mgb.korad160002f6
- Jan 13, 2025
Got a x670e gaming wifi and im using an arctic freezer III 360, contemplating of replacing the fans with some more high powered version maybe phantekts t30.
Power consumption would increase drastically, the p12 supplied with the aio draws 0.1A while the T30 can pull up to 0.41A, if im reading this right the water pump tops out at 0.35A and the vrm fan 0.05A
If my math is mathing then total power consumption would top out at 20W, i am currently using the all in one connector so pump & fans connects to the cpu fan header.
Lets say i replace the arctic fans with more powerfull t30, still safe to use the all in one connector? or should i change cable so pump, vrm and fans are connected to separate fan headers?
Regards
Regards
