Help with monitor set up
gilesle155902dd
I have just purchased aa Msi infinity pc for Christmas and x2 Msi monitor. They come with hdmi and only x1 hdmi port in pc what ?splitter will I need to be able to use 2 monitors. 1 for gaming and the other monitor for discord or internet.
badboy2k
what MSI monitor did you get as if your using 2 of them 1 should be HDMI and the other you should connect with a Displayport Cable as both should be coming off the Dedicated GPU?
gilesle155902dd
Optix AG321CR 31.5 inch, Full HD, 1ms, 165Hz, two of these. I think they both come with hdmi cables.
badboy2k
each of the 2 should have came with 2 Display Connection Cables 1xHDMI and 1xDisplayPort check what came in the box and locate the Displayport Cable and use that for one of the Monitors to the Dedicated GPU or if you get each one you can swap to 2 Displayport cables.
for your Monitor:
Display Port: 1920 x 1080 (Up to 165Hz) <-- that allows full Refresh Rate
HDMI 1920 x 1080 (Up to 144Hz) <-- that limits Refresh Rate to 144Hz
