jdepaula815ec02e8
- Apr 9, 2026
After switching components from a dead Asrock board to this new MSI PRO B850M-B GEN4, the system fails to POST. Upon powering on, the EZ Debug LEDs for CPU (Red) and DRAM (Yellow) light up for about 5 seconds and then turn off. However, there is no display output (tested HDMI and DisplayPort) and no keyboard activity (Caps Lock/Num Lock lights do not respond).
Steps already taken:
Does anyone have experience with Zen 5 (9900X) and this specific B850 board regarding AGESA versions or specific Corsair Vengeance compatibility issues? Any advice on forcing the integrated graphics to initialize?
System Specs:
- 1- Flash BIOS Button: Can't update the BIOS using the external button and a FAT32/MBR USB drive. When I press the Flash BIOS button, the power goes on for some seconds, then turns off and the white LED blinks slow for 3 seconds, then it turns on again and the white LED begins blinking faster for several minutes with the red CPU and yellow RAM LEDs on. After that the system auto-rebooted, the EZ Debug LEDs turn on and then off, but no video signal.
- 2- Clear CMOS: Performed via both the dedicated button and the JBAT1 jumper.
- 3- RAM Configuration: Tested with a single stick in slot A2. Allowed the system to run for over 10 minutes to account for DDR5 memory training.
- 4- CPU Check: Reseated the CPU and verified the mounting pressure of the cooler (loosened slightly to avoid socket deformation).
- 5- Peripherals: Tested with different HDMI and DisplayPort cables and different monitors.
System Specs:
- Motherboard: MSI PRO B850M-B GEN4
- CPU: AMD Ryzen 9 9900X (Zen 5)
- RAM: 64GB (2x32GB) Corsair Vengeance DDR5 6000MT/s
- PSU: Gigabyte Gold 850
- GPU: Integrated (testing via HDMI/DP) and Dedicated MSI GeForce RTX 3060 Ventus 2x 12G OC
