I have following problem with the laptop:
on the screen I have sometimes some flickering. Like something kind of interference. It is short, but repeats all the time. Sometimes every couple minutes, sometimes every couple seconds. I check to power supplies and battery. The same.
I didnt notice it when display driver was not installed. And I had it like that for a day, although with resolution 1440x900. On the standard has no problem. GPU temperature in the iddle is 58 degrees, when I check Furmark, I reached 92 what is a lot! But at the test flickering ocurred very rarely. Anyway laptop is always very warm on the right side. When I open the case, the aluminum tile is also very hot as well as wifi card. This tile is only warm at the top. It sticks with the CPU cooler via thermal paste- arctic silver. At the same time CPU temperature is max 60 degrees (T9300).
What can be wrong?
Thanks in advance for your help
What can be wrong?
