- Dec 1, 2019
Hello, forum
I would like to find out how thick thermal pads should be to cover VRM section. I've read that I need to replace thermal grease (white and sticky stuff on VRMs) with thermal pads to get better temperature results. I have a picture here
There is that white stuff. Also there are Pink thermal pads in the top right corner but they don;t seem to be touching the heat spreader that sits on top of them. There is no print on them.
Please let me know how thick should the pads be in order to replace white thermal grease? Also tell me how thick should be the pink pads? Should that help with VRM temperatures?
Not even sure why MSI didn't go with pads instead of white grease straight away...
Also I'm planning to use liquid metal on CPU + GPU, but I'm not sure how often should I reapply it afterwards? Some say once every 2-3 years. What you, guys, think? I would also appreciate if some1 will share his experience with it. Normal paste vs Liquid Metal experience may be? I've done some research but there are still questions. Any help would be much appreciated!
That's why I use TG's Minus pad8 thermal pads or Phobya Nano as alternative.
