HELP UPDATING THE GRAPHICS CARD
Hi! No one in the Customer Support helps me so I need to come here. I have an Aegis 3 vr7rd-002eu (7th gen... basically this one: https://www.game.es/msi-aegis-3-vr7...16gb-2tb-hdd-256gb-ssd-w10-pc-hardware-135111) and I need help with the info about the update as there's no info at all about what you can exactly upgrade (more than that upgrade video that doesn't help at all) and how.
Ii'd like to upgrade the graphics card for a series 30 one. Does anyone know if with my gabinet and stuff, which cards I am able to install. I mean, the RTX 3070 is too big, but maybe a Zotac one fits. Can anyone help me? :/
Thanks in advance.
badboy2k
no 3070, 3080 or 3090 will work in that due to the Power supply as its too low a wattage unit and the current 30 series cards are power hungry like all RTX 3070's pull 220w alone and your PSU in your machine is only a 450w bronze PSU and you need at least a 650w Gold PSU or higher to use that type of GPU.
Then changing the power supply would make it working, right? Which one should I get to fit this gabinet.
And even with the right power supply, does my gabinet have space for a RTX graphic cards? Because I saw Zotac one and it should fit, but I need to ask because you know more about the topic (right?).
