIOS settings:
PL1/2 = 253W
ICCMax = 307A
Intel Enhanced Turbo = OFF
CPU Lite Load = "Normal" and "7" (<--- seems necessary since a few BIOS updates for low voltage stability)
CEP = both entries to "OFF"
0x125 BIOS/microcode: CB23 result, 10 min all-core = 33,800 points
0x129 BIOS/microcode: CB23 result, 10 min all-core = ~33,500 points (seems kinda low for this chip, but most results I can find online are on Z790, DDR5 boards, so ... )
EDIT 2: 0x129, CB23 result, 10 min all-core with "MSI Performance"-preset (400A):
^ Not sure if the 1000 extra points are worth the higher power-draw. Temps and voltages still seem fine.
3DMark CPU Profile 0x125 run:
3DMark CPU Profile 0x129 run:
VIDs peak at around 1.4V on some cores, but mostly stay close to 1.2 - 1.25V under load. Vcore hovers around 1.35V and temperatures seem fine with max peaks in the high 70s. Power draw maxes out just over 200W in CB23 (~205W). Both P- and E-cores seem to boost to their expected levels under all-core stress-testing.
Not 100% on this, but differences between the two BIOS versions seem rather low to me - probably within margin of error? So I *guess* it's safe to say that, in my case at least, there's no real performance loss incurred by the new BIOS and/or microcode. Although all the testing and comparing I've done so far seems to point to slightly lower scores across the board with the new BIOS/code.
EDIT: And just for $hits and giggles, I went and set "MSI Performance" preset in the BIOS, which - from what I can tell - ups ICCMax from 307A to 400A. Didn't touch any other settings and the BIOS didn't change anything obvious on its own - CPU LL was still set to "7" for example and LL AC/DC values were unchanged according to HWInfo.
Did a single CB23 all-core pass just to get a score and achieved ~35,500 - at the cost of 50W additional power-draw (it actually goes up to its allowed limit of 253W now) and slightly higher temps. Voltages seemed a little higher, but not dramatically so - but I would have to do a 10 minute run to see if they change under that kind of prolonged load.
Also re-ran CPU Profile like that and here's the results - "Intel Default"-preset/307A on the left, "MSI Performance"-preset/400A on the right:
CPU Profile doesn't seem to be pushing the CPU that hard, as power draw was pretty much identical (around 200W) with both 307A and 400A ICCmax.
S.
BIOS settings:
PL1/2 = 253W
ICCMax = 307A
S.
Hey mate! Idk if GT CEP should be disabled or just IA CEP!
Yeah... I'm not too sure about that myself. But since I had read that if you run a lower value for CPU Light Load, CEP might freak out on you, I simply turned them off.
Haven't read or heard any definitive answer re CEP when you're diverting from Intel Defaults, so... *shrug* :D
S.
There is: -
IA CEP Support
IA CEP Support for 14th Edition
as well as:-
GT CEP Support
GT CEP Support for 14th Edition
I've never seen anyone mention the last two so I've not touched them, would be good to get some clarity on the last two.
Hello, there is something wrong. I have an MSI Pro Z790A Max board and an 14900K CPU. With latest bios beta at LLC Mode 5 setting CEP still not kicking in under full load of Cinebench R23 multi core benchmark when I set AC LL as low as 0.05 mohm. And this should not be true, this board's LLC Mode 5 could not be set as low as that value.
Settings are: Intel Default selected, CPU Voltage Adaptive+Offset -0.14V, CPU Lite Mode Control AC LL 5 / DC LL 110
Can't figure what is wrong here.
There is: -
IA CEP Support
as well as:-
GT CEP Support
These are for internal GPU of the CPU I assume. You can’t see those settings if you have an KF CPU again I assume.
I don't recall seeing them before the microcode fix bios came out so but a quick Google (which I should have done first) seems to prove your point that they are for the IGP which I don't use but thanks for the response. (y)
I don't recommend using "CPU Lite Load" - it can result in different AC_LL and DC_LL settings with different other settings or with different BIOS updates. Instead set AC_LL and DC_LL directly
BIOS settings:
PL1/2 = 253W
ICCMax = 307A
S.
This checks with what I see on my 13700kf. I am using the MSI Profile (400a). Performance is better, temps a degree or two higher, voltages look ok.
I did a couple of 10 minutes runs and it didn't show anything unusual. As stated earlier, I'm leaving it this way.
If you read that post closely, it would not be about preventing CPU degradation in the first place, it would be about reacting to existing CPU degradation in a way that limits the degradation from proceeding as before. It can sense if "current is leaking somewhere" (which could point to the effects of degradation) and physically reduces the clock speed of the affected core. However, when we undervolt, we can trigger that detection without it being any effect of degradation (we can easily trigger it on brand new CPUs), so then it only gets in the way. And the degradation is hopefully taken care of for the most part by limiting voltage spikes and lowering voltages in general.
IA means Intel architecture, referring to the actual CPU cores. GT means Graphics Technology, referring to the iGPU. The iGPU doesn't interest us, we're not undervolting that bit and it is not related to what we're doing with the CPU cores. So only IA CEP has to be disabled sometimes. If you turn off "IA CEP Support" and you have a 14th gen, then "IA CEP Support for 14th Edition" should turn off automatically as well.
Well, CPU Lite Load can be used alright, but you are correct in that the latest BIOS versions seem to default to a higher mode by default (also see here) or may have changed the underlying values. In the first eventuality (default mode is higher), just reduce the mode to the previously found lowest stable mode (plus one step higher for headroom). In the second eventuality (values have changed), the lowest stable mode would have to be found out again. So far, probably all cases just had a higher mode than before as the default in the latest BIOS. So then they'd just have to lower the mode again.
Even if they had to find a good mode again for this setting on a new BIOS, i think that is more straightforward to understand and implement for some people than how to first set the AC loadline and then dial in the DC loadline to make the VIDs match VCore under load. This is what i explain at the very bottom of the first post, where i talk about the common cricitisms of using CPU Lite Load "Normal". Yes, it has some downsides, i am fully aware. But there has to be a simple guide. If i need another two or three pages of additional explanations, people's heads will be spinning.
I see your point, but for now i will see how things develop, especially in future BIOS versions after this 0x129 "milestone" (or was it just a stepping stone?).
