Guide to Realtek sound on NF2 boards (by backwoodz)
Assaf
GENERAL
First go to realtek and down load Windows 98Gold/98se/Me/2000/XP for Driver only A3.44 2003/05/26 4991k http://www.realtek.com.tw/downloads/dlac97-2.aspx?lineid=5&famid=12&series=8&Software=True
Now unzip the wdm files inside to a directory that you will easily remember
Now check out these screen shots of XP and how to manually update your NVidia sound drivers .....
They start from the My Compotor Properties
Navigate to the sound controllers
choose the device and go to it's properties....update drivers wizard
If the Realtek driver is not detected click on the have disk button
Now browse to the dir. where you extracted the wdm folder
confirm and ok
Exit........Now check for the Sound Effects Manager in control panel
I hopes this helps..a few.......MSI should have had this included in the manual.
K
kdmsant
Guest
thanks,
msi should give you credits for this
can't believe they announced the k7n2 with 5.1support if it is not fully supported
