Pro
Setting up a fan curve involves a balance between airflow and noise. But it is not that difficult when you know a good way to do it, and you only have to do it once.
First, a word about the fans. I'll try not to make it too difficult, there is just some precise terminology I have to use, but in the end it's not that hard to understand, I promise.
If you want to skip this part and go right to the information about setting up fan curves, scroll down to FAN CURVES.
There are two different types of fans, which you can tell apart by their plug. Let's look at this picture:
A three-pin plug means the fan is DC (direct current) voltage-controlled. A four-pin plug means it's PWM (pulse width modulation) controlled.
With a DC-controlled fan, the fan speed is regulated by the board powering it with lower or higher voltages (say, between 3V and 12V) instead of steady 12V.
With a PWM-controlled fan, the board powers it with a steady 12V, and the fan speed is controlled through the fourth pin via a PWM signal.
Note: The "RPM Speed Signal" pin (rotations per minute) in the picture is telling the motherboard at which speed the fan is spinning, it is not controlling the fan.
So for each fan, you have to select the right fan control method: DC for a 3-pin fan or PWM for a 4-pin fan.
Beware: Some cheaper motherboard models may only allow DC control for most of the fan headers, or only allow PWM control for all of the fan headers, regardless of the fan headers all being 4-pin headers or not. This may save them a little money on components around the fan headers, but it can be very inconvenient if you have the wrong type of fans and you can't control them properly as a result. So pay extra attention to that.
It's easy to notice in the BIOS: When you can't control some 4-pin fan headers with a PWM signal and instead only have DC (voltage) control available. Or when you don't have the ability to set a DC voltage for the fans, and you can only set a PWM percentage (then, when using 3-pin fans, they would always run at full speed here, because they would get constant 12V).
But you can also find out about this in the manual, before purchasing such a board.
Two examples of such boards. First, a board where they saved money on two of the headers:
Both CPUFAN headers can control the fan speed via PWM signal or DC voltage (depending on the fan and which control method you select in the BIOS).
But the SYSFAN headers at the bottom can only control the fan speed via DC voltage, despite having a 4-pin fan header.
"NC" means Not Connected, so they didn't implement PWM control on those headers for cost-saving. On more expensive board models, all the fan headers should be able to control fans with both methods. But in this example, you'd want your 4-pin PWM fans on the two CPUFAN headers, if possible.
Second example, from the MSI PRO Z790-S WIFI, the worst Intel Z-series board on the market:
This board simply doesn't offer DC Voltage control for any fan headers, only PWM control. So if you use 3-pin case fans (or CPU fans) on this board, since they don't have the fourth wire for the PWM speed control signal, they're stuck at a full 12V. There is no way to control 3-pin fans on this board at all, the fan curves will be useless for them. You need some kind of solution like a separate fan controller, which some cases may offer.
These shortcomings are mostly on lower-end board models. Once you go for a slightly nicer board model (from lower mid-range onward), those should be able to have all fan headers controlled in both ways, DC voltage or PWM.
By the way: Every PWM fan can also be DC-controlled, it's just a slightly worse method of controlling it. One advantage of PWM control is that the fan will always turn on, even at a very low setting (unless it's purposely configured to stay off below 5% or 20% PWM signal for example). But when you go too low with the voltage on DC control, the fan might not turn on reliably, as the voltage is not enough to overcome the fan motor's resistance, so you'd have to add a bit of extra margin on the voltage.
The general target for the fan curves is:
- Nice low RPM (fan speed) at low temperatures
- Let the RPM ramp up gently with rising temperatures
- Only ramping up the RPM faster when the temperature approaches a quite high level.
Now, before setting the fan curves: Since we're doing this in the BIOS, this is a good time to first update the BIOS to the newest version. Because if you decide to update the BIOS later, it will reset all settings (with some boards, that includes the fan curves), and you have to enter everything again. But since we'll start from scratch now anyway, updating the BIOS beforehand is a good idea.
A quick how-to on BIOS updates:
1) Get the latest BIOS. It's always the topmost one when you click on "BIOS" on the MSI support page for the mainboard.
Now, before we come to the topic of how to set good fan curves, let's first look at a proper way to create an airflow through the case. Normally there should be at least one intake fan (usually at the front) and at least one exhaust fan (usually at the rear, in line with the CPU cooler). This will ensure a defined airflow through the case which can extract the heat from the components.
All the fans should work in unison within that airflow, to get one stream of cold air coming in from the front, picking up some heat (mostly from the CPU and GPU), and the warmed-up air being exhausted out of the rear. So in modern cases, the airflow usually looks something like this:
Perhaps minus the fans on top of the case. But there often will be at least one fan (if not two or three) in the front, and one exhaust fan in the rear behind the CPU cooler. Each fan will have one or two arrow markings on one of the sides, showing the rotational direction as well as the airflow direction, and all the "airflow arrows" should be pointing towards the rear of the case. When the fans come pre-installed in the case, they will already be installed like that.
If the front intake fans outnumber the rear exhaust fan by 2:1 or 3:1, then the rear fan ideally runs on slightly higher RPM than the front fans, to create a more even airflow.
About over- vs. underpressure, or positive vs. negative pressure:
Usually there should be a slight overpressure / positive pressure, meaning, slightly more air intake than air exhaust. Because the problem with underpressure / negative pressure is, there's no control over where the air is being pulled from. So when there are more exhaust fans than intake fans (or when the exhaust fans are more powerful or they spin faster), they will usually pull air from the shortest path. Meaning, all the additional air does not come from the front, it will be pulled from every vent and case opening that is nearby.
But since we want a defined airflow, usually front-to-back/top, the best thing is to have a slight bias towards the intake fans. And most cases will naturally do that, as they tend to have more intake fans than exhaust fans. Then the exhaust fan should be on a slightly higher fan curve to spin a bit faster, but it's ok to still have some air blowing through the case vents below the rear exhaust fan, having the the front fans move slightly more air into the system than the exhaust fan alone can move out. Then the warm air that collects below the graphics card, or generally in the lower half of the system, can also slowly be replaced by fresh air as it exits through the rear case vents. You don't have to feel real wind coming through the vents, but it's good if the air is not totally stagnant, and you definitely don't want the air to be pulled in from there.
FAN CURVES
Now it's time to set the fan curves. Enter the BIOS (press DEL after power-on/reboot) and open the "Hardware Monitor" which offers the fan control.
For each fan, you can set four points of a curve, MSI calls this the "Smart Fan Mode".
This is how it might look:
Note that each of the four points of a fan curve is restricted by the points next to it, it can't go lower than the previous point or higher than the following point.
So you may have to move a neighbouring point if you hit a restriction on the point you want to adjust.
The goal for the first point of the curve is to find a setting with a bit of airflow, but where the fan is very quiet. This will be the setting when the CPU is doing nothing (idle).
You don't need a lot of airflow when the CPU temperature is low anyway. My fans spin only at around 400 RPM there, as you can see, just enough to keep some air moving through the case. Note that i have a high-end air cooler with two fans on there, as well as three 140mm case fans in a large case. So in a small case with fewer fans, you will need a bit higher RPM to keep it this cool inside. But there is no need to have the fans spin for example at 1000 RPM in idle.
For testing, it's good to open the case and put your hand behind the fan or behind the cooler (where the air gets blown through) to feel how much airflow the fan generates with different values. As long as you don't touch the motherboard or other components, there's no danger. And you can immediately feel the results of your adjustments.
For testing the airflow, turn off "Smart Fan Mode" for a while, so you can influence the fan speed directly. You can also turn off the other fans, so you can find the sweet spot for low temperatures with the particular fan you're checking. Remember, you only need a slight airflow for this starting point of the fan curve, the goal is not to have unnecessary noise when the temperature is low.
For this goal (a bit of airflow, but being very quiet), the resulting PWM % value (or DC voltage on 3-pin fans) is your starting point at 30°C or 40°C for this fan's curve. The temperature you select depends on where you want the fan to first start ramping up. It makes no sense to define a temperature below the ambient temperature, or below the minimum CPU temperature, you'd just be wasting the whole adjustment point. So anything below 30°C only makes sense with powerful cooling methods that can actually hold the CPU below 30°C.
Next, don't go to the second point, but the third one. Find a good level where the airflow is strong but the noise is still bearable, and use this as your "full CPU load" setting for higher temperature values like 65°C or 75°C. To fine-tune this point of the curve, you might have to go back and forth from the BIOS to Windows, where you monitor the fan speed with certain CPU load and fine-tune the setting afterwards. But it doesn't take that long to do, and you only have to do it once.
As for the second point of the curve, the in-between point: Set it slightly below a straight line between the first and third point, to not make the fans ramp up too fast at medium temperatures.
For the final point, set it for 85°C or 90°C CPU temperature and 100% PWM value (or full 12V DC with a 3-pin fan). This is the "worst case" point for safety.
Now you should have all four points of the curve set to a sensible value, and most of the time, the fan should stay between the first and the third point. The highest last point is just a safety measure.
I would always create such an "ascending dominant" curve:
A perfectly straight line makes no sense, you'd be wasting the two middle adjustment points.
A descending dominant curve makes no sense, as it will make more noise than necessary.
Here are examples. You might of course have to use different values, but just to see how it should roughly look like. The curve needs to be done for your particular fans.
This is for a PWM fan (4-pin), which is controlled by a PWM % signal:
I would always prefer "Temperature source" CPU for the CPU fan(s), and probably most other fans too.
Usually, the CPU temperature is the most important one, and will influence the other temperatures.
By the way, a "Step down time" of 1.0s makes the fans spin down less audibly.
However, it's also feasible use "Temperature source" System for case fans. Here's an example for a DC (voltage-controlled) 3-pin fan.
Note: The following picture is not how it should be set when using the CPU temperature as the source (which is the usual temperature source),
it's an example of a fan curve when using the System temperature as the source, which could be done for case fans.
When using CPU temperature as the source, the fan curve should not be this steep, it should be more like the pictures above.
Of the six total fans in my PC (two on the CPU cooler, four in the case), this lower front intake fan is the only one for which I use the "System" Temperature Source. I want it to react to the system temperature with a steeper curve, since the system temperature will obviously increase much more slowly than the CPU temperature. The graphics card can be a major contributor to heating up the whole system, and since I can't use a graphics card sensor as the temperature source, this is sort of a roundabout way to handle that. Of course, you can also have the CPU as the temperature source for all the fans, then you should use a shallower curve like in the pictures before this one.
Here's a 4-pin system fan (in my case, a Noctua NF-A14 PWM) with the CPU as the temperature source:
In my system, the CPU temperature actually stays very low under load, since I have a mid-range CPU and a high-end CPU cooler. Therefore, even for the system/case fans, I can set this steep of a fan curve and not worry about getting jet engine noises under load, it will still stay pretty quiet. Depending on the individual configuration, it might be better to have the system fans on less steep of a curve compared to the CPU fan(s), just so the noise is less annoying under load. It all depends on your setup, what kind of fans you have, and noise/temperature preference.
When you have a graphics card (GPU) with a pretty high power draw, and/or there will be a lot of gaming done on the PC, then it's also a good idea to observe the various temperatures during a stint of gaming, running HWinfo Sensors in the background, set up as mentioned in step 1) of this guide with the sensors expanded. Because apart from the CPU temperatures, the GPU and other temperatures (SSD, RAM, System...) are of course also important. A GPU can take quite high temperatures, and for some cards it's not unusual or concerning to see high 80°C there under load, that can be pretty normal. But it shouldn't cause excessive temperatures for other parts. So while thinking about achieving a good balance of temperatures vs. noise, it's good to keep the entire system in mind, for example in a gaming scenario, and not only test full CPU load.
Each fan model has a different RPM range and therefore needs different values or voltages to reach a certain airflow. Also, each different PWM-controlled fan model can interpret the PWM signal differently. This is because some mainboards don't allow a PWM signal lower than 20% for example, to never have the fan turn off. So to circumvent that, a fan maker might decide to let the fan interpret a 20% PWM signal from the mainboard as "still turned off", and turn on at 21% PWM. Another fan might interpret 0% PWM as the turn off signal and 1% as the lowest possible RPM, or may never turn off and just map the entire PWM signal range to the lowest and highest RPM. And all variations in between.
Here's an example of an Arctic fan which has implemented a semi-passive mode, it stays off with any PWM signal below 5%:
These Arctic P12/P14 PWM PST are very good fans by the way, almost unbeatable in price/performance.
Another example of a fan with a semi-passive mode is this Noiseblocker one, which has the following PWM-signal-to-fan-speed mapping (depending on the variant):
Screenshot 2023-06-27 at 21-58-11 TData_eloopX120_de_en.cdr - TData_eloopX120_de_en.pdf.png
So for each fan model, you will need different PWM values (and for 3-pin ones, different voltages), but just go by airflow and noise.
And the concept of the fan curve is always the same.
Once you're done, it's a good idea to write down your settings or make a screenshot/picture of them (in the BIOS, F12 saves a screenshot to a FAT32-formatted USB drive).
Because whenever the BIOS settings are reset (due to BIOS update, CMOS Clear or empty battery), you'll need your notes or pictures to know what fan curves you had before.
Although in BIOS updates for newer boards, the fan curves are actually kept between updates nowadays, which is good.
Some of my other guides:
Guide: How to set good power limits in the BIOS and reduce the CPU power draw
Guide: How to find a good PSU
Someone asked me if they can thank me for my work by sending me something via Paypal: Yes, that's possible, just write me a message and i'll tell you my Paypal 😉
citay,
Thank you for the informative and instructive fan curve guide. I completed my first build a few days ago (after 20+ years of owning pre-built machines) and your guide enabled me to reduce my air cooled cpu temps to a comfortable level as well as making my system virtually silent. I am very appreciative of the many knowledgeable posters in this forum.
Windows 11, MSI z790 Tomahawk DDR5 WiFi, I7 13700K, 32GB 5600, PSU 850, EVGA Nvidia 2060
Thanks for the feedback, glad it could help you!
Hello Sir...
Great writing on the fan control
I need your help...I recently bought a msi z490 motherboard online.
Since powering it on, the MOS fan is spinning close to 12k RPM.
After searching online, I figured it is a known problem with no clear solution in any of the forums other than RMA.
RMA is not an option for me since I bought it used.
Thanks
Disable the VRM fan physically by unplugging/snipping the cable. In most cases, the fans are complete overkill. Those boards that use VRM/MOSFET fans, such as the Z490 ACE / GODLIKE, have an efficient VRM with Smart Powerstages, so there's no risk of overheating even with the fan disabled.
citay,
I am planning to swap out my air cooler for a MSI Coreliquid s360 AIO. Would the same principles apply to a liquid cooled system as you have described in your fan curve guide?
Thanks for your instructive and informative input to these forums.
Yes, any water cooling leads to air cooling in the end (at the radiator). Whenever you have fans moving air to transport heat away, you apply similar principles as to what i described in the first post: Low revs when the temperature is low, slowly ramping up when it increases, and only in the high temperature range ramping up more rapidly.
With a liquid/water cooler, there's two additional things to consider: First, the pump, usually it goes onto the PUMP_FAN header, but how you control it depends on the specific cooler. Check the cooler manual on what they recommend. Sometimes it wants to be run at full speed all the time, sometimes it can be RPM-controlled with a fan curve depending on the thermal load.
Second, the airflow through the case, because apart from the CPU, there's other components that can generate considerable heat, primarily the GPU. So it's good if your CPU runs cool, but you also need to be aware of the other temperatures.
Thanks for the feedback, always nice to hear.
Nice guide! Would it be possible to make the guide in to a document so I can print it off for myself?
Also, about my fans, I have 1 rear fan (SYS_FAN1), 2 top fans daisy chained (SYS_FAN5), and 3 front fans connected to the Corsair node plugged in to the USB header. Only thing I can do with the front fans is control the RGB lights. How can I have them spin down when the system is cool and ramp up when the system is warm?
I mean, you can select all the text and pictures, copy it into your word processor, and see what it makes of it. I had to make a bunch of small little edits to keep a decent readability here on the forum, because sometimes the automatic line breaks can make sentences or paragraphs look awkward. Also, sometimes i edit the guide when i think i could explain something better in a different way. So then i'd have to redo the document as well each time. So i think it's best if you just copy it into Word or LibreOffice Writer or whatever, and see what happens.
It depends what this Corsair node is for. If it's only for RGB, then only the RGB cables of the fans will go into it, and the seperate cable each fan has to power the fan motor will go somewhere else. You have to check that, an RGB fan will always have two cables, one for RGB, one for the fan motor (either 3-pin / DC or 4-pin / PWM).
The B550 GAMING EDGE WIFI you seem to use has a whopping eight fan headers, so you could plug everything into the fan headers on the board and have full control.
Okay, so for the RGB fans, the RGB cable would go on JRGB or JRAINBOW and the fan cable would go to the SYS_FAN header?
I'm not sure how I would do that. This is what the fans are connected to now.
The motor cable for the fans is connected to the Molex connector on the power supply. The RGB cable seems to be connected to the USB header.
Probably on a Molex-to-3/4pin adapter like this?
And the RGB controller is on a USB 2.0 header of the board, so the Corsair software can control the RGB effects, obviously.
What you do is, you take the fan's power cables off the Molex adapter and plug them into the free SYS_FAN headers individually, then you can control them all. You don't have to set different curves necessarily, but it's good to be able to control them individually if need be.
That's the one! Mine just has one wire, not 4. Same idea though. If I connect the fans to the SYS_FAN headers, would I still be able to change the RGB effects of the fans or just the motor speed? The motherboard user guide just shows the RGB cable and the motor cable but the fans only have the one 4 pin cable.
Thanks citay. some user experience here from my side, the bios has a minimum fan speed. Probably to avoid long durration over current. I was looking to turn them off on low temp, but I don't think I can... My fans are 4 pinned and after setting it and take a peak after a week or so, it is back setted to DC. I can't explane...
You can control both, they are independent. Meaning, if you were to only connect the RGB cable and not the fan motor cable, then the RGBs would turn on and you could control the RGB effects, with the fans standing still. Or if you were to only connect the fan motor cable, then the fans would run, but without any lights. If you connect both (to the right places), you can control both.
No, the BIOS has no minimum fan speed, it's completely individual to the fan model you are using. There can be no overcurrent drawn from the fan running at very low RPM.
With 4-pin PWM-controlled fans, each fan model will interpret the PWM signal coming from the motherboard differently. Of course, a 100% signal will always mean full speed, but how they interpret anything below that is completely up to them. Here you see an fan (Arctic P12 PWM PST A-RGB 0dB) which has implemented a semi-passive mode, it stays off with any PWM signal below 5%:
Another example of such a fan is this Noiseblocker one, which has the following PWM signal to fan speed mapping depending on the variant:
Other fans may stay off below 20% PWM signal. And a lot of common fans may just map the entire PWM signal range to their safe lowest and highest speeds and never turn off this way.
Of course then you can try to forego PWM control and attempt to use DC control instead. A lot of fan motors need a certain initial voltage to start spinning, and if you stay below that, they will not spin. There's a small problem in that the voltage to turn on is greater than the threshold at which the fan will turn off again once it's already spinning. What i mean by that is, for example it may need 4.5V to reliably start spinning, but once it's going, it will only stop spinning below 3.5V or so. So it's difficult to set a reliable curve like this. The best thing to do is to use 4-pin PWM-controlled fan models which clearly state that they offer a semi-passive mode.
edit: I also added some of this information to the first post.
Thanns for letting me know. I anley draw 50% off from the maximum speed I can. Db is my first concern, dust is my second. I can block it, but I prefer not too.
I know how pwm works, have a whol switching box of it. But DC, doesn't see unpossible with me. Curious wath you have to say.
Kr
Dave
@citay I've played around with the fan settings in the BIOS and I was surprised to see that when I set SYS_FAN1 to 0%, the 3 front case fans stopped spinning. I thought SYS_FAN1 was the rear fan.
Quick tip. I setup my custom curves for all the fans on the motherboard but then I also have Fan Control running on windows with almost similar curves, Fan control seems to override the bios curves. If you want to control them when in windows this is very useful. My system is still new and I wanted to check what happens to temps when and experiment with different fan speeds and see how the temperatures act. You can use this tool to finalize on the curves you want to set and set them in bios and stop using this if you want.
Fan headers are numbered, in most cases are numbers like a clock with one starting at top of board and so as you go clockwise around the board top will be one then two, three four and so on.
You can always find the SYS_FANx numbers in the manual.
Hmm, what mobo do you have? I have slide the curve in to the upper right corner and it was still spinning. But I dit the same thing as you, when I just setup my mobo for the first time. And then it did work. So what am I doing wrong. 🤔 maybe you toke a fix point?
