H110M PRO-VH MS-7996 Bios and drivers problems.
xidia.co158402ed
* This is a copy from my ticket
Have some problems. I did buy this pc from a friend, and yes I can see it's a bit outdated.
1. I'm trying to use Intel graphics, I'm streaming so would use that hdmi input as a (chat display) because it doesn't really need high graphics. I downloaded all drivers from MSI website, also used live tool but doesn't install the Intel hd graphics. and as I understand it need to be a specific number on the driver. did try to use device Manager and install old driver, but it was like a lot from Intel, like Intel HD graphics 530,630 and so on. have try some but not correct. So I need help to get this driver and then also the rest because intel tool and msi live thinks I'm up to date.
intel(r) core(tm) i5-7400 ms-7996 gen
2. next part is the Bios update, used live tool, it says o got latest bit it isn't because on msi I can download newer for my motherboard. I also formated usb, but I got no usb options like it shows on MSI website (how to update) because Im not in the advance bios.
3. trying to get into the advance bios, reading on msi and other forum, and trying different combo but nothing, controll, left shift alt F3 or F7. when I'm looking at videos I can't really follow because the Bios looks totally different and some using same motherboard.
*Press delete at startup to enter Bios, At the BIOS screen Hold ALT, Hold Right Control, Hold Shift, And Press F2 while holding those 3 buttons,
Did also try to replace F2 to F7
I need everything that's for my pc, don't really afford new things.
Will post everything here becouse i really need things to work.
MS-7996 14 OPT:G H110M PRO-VH,H110,LGA1151,2DDR4,1PCI-Ex16,2PCI-Ex1,4SATA3,4USB3,HD Audio,Gb LAN,HDMH516656641
Please refer below to flash BIOS under DOS mode and maybe it is not support M-Flash funciton.
The link is on Special Note: "For Windows 7/ Windows 8/ Windows 8.1/ Windows 10 SOP" on MSI website.
Did just make a new post, but here is the result, stuck on MSI screen -
Had problems to update my bios and was finding out H110M PRO VH update from MSI page wasn't right, because I needed Codex 3. Downloaded it but still, got no flash alternative on this bios, so did find a tool on this forum to flash. Did follow instructions and the update of my bios was successful, after it asked me to reboot anf I'm stuck on MSI screen.
1. I did go to bios settings and reset to default = nothing
2. Unplug all cables and removed the battery for about 1h = startup screen tells it's reseted but still end up on MSI screen.
3 plugged in usb stick with windows 10 Installation, press F11 and then klick on my usb = it freezes.
4 inserted Plop boot loader CD, doesn't start.
No hidden bios settings is found or I don't really know how to get them.
Had problems to upload photos on bios but sharing from GDrive
8uQjLOX
1.Please provide picture for all information in BIOS setup.
2.Please use Microsoft utility-Create Windows 11 installation media for creating USB installation disk first and then use it for reinstalling windows 10 OS.
3.Please refer below steps to load default in BIOS setup.
Step 1. Please insert USB installation disk on this system.
Step 2. Please into BIOS setup.
Step 3. Please press "F6" button in BIOS setup for loading default setting.
Step 4. Please press "F10" button in BIOS setup for saving changes and exit.
System will be rebooting once.
Step 5. Please press "F11" button during POST and it will be showed boot device menu.
Step 6. Please choose the USB installation disk for installing Windows 11 OS.
Requested photos is uploaded here https://drive.google.com/drive/folders/15wrugHDDCjefT9ytaKcZPvD4Uso74GuH .
I have try with disable windows 8.1/10 whql support
Same with secure boot but nothing and to select windows 10 USB stick as boot prio 1 but didn't work, when I get to boot option by clicking F11, it freezes.
Thank you, will will try with this, so I replay when I have fixed a windows 11 installation drive and trying this one, thx !
Uploaded a video in folder (15 July update) still stuck. And MSI support asking about Intel graph but I have no installed, that what's the main problem, maybe the graphic card blocks but how to enable it when it's no options, did from start try to install Intel hd graphics for my motherboard, also for Codex 3 but ended up on (not supported) and then I was thinking, maybe because my bios is not updated.
Msi HQ flash tool was used and inside my stick i got recoveryBios.bat but don't know how to use it
https://drive.google.com/drive/folders/1kfqkhNAu2bEoDc_DrRGVB2QKdV1GIeRq
It have been flashed to latest BIOS -"EB913IMS.861" so i think this symptom is not related BIOS.
Please refer below link to install Windows 11 OS on this system.
How To Install Windows 11! - Your COMPLETE Guide, Step By Step!
Have done exactly like that, but it freezes. And like you told, it use desktop Codex 3 but support tells me to use the motherboards bios update. Doesn't help when I not got a m flach,
Again!!
Please refer below to flash BIOS under DOS mode and maybe it is not support M-Flash function.
Please contact support again.
