- Oct 20, 2014
Hi all i need help for a big problem...
I have a new system with Z97 Gaming7, i7 4790k (stock for now) and my old Sapphire HD6950.
I have just install windows 8.1 with the old PC and when i replace with the new component all start and work perfectly!!
Well, when i try to reinstall windows 8, because i wanna a clean installation of OS, after the first reboot i have a blue screen (error is refer a atikdm) and reboot...then is impossible to continue. SO i think that there is a problem with my video card and try to start with intel graphic.Well Installation complete then Update system.
Now try to insert my vga but at login i have always blue screen and reset.
I can only boot in safe mode. I try also another vga nvidia gt 430 and system start.
Why now i have this problem with hd6950???
I have update the last bios (1.6) and try also to install ubuntu to try if vga is damaged... but its ok!!
I need your help!!!
EDIT : Windows 7 run OK
I need your help!!!
