My laptop is about 6 months old and has worked perfect till now. I put my laptop away for 3 weeks and didn't use it for that time as christmas and new years was so busy. It worked and charged perfect when I put it away. So 3 weeks later I pull it out, and the thing won't boot up. I'm not certain, but I think it had near a full charge when I put it away. Anyways, I plug it in, and it boots up. The little amber battery light is on and solid (not blinking) and on the toolbar it shows 0% charge, but states "plugged in, battery charging". I think nothing of it and do a couple hours work and then without checking because I assume it should be charged, I pull the plug and the computer immediately goes black and I lose my work. I also tried to charge it while shut down. The charge indicator light is on, as if it is charging but it takes no charge. I have removed & replaced the batter, checked that it's secure and the latches closed. Booted up without the battery then shut down, replaced the battery and rebooted. Device manager shows no trouble, but I'll next re-install the drivers, but I'm confounded. Help?
One odd thing is that the "sleep state" light remains on even when I'm using the laptop. I don't remember if it used to be on, but I'd think it shouldn't if not hibernating.
Thanks so much for your help
