mdubose157702d5
- Jul 13, 2026
Hey everyone, I’m dealing with a frustrating POST issue on my desktop rig and could really use some expert advice.
My Specs:
Motherboard: MSI MAG X870 Tomahawk WiFi (with EZ DIGI-DEBUG LED)
GPU: AMD Radeon RX 9070 XT
OS: Windows
The Problem:
My system is stuck in an endless boot loop and absolutely will not POST. I have no display output and I am completely locked out of the BIOS.
The Symptoms:
The motherboard debug LED never reaches the OS handoff or the CPU temperature display. Instead, it constantly cycles through this exact sequence of codes over and over: 16 -> 0A -> 8A -> 85 -> F3 -> 4F -> 88.
From what I've researched, 16 is pre-memory initialization, 4F is DXE IPL, and F3 means it's looking for a recovery firmware image, but I can't get the system to snap out of this loop.
What I’ve Already Tried:
I completely removed and reseated both sticks of RAM, but it didn't change the behavior at all. The loop continues exactly as before.
Has anyone successfully recovered from this exact sequence? Should my next step be trying to force a blind BIOS update using the physical Flash BIOS button on the rear I/O, or does this look like a hardware failure with the motherboard or the CPU's memory controller?
Any help or guidance is incredibly appreciated!
My Specs:
OS: Windows
The Problem:
The Symptoms:
