HELP! After BIOS update there is nothing on screen.
skalosadamk15c002e2
I have H110M PRO-VD PLUS motherboard. Yesterday I bought RAM upgrade and today I decided to update BIOS. Update was successful, it rebooted and there it was. Black screen, when I plugged in keyboard it turned on for second, you can only turn off PC only when you hold ON/OFF button for 5 seconds. I searched a bit, everywhere it says to press flash button, but on this type it isnt there. So how do I downgrade it back without keyboard and screen and flash button?
What BIOS you have flashed to and how? Also what was your old BIOS version?
Does the BIOS update complete successfully?
List full system specs, see >>Posting Guide<<
So I had this PC from school, they were removing them. I brought one, bought RAM, inserted HDD and prayed for best. It booted up to bios, I installed windows 10 and it worked. Then I updated BIOS and it died. I think that I somehow bricked it, im not best at BIOS.
I flashed from v7996v2F to v7996v2H using M-FLASH. It said that update was succesful, it restarted and the problem was there
Specs:
Board: H110 PRO-VD
BIOS: old v7996v2F, new v7996v2H
GPU: intergrated intel
CPU: i3-7100
PSU: White Energy ATX500W
RAM: 2x8GB 2133mHz
MOUSE: Hama MW300 v2
KEYBOARD: Some generic one
MONITOR: I used TV for testing, plugged with VGA from motherboard
