henrik-erns155702db
- Apr 15, 2025
can anybody help me out with this? I have tried a couple of different modules already and also turned on tpm in bios.
ty
ty
Hey,You don't need a discrete TPM module.
Just enable the firmware one.
Read this article: https://www.msi.com/blog/How-to-Enable-TPM-on-MSI-Motherboards-Featuring-TPM-2-0
thanks for the quick answer! I already enabled this option and as you can see in the screen shot my system doesent find any secruity device...
yoooo thanks so much man, didnt do the obv thing <.< its working nowIs your BIOS up to date?
https://www.msi.com/Motherboard/B550M-PRO-VDH/support
After "Security Device Support" is enabled (AMD CPU fTPM), press the F10 key to save and exit BIOS. Reboot and you’ll see the TPM version.
