High CPU temps, BSODs and “Aw, Snap!” errors - temps still hitting 100°C
Over the last few days I’ve been having huge problems with my PC. I was constantly getting “Aw, Snap!” errors in Google Chrome and Opera, even with only 3-4 tabs open. On top of that, I was getting frequent blue screens - literally during almost every game in League of Legends. Sometimes it would even crash during champion select. Occasionally the game window would crash and then come back, which was very strange.
I’ve had this computer for 2 years and I spent a lot of money on it, so I’m honestly very frustrated that something like this is happening. I really don’t understand what’s going on.
Yesterday I updated the BIOS and so far it seems more stable - the crashes have stopped for now. However, I’m very concerned about my CPU temperatures.
I tried lowering the power limits and tweaking settings in BIOS:
  • PL1: 175W
  • PL2: 200W
  • Lite Load: 11 (I can’t go lower, it causes blue screens)
Despite this, my CPU still easily reaches 100°C under load.
I also tried a negative voltage offset (-0.05V / -0.08V), but it didn’t make any noticeable difference in temperatures according to the graphs.
I’m attaching my Cinebench multi-core test results.
Is there any other way to reduce the temperatures? So far, none of my changes have brought any real improvement. I would really appreciate any help.
I7 14700K
MSI MPG Z790 Carbon WiFi
MSI MAG CoreLiquid 360R V2
RTX 4070 Ti (Palit)
RAM LEXAR Ares 16GB X2 6400MHz
KINGSTON KC3000 1TB SSD
Hi
So you may be looking at 2 potential issues here:
1. with CPU temperatures. Is the cooler's pump still working? Can you hear it running? Because that sounds like a dead cooler to me.
2. with memory or the SSD themselves. Fix the CPU temps first, and work your way through. Run a full test with Memtest86+ to see if it picks anything on the memory.
We may be looking at an even bigger issue than that. Considering the CPU model - a 14700K - and the backstory of the system, that it may have been running on a 2+ year-old BIOS for all this time until the recent BIOS update, we may be dealing with a degraded CPU here.
What may have escaped the OP's attention: If you have a true 13th/14th gen CPU, then buggy microcode in older BIOS versions caused voltage spikes, which could damage parts of the CPU on a molecular level. So on an old BIOS, the CPU can slowly get grilled from spikes of excessive voltage, which eventually cause CPU degradation to the point of instability. It's possible that your CPU was damaged by the voltage spikes by now. You can also read here, where there was a similar case.
Once there is degradation, the CPU becomes unstable at voltages it was originally stable at, and this is irreversible. Updating the BIOS to one with the latest microcode fixes only prevents it from progressing further. With affected CPUs, game crashes are not unusual, especially in Unreal-Engine-based games with crashes that are seemingly GPU-related, see https://www.radgametools.com/oodleintel.htm
So, if we assume for a moment that your CPU suffered degradation, then there's usually a conflict: To achieve stability again, it would require lower frequencies and/or higher voltages (the two main ways of regaining stability). But: A 14700K is already overpowering a lot of people's cooling as it is, and raising the voltages just makes everything much worse. So in the end, if the degradation is severe enough to cause crashes, it would be better to outright RMA the CPU.
Let's not get ahead of ourselves of course. But this is a bad sign:
Because yes, normally, to tame the 14700K, you could go by my Guide: How to set good power limits in the BIOS and reduce the CPU power draw. But lowering CPU Lite Load as per step 2), you can't really apply now, because it's about trying to lower the power draw (by lowering the voltages). This gives amazing results with CPUs that are still fully ok. But for CPUs which have suffered degradation, this won't work at all, since they actually need higher voltages to be stable again. Which would drive up the power consumption and basically make everything worse.
Then, you may have an overlapping issue with your cooling, as Nichrome noted. Severe thermal throttling at 200W power limit, and idle temperatures are also quite high (although it's not clear how long it had been in idle for the screenshot). For a 360mm AIO, this is underperforming, it should be good for up to 250W of heat. We know that the original MSI CoreLiquid R-series had huge issues, and even the V2 is a bit in doubt. So I'm not a fan of this AIO in general. I mean, the idle temperatures don't look completely terrible, and the system temperatures look a bit elevated at 37-41°C, which might explain the somewhat poor showing of the AIO too.
Can you show a photo of your system, to see the cooling setup?
But what we also need to know, these two years, what BIOS did it run on, the one it came with, or maybe the one you updated to those two years ago? Were you aware of the issue with the voltage spikes, affecting 13th/14th gen CPUs? Around July/August '24 was the time when the first BIOS versions came out that had initial fixes for the damaging voltage spikes, by implementing updated so-called microcode from Intel, which contained bugfixes that were loaded into the CPU to replace the buggy original code.
You can only really lower the power draw of a CPU which is healthy, because then you can use its undervolting potential. Doesn't matter which method you use, the one from my guide, or direct VCore reduction, this can only ever work properly if the CPU is in good health. But if your CPU was subjected to those damaging voltage spikes for all this time, you can't undervolt it anymore, in fact, the demands in terms of voltage will now have gone up.
You could then underclock it for a test, to see if it becomes stable again, similar to this example of a degraded CPU:
Hi, thank you for your interest in my case. Yes, I’ve read a lot about CPU degradation. I was using the latest version for about a year, and later I became more interested in the topic and kept updating, so I think I reacted in time. This computer had high temperatures from the beginning - my friends and I were surprised that it was reaching 90-100°C, but I assumed it was normal because some people say it’s safe and that you can use it like that.
Is there any way to check whether the processor is damaged? If it is, can I return it to Intel under warranty?View attachment IMG_4145 (1).jpegView attachment IMG_4143 (1).jpeg
As mentioned, the BIOS versions that came out around July/August '24 were the first ones with any real attempts against voltage spikes in the Intel microcode (albeit incomplete ones, as has been discovered later). So that's the BIOS 7D89v1D1(Beta version) or 7D89v1D for your board, with µcode 0x129. Anything prior to that would've still hit the CPU with the full extent of the voltage spikes.
So not only is the version you ran for about a year important, but also, we must not forget, all the action from Intel and the board makers only came as a result of people's CPUs becoming unstable for no apparent reason. Since early 2024, people were reporting about this. By mid-2024, they had no idea about the cause and tried various things. Only in Q3 of 2024, they were beginning to address the root cause, with the Intel microcode revisions against voltage spikes. So even for people who applied the appropriate BIOS versions right away, their 13th/14th gen CPU might not have gotten away completely unharmed.
However, the one thing that is in your favor, your problems only started to appear a few days ago. It might've been unwise to not keep updating the BIOS, since you were well aware of the degradation issues, because the fixes kept encompassing more causes of voltage spikes. But as for saying that this must be CPU degradation, taking your latest reply into account, is not so cut and dry anymore.
It's normal and not normal at the same time. Normal in a way that Intel pushed these CPUs way too far from factory, as I allude to in my guide, and the board makers - for a long time - letting the CPUs off the leash way too much, with inadequate presets for the power limits. So if you just installed your new system, you maybe update the BIOS, and then select "Water cooler" in the cooler selection prompt (which is really the power limits prompt), then the MSI BIOS would completely max out the power limits, letting the CPU completely off the leash.
What does this mean for the 14700K? A native power draw well over 300W under full load, if left to its own devices. Of course, not even most high-end AIOs could deal with heat like that, so with most of the available coolers, the CPU would firmly be in thermal throttling range, hovering around 100°C and downclocking itself, because the cooling can't get rid of the heat fast enough. This is what most people see if they don't adjust things properly to their situation, and this is part of the reason I wrote my guide in the first place.
Because what is not normal: When running it like this, you are relying on an emergency mechanism. The lack of cooling (at least for using maxed out power limits), combined with a CPU model that has been pushed to the extreme (for lack of other ways of gaining enough performance), leads to a CPU that's constantly trying to save itself from dying, once you apply a high enough load. Bouncing off the thermal limit is not a good way to have the CPU act with full load.
Now, you have two ways of counteracting that: Lowering and/or limiting the power draw of the CPU, and improving the cooling.
You already tried to undervolt, and with any CPU Lite Load mode below 11 causing instability, you know that your CPU doesn't have much undervolting potential. This could be because of a slight CPU degradation already, but this also could be normal. After all, MSI chose the default values for CPU Lite Load in order to make all CPU samples of varying quality be stable. Some CPUs of the same model need a bit more voltage, some a bit less. But what this already tells you, no matter which undervolting method you try, you won't get far. In fact, if Mode 10 is already unstable, and Mode 11 is the first one that's stable, then I would use Mode 12, to have some stability headroom. And that's basically where the undervolting adventure ends with this CPU, there is no need to try VCore negative offset or anything else, it will all be limited in the same way.
That leaves us with the cooling. And there, for a 360mm AIO, this is not performing up to par. You have set 200W Short and 175W Long duration power limits, yet the AIO is struggling this much, when it should easily be able to deal with 200W continuously? Something can't be quite right. Either the fan curves need to optimized further, or something is the matter with the AIO itself.
Your photos of the system, it seems like a reasonable setup, two intake fans in the front, one exhaust in the rear, and the AIO top-mounted as exhaust, this is standard setup that should deliver good cooling performance. So you need to take a look at the fan curves, doesn't matter if you set them in the BIOS or in a software. At around 80-90°C, the fans on the radiator should start to go to full speed. For the case fans it depends, also on the fan models and whatnot, sometimes they can be a little less than full speed.
What you can also check, the CPU temperature in the BIOS, just letting it sit for five minutes. With such an AIO, it should be in the 30s, if not even high- to mid-20°C (depending on room temperature of course, assuming around 20-22°C). If you see well over 40°C there, that would already somewhat point to an issue with the AIO. Perhaps double-check how it's mounted, clean the surfaces with isopropanol and use fresh thermal paste, stuff like that. Because the AIO should do better than this. It could be something out of your control, but you first need to check the variables you can control, like the fan curves and the mounting.
To me it look like some cooling issue. Even min temp is over 40'C, my 14700K cooled with air (Thermalright Phantom Spirit) idle around 30'C package with cores bellow 30'C, even when I stop R23 where it reach around 92-93'C with PL1=PL2=253W as soon as I stop R23 it instantly drop on 35'C area and than settle in around 30'C while idling.
Your MOS also reached quite high, 64'C, during R23 mine never go above 55'C as I also pay attention on it as I use that sensor for system fan control to try to get good cooling for RAM (Fractal Design Torrent). Those are on MSI Z790 Tomahawk WiFi, I guess your Carbon should have better components as it is higher tiered MB.
BTW, memory readings look like you didn't enable XMP in BIOS. 5600 with those timings look like JDEC frequency, check if XMP is enabled.
There could be degradation issue (let's hope it is not) but I would first check cooling as those temps are quite off. Maybe to reseat and repaste your CPU cooler first and see.
Here is my 14700K idling with only activity writing this post and snapshooting HWinfo. And my PC case is some 20cm from heating radiator in my room and heating is on :)
CPU is undervolted but not overclocked.
And here is at before R23 (min), during R23 (max) and after R23 finished (current):
More than likely.
And keeping a CPU in very high temps for so long is a very bad thing.
Your CPU might be damaged because of that (and not because Intel wanted to win the overclocking contest with AMD :biggrin:)
