help if possible x570 prestige creation motherboard bios update
jinkscharlie
OK well updated bios through the creation centre clicked install then screen went black computer rebooted then after about 10 to 15 mins it turned off then nothing so i turned the computer back on and now screen goes to light up but then nothing and i get error code F8 on the motherboard any help would be grateful i have never had this problem before thanks in advance
plutomate
Active member
MAJOR GENERAL
the board does not seem to come with flash bios button or multi-bios function, so your best shot is to clear CMOS and see if it can boot into bio somehow
flyingv2815b702e7
Active member
You also try the boot block recovery method.
Boot block, part of BIOS that doesn't usually get updated so stays intact.
In the old days it took a floppy drive with MSI.ROM file. (File renamed)
But I think it has been updated to support USB drives.
Google it.
Active member
According to the manual (always the first thing you should look at), https://de.msi.com/Motherboard/support/PRESTIGE-X570-CREATION#down-manual
Code F8 means "Recovery PPI is not available". This is an error pretty early in the boot phase, during initialization. That's why you don't see anything on screen, it didn't get to that point yet where it displays something.
We can assume something went wrong during the BIOS update and now it's corrupt. That's why i would never update the BIOS from Windows. Always enter the BIOS, go to M-Flash, and flash the new BIOS there with the new BIOS file on an USB stick.
It seems that your board doesn't have a USB Flashback port or some other function to restore the BIOS. So you can only try a couple things. Remove all power, and short the Clear CMOS pins again. Take out the RAM and try to boot. If it's still stuck at F8, it's gonna be more difficult.
jinkscharlie
thanks i will try that now and tried all msi said but goes straight to F8 thanks i will let you know :-)
Active member
According to this post, the "MSI.ROM" trick doesn't work on this board, https://forum-en.msi.com/index.php?threads/prestige-x570-creation-wont-post.332676/#post-1967497
You can contact that user and ask if he found a solution.
So that leaves very little options. I think you may have to contact MSI service and explain the situation, or contact the seller of the board. It was not your fault, you just used an MSI program that offered to update the BIOS. You didn't know that flashing the BIOS via M-Flash is always better. Maybe your system wasn't fully stable and the update failed because of that. We'll never know now. But if it never gets past F8 code, and you can't force-flash the BIOS, you're a bit stuck.
jinkscharlie
hi yes i bought from amazon but says msi supplied it they just sent a link but i dont think they understand think its best just to rma the board but guess its going to take weeks and thank you for your help
Active member
Amazon can either be the seller themselves ("Sold and shipped by Amazon") or they can just be a selling platform ("Sold and shipped by SHOP XY", "Sold by SHOP XY and shipped by Amazon").
Depending on those things, you either have to deal with Amazon (first case), or with the actual seller (latter cases). That's what they probably mean.
You could also do an RMA process, but this is then a warranty service from the manufacturer MSI, not the actual shop you bought it from. I would always try talking to the seller first, if the purchase date wasn't too long ago. If the purchase was a year ago or so, then it's better to talk to the manufacturer for a warranty claim.
jinkscharlie
jinkscharlie
hi yes the board is 8 months old bought through amazon from MSI so i'm going to RMA it lol thanks for all your help at least i had a go but will use USB in the future £500 pound board with no flashback never mind and thanks
