Herald BE9400 Bluetooth not connecting
metalracket
I've just installed WiFi 7 PCIe Card, Herald 9400, into a my PC. after installing drivers WiFi and Bluetooth are showing up as working. WiFi is fine and working well. Bluetooth is showing as working but no devices are being found and the Bluetooth is not being fond from other devices.
Please help!
I have a ASRock Z690 PG Riptide motherboard with an i7-12700KF CPU
Signal may be blocked or weak. Check that the Aerial Connections are fully seated and the centre pin has not been bent
Same problem. I'm on Windows 11 25H2, and the issue is not signal, the OS does not recognize the bluetooth adapter at all. WiFi is unaffected.
I had this happen once before, and it just came back with time for some reason. However, it's happened again. Hopefully it fixes itself again, but I'd like a solution that prevents this issue completely.
Update: I may have fixed this! I took the PCI card out, cleaned the pins with alcohol, reseated the USB header cable into the card, made sure that was still well attached to the motherboard, then put the card back in. Then, I uninstalled the drivers through the device manager. If you can't see the device, you can change to drivers instead under view. I then had to restart to be able to install the drivers, and everything works! I'll update again if my problem comes back.
