Under "Advanced CPU Configuration" in the BIOS, i usually set the following:
"Intel C-State" to Enabled (Auto should equal Enabled, but anyway)
"C1E Support" to Enabled (clocks down in idle)
"Package C-State Limit" to C10 (this way, the CPU will enter C7 state in idle, instead of only C6. The C7 state lowers power consumption in idle by around 6W for me.)
"Intel Speed Shift Technology" to Enabled
If "Package C-State Limit" on C10 causes problems (quite rare, but it's theoretically possible with some configurations), then just leave it on Auto instead.
Now, you will know this, but others that may be reading: "CPU Lite Load" is a setting that is indivual for each CPU (not just the CPU model, but the individual CPU), and the best setting for that can be found out using my
guide. Lowering this from the default mode can yield great improvements for power draw under load and efficiency.
Then under Settings\Advanced\Power, set ErP Ready to Enabled. Reduces power consumption in off state to less than 1W instead of 2-3W.
Under Settings\Boot, set both Fast Boot options to Disabled (Fast Boot is not good for much and is sometimes problematic).
Then go here:
You can experiment with PCIe Native Power Management and Native ASPM set to Enabled or Disabled for a test.
Also set these settings in the bottom menu like so:
Should there be any problems with the graphics card from this, set PEG0/1 ASPM back to Auto, or set "Native ASPM" to the opposite value.
It's also worth trying to bring down the so-called IMC-related voltages under the OC section (the voltages that power the Integrated Memory Controller), because once XMP is enabled for the RAM - depending on how aggressive of a profile that XMP is - the BIOS will raise some voltages way more than required. For DDR5, the voltages are CPU SA Voltage, VDDQ, and VDD2. As an example, for DDR5-6000 @ 1.25V, i recently could decrease the Auto voltages of SA Voltage 1.25V / VDDQ 1.3V / VDD2 1.3V down to VCCSA 1.0V / VDDQ 1.2V / VDD2 1.2V without a problem.
In Windows, make sure the power plan is set to "Balanced" (the only proper one).
Then set PCIe Link State Management to Maximum Power Savings in the Balanced power plan:
I get an idle power draw of only 22.5W (whole PC) with my Z690 DDR4 board that way, combining all the measures and using an efficient PSU.
As can be seen here on the table,
This is a very low idle number for a modern system, and that is with eight SSDs in the system too (3x M.2 PCIe, 5x SATA).
Some of the improvements from these settings, you can only see if you hook up an energy monitoring device in front of your PSU on the wall outlet. This will show what really happens. It's more difficult to tell this just from the sensors you see with HWinfo and such.
