Help with CoolerMaster HAF 700 best Positive Negative Cooling setup please.
Hey guys. I ordered this case for my new dream pc build, it's arriving tomorrow. I might be getting a computer shop to build it for me.
I'd like to ask your advice on the best positive negative pressure setup. I'll probably be installing as many fans as possible for maximum cooling.
Ok so I looked at CoolerMasters included fans. They aren't the best models. They have better ones for high airflow and better ones for higher static pressure.
What I'd like to do is tell you about Coolermaster's 3 types of better models of fans and then you tell me whether I can use one type or all fans in various places in the case.
First fan. Mobius 120P, 75.2CFM, static air pressure 3.63mmH20.
Second fan. Mobius 140P, 76.05CFM, static air pressure 2.3mmH20
Third fan. MasterFan MF140 Halo², 59.51CFM, 2.53mmH20.
The first or the third fan would probably be best for the AIO cooler with their higher static pressure. The arctic AIO cooler's fans are 69.90CFM, 2.00mmH20 static air pressure.
So what do you think ? I would be keeping the two 20CM front fans, installing fans along the bottom and the side of the case. Also because you can install two radiators at the top you could effectively have 6 fans at the top.
I would only be installing one AIO, but could have push pull configuration, and then have fans on the other side for exhaust ?
The question is which fans for intake or exhaust, which fans for best positive pressure or best negative pressure. Can you help me plan it out ?
Picking out the best fans for high airflow and putting them in the best place. Picking out the best static pressure fans and putting them on the AIO cooler.
So I wouldn't be using arctics fans. I'll probably buy the CoolerMaster fans and put them where you all would beat recommend them for best performance.
Hi
If I'm honest, your best bet would be to ask on cooler master forums. Folks there are more likely to have used this specific case.
