Help with MSI MPG X570 Gaming Pro Carbon wifi, is dead?
Good evening everyone, I managed to get a board described above, however I believe it will be dead, if anyone can help, I would appreciate it.
i used with a ryzen 3600, weak gpu hd 5450 and a hyperx ram 8gb 3200mhz just for testing.
I tried several bios all updated through pen with nothing on the board, it then with the minimum described above, turn on the chipset fan runs at maximum, the cpu fan also heats up, the leds light up, but the gpu fan does not run and there is no image, there is always the cpu light in ezdebug on without turning off,
I don't know if what I wrote will be enough, any help will be appreciated, thanks
Pro
What's your PSU (model and its age)? Did you connect the 8-pin EPS12V cable to CPU_PWR on the top left of the board?
When you updated the BIOS using the Flash BIOS Button, did it flash for 5-7 minutes and then rebooted?
thank you for your kind reply.
the PSu is seasonic gx 750w and its working, and the update went exactly as you described, and like its in the msi msi page, the led flahsed, then reboted, still nothing, im really afraid its dead, nevertheless, i still have a grain of hope i can use it, otherwise i will try to seel for part and get few €.
Pro
That's possible. What was the description of the board by the seller? Did he mention what was wrong with it?
Pro
Then sell it again for 20€ with the same description. Although we might get the new buyer also posting here for help 😄
If the BIOS is not the problem, and all your other components are known good, there is not too much you can repair on the board as an amateur. First you would have to find the faulty component on the board, then you would have to solder in a new one, it's all too much hassle. Thankfully, with AMD launching their new 7000-series CPUs and new boards, maybe you can soon get AM4 boards for a better price. Or look at B550 boards.
citay, would you be so kind to advice me for some board either b450 or 550 not much expensive so i can look in second hand, i've seen b450 tomahawk but people in my country ask for 100€ wich is too much, thank you in adavande for your trouble
Pro
B450 Tomahawk for 100€ used? But it cost less brand new... also, there were the B450 Tomahawk Max and B450 Tomahawk Max II later. Normally it should cost no more than 50€.
See if you can get a new (!) B450 Gaming Plus Max, B450-A Pro Max or maybe even B450 Tomahawk Max II somewhere for around 80€.
For example the B450 Gaming Plus Max is 79€ here, new. If your budget is that low, a good B550 board is probably out of the question, let alone an X570.
