How to not Charge notebook battery when connected to Charger
badboy2k
محتاج البرنامج الا بيفصل البطاريه و الباور شغال
Please only post on here in English as this is the Global English Forum. >>Please read and comply with the Forum Rules.<<
Please feel Free to use a Online Translation Website to convert Your Language to English.
يرجى النشر هنا باللغة الإنجليزية فقط لأن هذا هو المنتدى العالمي للغة الإنجليزية. >> يرجى قراءة قواعد المنتدى والالتزام بها. <<
لا تتردد في استخدام موقع ويب للترجمة عبر الإنترنت لتحويل لغتك
Also What Device are you using here Make and Model?
magdyasd415d702e6
I need the program not to disconnect the battery and the power is on
badboy2k
This is my computer
GF63 Thin 11SC
you need to use MSI Center to change how the Battery Charges by installing the Systems Diagnosis App and use that as it will allow several Options
AI Charge: Lets it Vary how much it charges
Best For Mobility: 90-100% charge (Kicks in Charging once it drops below 90%)
Balanced: 70-80% charge (Kicks in Charging once it drops below 70%)
Best for Battery: 50-60% charge (Kicks in Charging once it drops below 50%)
magdyasd415d702e6
رمز تم التحقق منها بواسطة المنتدى
The program was downloaded and it did not solve my problem .
How to not Charge notebook battery when connected to Charger .
I need the whole way .
badboy2k
This program is available and the battery was selected from 50 to 60 Is this true
50 to 60% is what is called Storage Charge and is what is used for long term Battery Storage where its at a Middle level of Voltage and will not Start to recharge upto 60% till it drops to 49% and then it will charge it up by 10% in a very short time (about 5-10 mins) and stop again till it drops below 50% again.
I have all 3 of my MSI laptops on 50 to 60% as I never use them without the Charger Plugged in so just let that feed it power.
just depends how you use your Laptop to which of the Actual levels it has to what will work for you but if its always plugged in the 50 to 60% one is the best as you want that battery in a state where its under nearly no Strain.
magdyasd415d702e6
thank you brotherly
