HDMI output issue on GTX 1650 Super
I just got a GTX 1650 Super yesterday. I have the display port connection going to my pc monitor, and the hdmi output going to my tv. The monitor connection is rocksteady but the hdmi connection, picture and sound, blanks out every few seconds. But when I disconnect the display port connection, the hdmi output stabilises. It stays that way even after I reconnect the display port connection. But the next time I start the pc the same thing happens again. I have Geforce driver 456.38 and Geforce Experience driver 3.20.5.48 installed, which I believe are the latest drivers. Is there a way to get the hdmi connection working properly without having to remove and replace the display port connection?
Connecting a TV with hdmi is in many cases an adventure. Does the same happen when connecting the monitor with hdmi?
M
My monitor uses Displayport, and this works fine. I'm getting a new monitor tomorrow which has dual hdmi inputs so I can check when I get it setup.
A monitor should be no problem, lets see
makalanda2156102e2
Hi, I also have the same issue my HDMI signal to the monitor drops randomly all the time I also have the same card (1650 Super Ventus XS OC) did you find any solution to the problem??
