Help needed with S/P Out
  • Thread starter Thread starter lld_eman
  • Start date Start date
L
lld_eman
Guest
:help: I have the SPDIF connected to a dolby digital receiver and have the latest driver from MSI for my K8T Neo-FIS2R. I can get sound from from the front left and right channels, but I get nothing from the center or surrounds. Can someone tell me what I am doing wrong?
I have now downloaded the latest drivers from Realtek and it still doesn't correct the problem.
I also have the issue that has been mentioned over and over in this forum. I do NOT get HDD LED activity from my HDD's on the VIA RAID channels. I do get it from the IDE DVD+RW drive. I thought I read a thread that said that MSI was going to fix this in a new BIOS update. IS this true????, or was I dreaming? I also thought I saw where someone mentioned a RAID LED pin set, where is it, I cant find any reference to it on the board or in the manual.
That's because the S/PDIF output (both coax and OPT) is only silly 2 channel. Don't know why they always do it that way, but it's probably much cheaper. Get a better saundcard. Thats the only solution if you want real surround from the computer.
my HDD LED doesn't work on VIA SATA controller either, i have no idea what the RAID LED pin set is. I have to use JP2 because my HDD LED Is 3 pin plug (only 2 wires though ???-))
meanwhile i also get no HDD LED from my DVD Writer on Secondary Slave
my config is as follows
VIA SATA 1: Seagate 120GB Serial ATA
Promise Controller: Disabled
Primary Master: None
Primary Slave: None
Secondary Master: Auto (DVD Writer)
Secondary Slave: None
???-) Isn't 2 channel audio only out of either/both spdif and optical kind of like false advertisement? I mean, those connectors were designed for and used for, as far as I know, only Multi channel (5.1 or 7.1) audio connections to devices usually designed to decode Dolby Digital or DTS? By adding them to the mobo, they create the expectation that the built in cound card CAN reproduce these 5.1 signals. And what about the drivers, the sound manager even allows you to choose 5.1 configuration. and then the speaker test in sound manager goes as far as letting you click on the surround speakers and SW and center channel to test them....but no output from sp/out....???..... I get a signal from the center out mini jack connection for center and rear surround.. why not the sp/out? (I have not tested the optical..
And since noone can tell me where another HDD LED connection is, I guess I too will continue to use the IDE connection even though I think this is a shame! :wall:
Scottg26, I have my DVD on the primary as master and I DO get HDD LED activity when it is running, I had not tried on the secondary.
If you use a software DVD player you can get 5.1 surround out of the S/PDIF connector, but other sounds are only in stereo and yes, it's a little false advertise and not much info about it. It's true you can get 5.1 DD surround, BUT, only when using the softwsre DVDplayer.
NForce2 boards had great sound with soundstorm. Think it's sad NVidia is going to stop including their great sound at the moment.
You can always use the analog connectors. That should give you 5.1 sound always, but i'm not quite sure about that, but that's still a very bad solution. I have 12meters to my surround receiver and a analog signal would be really crappy if I had to use that.
i may try to change cables one day, see if it works, however LG's firmware update only works for secondary master (or so it says) so i may just leave it. would be nice to get the LED to work for the hard drive, im kinda picky about these things lol
