- Mar 9, 2004
Where can I buy the nylon bolts,washers, nuts i been seeing people talk about using? I already ordered 2 tubes of the thermal paste... I sent back 1 Eclipse board back to Tiger for a bad PCIe slot. That board was also getting up to 187F on the IOH. The replacement board (im using it now while running a stress test) has gotten up to 168F I just feel that it too hot.
I would like to try the home mod on the copper heat pipe and sinks the others are talking about in these threads but need to find the right sizes and places to buy the nylon bolts,washers, nuts that will fit this board etc.
Also, I have the i7 xtream CPU... how hot do you think this thing should run at stock? When pushing it i have hit 141F THAT seems too hot also. I would like to over clock this some down the road.... but not until I get new compound on the cpu and the bridge cooler.
I also noticed this board makes my GPU way hotter (Side of case is wide open for all this). I put my GTX285 in my ASUS SLI Delux mobo while waiting on replacement. With the Fan set at 40% at idol the card was at 42c. With GPU in the MSI board and the fan on the card set to 100% at idol, the GPU is 51c. When i put the fan back on auto settings (puts it to 40% speed) GPU temp jumps to 61c.
HEAT seems to be an all around issue with this board!!!
