HELP! MSI PS42 Modern 8RC Creation Center Not Installing
S3ndN00bs
Hello! I uninstalled my old dragon center and tried to install the new creator center but no luck. Any suggestion please? Ty!
next3r
Active member
MAJOR
Crazydonkey
SECOND LIEUTENANT
What process was failed?
Also delete C:\Program Files(x86)\MSI\Dragon Center before reinstall Creator Center.
And remember to extract the file before executing the installer.
S3ndN00bs
and must full clean old dragon center ,,check all MSI app in your system
hidden folders
C:\ProgramData\MSI
C:\Users\your account\AppData\Local MSI folders
test only check windows control panel ,,uninstall "check MSI apps"
or send screen --send more info SAfe remove or not
all is safe remove /reinstall :D some UWP -- new SETTING windows UI --modern apps --uninstall
Hallo! I really appreciate your suggestion and managed to install it somehow. But now, I don't see any figures in my GPU counter. You have any idea to fix it? Ty in advance!
S3ndN00bs
Crazydonkey
SECOND LIEUTENANT
Could you see the GPU info in Task Manager?
If not, reinstall GPU driver with DDU tool and try to reset EC.
If the GPU info is still missing in Creator Center, try to reinstall the APP again.
Hi, how did you get it to work? I have the exact same issue, every time the install just says completed after 18%, I tried deleting all the hidden files too.
