GX700 Display/Graphics adapter problem
59Hz
PRIVATE FIRST CLASS
I've recently purchased MSI GX700 Performance edition and found an intresting problem: I can't choose any other refresh rate than 59Hz.
It's annoying, but I still can play games and so-on I just have to edit game preferences... But it is relly annoying.
Any1 else having same problems? I have searched a lot and almost all laptop manufacturers has same kind of problems and atleast DELL has replaced whole laptop as it is clealy broken.
As drivers I have all the latest MSI drivers and as graphics drivers I have 169.28 forceware from laptopvideo2go. Thanks in advance.
59Hz
PRIVATE FIRST CLASS
Actually it does. When I'm trying to play... let's say Sins Of Solar Empire without editing it's configs I can't change resolution because it does not recognize 59Hz refresh rates.
imp_cat
STAFF SERGEANT
I don't think any other refresh rates are available. Mine always detects and displays 59 Hz.
Never had a problem with it though.
mArInE^
I have 59hz too and it should be atleast 60hz for Battlefield 2 to work so if someone has a solution to this I would be really happy. :)
Administrator
If you think that can help to solve the problem with Battlefield, just go to Nvidia Control panel and define your custom refresh rate for desired resolution.
Frankenputer
GENERAL OF THE ARMY
I would visit the Battlefield forums and support pages as well. You may be able to set a launch parameter to force a certain refresh rate.  Many games came be configured for special launch options(may be a special parameter set in the target field).
