Hear strange sounds inside machine
Hey guys, I have a question, I have an MSI Modern 15 A5M, but these days I have heard a squeaking sound in the machine (listen carefully in the area charging slot), even when the fan is off, it can still be heard, when plugged in, the sound is clearer, but you have to get closer to the screen to hear it clearly, and when you unplug the charger, you have to put your ear to the device to be clear. So is it broken?
Sounds like the coil whine.
Contact the MSI support if the squeaking is very obvious.
In fact, to detect it, I had to bring my ear very close to hear it clearly. I think it's the problem, because every time I plug in the charger and use the battery, the beeping sound is different
next3r
MAJOR
try disable c-states ,,.repair is C-state noise ramp / or custom setup
BIOS/ADVANCED - try disable c-states "verify problem" for intel
// i not recommended fully disabled c-states "this is only for test"
repair is "repair is C-state noise ramp / or custom setup "
Hethdra_0328
Then it shouldn't be that obvious if you have to bring your ear very close to it unless you stay in an extremely quiet room.
I'm not sure, but I didn't hear it when I first started using it, I just recently encountered this phenomenon
