How can i connect my coreliquid 240 v2 to mortar b660m wifi? Fans work, but rgb doesnt
have you connected the ARGB connector to one of the 2 JRainbow connectors (one top Right and one bottom left) on your board?
the fans and the Pump had a Daisy Chain Connector System for ARGB (connect one of the Fans RGB connectors to the other) then connect one of the others to the Blocks Daisy Chain and then connect any one of the Available ones into a JRainbow connector as they will all then be controlled off a single Header it all depends which way you connect them just pick which one will have the shortest Route and then work from there. its probably best to use the Pumps one to connect to the JRAINBOW connector connect the Fans together and run one of the fans ARGB lines along one of the Coolant pipes as that will keep it nice and Neat.
its probably best to use the Pumps one to connect to the JRAINBOW connector connect the Fans together and run one of the fans ARGB lines along one of the Coolant pipes as that will keep it nice and Neat and connect that to the Pumps Daisy Chain.
