Gungnir 110R ARGB controller
Hi! I want to buy a Gungnir 110R, but I have a doubt, I do not have a 3 pin ARGB connector in my mobo, and I want the fans to light up, do they work only connecting que hub that comes with the case to the USB port? I mean, will they work? connecting the 4 fans to the hub and the hub by USB, could I control the lights by the insta loop button that this case has?
USB port is not involved. The internal controller board can be connected with the fans' 3-pin RGB connector and to SATA power. You can then choose lighting effects via the button on the case. Of course no control is possible through your mainboard as it doesn't support a 3-pin RGB connection
