How to lock GPU clock speed on MSI RX 570 4GB Armour OC
erminsb
Hello, im having trouble in CS:GO. GPU usage is not stable at all jumping from 0% to 100%, but clock speed does not exceed 700MHz, when OC is set to 1295MHz. in MSi Kombustor usage is stable 99-100% and clock speed is stable at 1295MHz. Temps are ok. So if you can please help to stabilaze gpu usage and core clock in CS:GO or help me figure out how to lock core clock at max so it doesn't think that it's at ''idle'', as it's not locking at MSI Afterburner.(Soryy for my English :D)
I've tried new windows, ddu, drivers, bios, ect.
erminsb
InGPU-Z log file i noticed that my power comsumption is low?
erminsb
it's latest, alredy did that. will do the test a bit later, thank you!
next3r
MAJOR
afterburner ,.,.ctrl + F -voltage curve
L - lock on curve "this profile save" load this profile before game
but your problem is adaptive power "this game no need full speed clock" ??
NVIDIA example
Alan J T
NVIDIA example
Yep I have some games that dont use more than 30% of than GPU if that much One Game I have hits all of 750Mhz max on the GPU, and my GPU hits 2,500Mhz without a problem in other games.
next3r
MAJOR
hi Alan J T
,..,voltage curve exist on AMD ??? or must find GPU power option in drivers "but this is most time BASE CLOCK lock" BOOST works only in some games /usage
when exist voltage curve --possible lock BOOST "but it is not needed" or FIX for video sequence in games
gpu power is adaptive in full range // according to the load
Alan J T
hi Alan J T
Yes you can lock the Clock in the AMD software,
You can set Minimum clock and maximum clock speed to within 100MHz of each other I can set mine to 2400MHz Minimum and 2500MHz Maximum ,
AMD GPU seem to like a slight undervolt. You can set GPU voltage easy enough. as well as Power Boost option.
