How many gpu's can I connect to this power supply and where?
landry92m
Can I use this power supply (A850GF) to connect with 2 or more gpu's that mostly require 2 x 8pins?
After the use of the first vga1 + vga 2 for my first gpu, can I use the second vga 1 + cpu for my second gpu? Then use my peripheral & sata to power my pci riser's?
GWraith
The bug hunter!
SO what you're asking is how to connect multiple GPUs to a power supply? Well just like you connect one but just more. Sounds like you are experimenting with GPU mining. I'd find a different forum to ask those questions. Also once you go past 2-3 GPUs you need to look into self-wiring things and splitters that can handle the amperage.
