djloon1156e02dd
- Jun 5, 2022
-First thing my laptop is out of warranty, the paints have faded on the palmrest and I opted to buy a replacement one all black because after searching I had found thath the case for alpha 15 a3dd was similar to the gl65 leopard and some other models. also had some paint fading on my keycaps and found an aftermarket replacement part. Purchased and installed succesfully even the trackpad is working okay. but this might be a stupid question. My original backlight or keyboard was all red not RGB the replacement keyboard I bought from aliexpress was branded as colorful, not per key RGB. I wanted to know if is there any way to activate through software or color controls for this issue. I am not sure if it is an actual issue becuase the original was all red and will it only support red or do I have an option to force change the color of the keyboard. I had intalled various steelseries gg versions also the older steelseries engine 3 as well as resetting my EC firmware to no avail. wanted to check in with you if anyone can help me try to activate colorful mode for this keyboard. thank you
