Heat sink reapllied then Mem Detection Test keeps it from booting
scooter787b
LIEUTENANT COLONEL
Hi guys, remember me, anyways i decided to use the snesor function on my Heatsink which goes under the processor, and since ive done this, i get LEDs saying Memory Detection Test, i know this can be caused by a number of things, and dont blame my ram or tell me to get new ram, cause it works great until i did the operation, do u think the sensor under the processor is causing this?what should i do?
Deathstalker
GENERAL OF THE ARMY
scooter787b,
Welcome back to the forums.
Reseat the CPU and the RAM. Also try one stick of RAM. Just because the RAM worked before, do not rule out that it went bad, it has been known to happen.
Take Care,
Richard
scooter787b
LIEUTENANT COLONEL
im not exactly an amatuer at this, so ive all ready done these steps, i also removed the sensor so the fan goes at full speed, but i still get the message, i doubt its the ram as it was working this morning, just after i tried installing the sensor function it gave the error
scooter787b
LIEUTENANT COLONEL
what else could cause this, also something strange happened to my moms computer last night, while i was on the net, the screen turned black and said Windows Protection Error or something like that, it then said to restart, and press any key to resart, so i did but then i couldnt access the net, i checked to see which files had been modified last, and system.dat was one of them so i opened it up in word, and saw Creg as the first word, was this a attack on the computer or just normal :( ,so i reinstalled windows, internet works fine this morning though just to let u know
Deathstalker
GENERAL OF THE ARMY
scooter787b,
With your mobo, try a different Vid Card, just to see if you can get it to boot.
As for your mom's, did the have the latest patches so she would not get hit by the attackes or at least is she behind a firewall? Could it be she opened an email with a virus in it?
Take Care,
Richard
scooter787b
LIEUTENANT COLONEL
well on my moms i have zone alarm running now, and the computer last night just gave me the message^^, ill try a different video card i have a Geforce 2 Mx400, ill try it any other suggestions, :help:
Deathstalker
GENERAL OF THE ARMY
scooter787b,
Once you get as far as the BIOS, try 4X AGP and try flashing to the latest BIOS for the mobo.
But till you can get it to boot, that is no help at all. (That was why I suggested trying another Vid Card.)
Take Care,
Richard
scooter787b
LIEUTENANT COLONEL
hi again, i swapped the vid cards, but to no avail it did not boot, but i still get the error message, this is really depressing, and let me say again everything was working fine, until i tryed the sensor function on my fan, could i have hurt the cpu it seems fine though,
Deathstalker
GENERAL OF THE ARMY
scooter787b,
Pull the Power Cord out of the Power Supply and the Battery from the mobo and wait a good 15 to 20 minutes before putting them back.
Lets see if it resets the mobo and lets you boot.
Take Care,
Richard
scooter787b
LIEUTENANT COLONEL
ok, i waited, but it still wouldnt boot after i reinstalled the battery and cord
:wall:
Deathstalker
GENERAL OF THE ARMY
scooter787b,
Do you have any other brand of RAM to try? If that does not work, what about another CPU for testing purposes?
Take Care,
Richard
scooter787b
LIEUTENANT COLONEL
sorry, no im only 15 with like 5bucks in my wallet, and all our other computers are old using 133mem on a PII and an non funtioning K6 processor
Deathstalker
GENERAL OF THE ARMY
scooter787b,
See if you have any friends you could borrow some RAM from.
Take Care,
Richard
scooter787b
LIEUTENANT COLONEL
i doubt that, all of my freinds arent as technically inclined as me when it comes to computers so they usually buy Gateways or Dells, their is one guy i could ask, but he usually acts like a know it all
also if i do get it to boot what should i do?
B
backwoodz
Guest
scooter have you tried clearing cmos and try it with set j11 removed to defaults......100fsb?
Deathstalker
GENERAL OF THE ARMY
scooter787b,
You could try a local computer place and see if they will lend you some RAM for troubleshooting. (Just bring your computer with you to the shop so you can test it there.)
If that is not an option for you, just RMA the board and hope there is something wrong with it.
Take Care,
Richard
B
backwoodz
Guest
Does the system beep at all?.......do the fans spin up and any hd activity?
Did you set j10 jumper to pins 1-2 and remove j10........remove power cord from source.......set cmos jumper to clear.......now press and hold the power on switch for 4-5 secs....set cmos jumper to save......and plug the power cord back in....try to see if it boots.............TRY THIS EXACTLY IN THIS WAY................also try it with just one ram at a time.
