Heat sink reapllied then Mem Detection Test keeps it from booting
scooter787b
LIEUTENANT COLONEL
id just like to thank you for everything said in this thread first, I know one place ill see if they can help me, i dont think i can get the ram, sad to say moneys kinda tight right now, but ill ask around
scooter787b
LIEUTENANT COLONEL
id like to thank everyone, and no beep; fans work, sounds like HD is working and ill try that
scooter787b
LIEUTENANT COLONEL
:biggthumbsup: :beerchug: yeah!!!!!! it booted except it says the checksum error-defaults loaded, what to do now?
B
backwoodz
Guest
tell what you did?............the checksum is from a cleared cmos......means time and date and such needs to be set.
B
backwoodz
Guest
If it booted from what I told you then....save bios defaults and....turn it off....set j10 back to pins 2-3 and replace j11..............now reboot and set bios as needed.
scooter787b
LIEUTENANT COLONEL
:beerchug: id buy u guys drinks if i could, its up and running now, yah!!, i dont think ill mess with the sensor thing or should i? :frankie:
B
backwoodz
Guest
as for the drinks lets make it lemonade........and lets see A's on that report card.
AND Save your money.
Deathstalker
GENERAL OF THE ARMY
scooter787b,
That is great news!!!!! So glad you were able to get it to boot again! :biggthumbsup:
Take Care,
Richard
F
Frogg
Guest
Originally posted by scooter787b
Hi guys, remember me, anyways i decided to use the snesor function on my Heatsink which goes under the processor, and since ive done this, i get LEDs saying Memory Detection Test, i know this can be caused by a number of things, and dont blame my ram or tell me to get new ram, cause it works great until i did the operation, do u think the sensor under the processor is causing this?what should i do?
Please excuse me if one of the other replies answered this; I did not take the time to read them all.
AMD's Builders Guide notes that the thermal interface material on the bottom of the heatsink is very fragile. It also notes that you must replace it it it becomes at all damaged. They give a source for material. The Guide can be found at http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/26003.pdf.
If the film is damaged, and, if you have run for very long in that fashion, you may have developed CPU problems. These can cascade thru your whole system, damaging the RAM and the Northbridge and the Southbridge. I know that that is not a very comforting thought; but, first, fix the thermal interface, throw some powdered batwing over your shoulder, and hope for the best.
scooter787b
LIEUTENANT COLONEL
sweet i didnt even notice my thread had been added to the important thread sections, sweet :biggrin:
