Help needed for Liberator GP10 footpedals
Recently got my order for the MSI Liberator GP 10 foot pedals from kickstarter. Got two of them to better run this game I have involving space flight but only one seems to be working when imputing commands. I assigned everything the space bar to try and see if it'll work and the pedal plugged into the computer works fine, the other one I'm trying to get going.
teletubby_po
To infinity and beyond.
FIRST LIEUTENANT
how did you connect the two pedals? they have to be connected to each other to work. also can you share a screenshot of your macro settings?
by not working you mean the macro is not executed?
Right foot pedal is connected to the computer to the IN port. then a cable going OUT of the right and IN to the left. which gave it power but that's it. and the macros I have are all "Space" bar for 0ms. I just needed to see if they'd work. which the Right one did, left did not.
teletubby_po
FIRST LIEUTENANT
does the left work when you connect it alone?
teletubby_po
FIRST LIEUTENANT
so it seems like the pedals have to be connected to the system before you execute the liberator control application. can you try this again?
