Help! Dragon Center messed up up my default Fan Speed options
singson_luis_gabriel
Before installing the app, my fan would automatically turbo boost when gaming. And it would automatically turn off after gaming.
After installing Dragon Center, I set the settings to Extreme Performance ( turbo boost on fan always )
now, I wanted to uninstall the DC. After Uninstalling, my fan is stuck to turbo boost.
- Does resetting BIOS settings to default help revert all changes made in DC?
- Some said I should uninstall one_SDK but I cant seem to find it on windows search anymore.
If I uninstall Dragon Center. should I also uninstall the drivers I downloaded in the update section of the app?
Thanks
Your thread is not readable, don't use custom formatting. Fix that. If done also add what MSI hardware product your thread is related to.
Reposting:
Thanks
cpu: i5-9400F
mobo: Msi  mag mortar b365M
gpu: zotac 2060
If the software is gone no setting can be left. Check the bios for what is set there regarding fan speed.
