rdy12157c02d8
- May 5, 2026
recently was able to get my system together and I’m at a bit of a loss as to what’s gone wrong here.
Specs:
Ryzen 5 7600X
MSI PRO B650M-A Wifi
ADATA XPG Lancer Blade 16gb DDR5-5600 CL46
Gigabyte RX 7600 XT Gaming OC
WD SN750 1tb
Corsair RM750 Power supply
I was able to get everything but the GPU built up a few days ago and the system was working no problem, was able to get into the bios fine and install windows. The system was working with no problems. When my gpu arrived I added it to the system and for the most part things work ok. I had some instability that updating drivers seemed to resolve, I was able to benchmark the system and do some light gaming with it.
I started to notice that the system was behaving really strange on startup, the case fans would start up fine but the Gpu fans would try to spin at 15%-20% power for 10 seconds before stoping for 30-40 seconds and then repeating this cycle. My monitor would indicate no output and I wasn’t getting loaded into bios or any other signs of life from the system. This would go on for minute or two before the monitor would get the PC’s output and start up as normally.
After this issue developed, I also noticed that the Motherboard’s Ethernet adapter would randomly stop working. It would give an error that no cable was plugged in despite one being in the system. I tried updating the drivers but this didn’t solve the issue. The adapter would work for 1-2 minutes after startup but then completely stop. Restarting the system didn’t solve the issue. My errors were similar (but not identical) to the ones in this thread: https://forum-en.msi.com/index.php?...-onboard-devices-randomly-malfunction.396071/
This beings me to today when the system completely stopped booting up. The GPU fan cycle just continued indefinitely with the monitor never receiving an output. I noticed that I was getting two debug lights on the motherboard, a red CPU and yellow RAM light. When the lights came on was not consistent at all, sometimes both of them went out while other times some of them stayed on. I tried booting with the ram sticks removed and swapped places and made sure that they were fully seated each time. I then tried to boot the system without the gpu as my problems had only started after the gpu was installed. This didn’t solve the issue and the debug lights remained.
At this point I’m thinking/hoping it’s a motherboard issue, but I really don’t understand how the system can be fine one day and completely non-functional the next. Any advice would be greatly appreciated.
Specs:
Ryzen 5 7600X
WD SN750 1tb
