GUIDE How to set good power limits in the BIOS and reduce the CPU power draw
Write your Guide.
Pro
By now, and not only since threads like these, many Intel users will have heard (or have found out) that a lot of Intel CPUs have a very high power draw that can really push the CPU cooling capabilities to the limit and beyond. There used to be a time where a cheap tower air cooler would be enough for any CPU available for that socket. That era pretty much ended with the i9-9900K, the first "monster", and then from 10th gen onward, Intel really started pushing the higher-up CPU models to the absolute edge. Causing higher and higher power draw, which has now gotten ridiculously high with the 14th generation like the 14900K.
Note that Intel also recommend certain power limits for different CPU models, but those are more or less arbitrary, they have nothing to do with your individual cooling capabilities. One thing i would say, there is no benefit in allowing more than ~250W for any CPU, not even a 14900KS. Because it will always make the CPU run more inefficiently from that point onward (at the very latest, for other CPU models even earlier). That's then "junk power draw" or "junk performance", meaning the power draw still keeps increasing a lot, but only for minimal performance gains, it basically just ruins the efficiency. So even with a high-end 360mm AIO, you will not tend to see me recommending limits higher than 253W.
Check the performance too:
Yes, because it is needlessly fighting the outcome of undervolting. By lowering the voltage, you are trying to do the best thing you can do to the way a CPU operates (as long as it stays stable), and IA CEP is working against it because it detects a deviation from a narrow "normal" range it tries to uphold. But we are know that lowering the voltage is not dangerous (quite the opposite), so we should not let IA CEP interfere in this instance. Furthermore, using an updated BIOS with the fixed Intel microcode will prevent the voltage spikes that can cause CPU degradation, so that's already the main line of defence. The recommendation to keep IA CEP enabled comes from a time way before BIOS updates with this new microcode were available, plus it was meant for default BIOS settings, not for hand-optimized settings. Here is more circumstantial evidence that disabling IA CEP should not cause the current to go crazy. So when you see the performance going down the drain when lowering "CPU Lite Load" below Mode 10 or so, simply set IA CEP Support to [Disabled], nothing bad will happen.
What to do when the option "IA CEP" is not available, for example on B660?
Let's recap: If IA CEP is available and there's a severe performance drop (e.g. Cinebench score cut in half) when lowering the CPU Lite Load mode below a certain point, then IA CEP has to be disabled, simple as that. But on some boards, like most B-series chipset boards (B660, B760), IA CEP is not available as an option. What then?
There's two possibilities:
1) Performance stays the same when you lower CPU Lite Load (which is what you want, but usually only happens on Z-series boards where IA CEP is not available as a setting), or:
2) Performance drops off a cliff once you lower CPU Lite Load significantly enough (which is bad, and would be the case on most B-series chipset boards).
In other words, on a B-series board, where the setting is not available or ineffective, that severely limits the undervolting capabilities. So in that case, if the option is not available and you notice a performance drop below a certain mode, you either have to use the lowest CPU Lite Load mode that still keeps the full performance (often around Mode 9 or 10), or you have to use a more sophisticated undervolting method that tries to "dance around" IA CEP becoming active, using a combination of different settings. But that is quite complicated, and sadly, the bottom line is, with a B-series chipset board it's very difficult to achieve a similar undervolting result as with a Z-series board. No matter the undervolting method, at some point, IA CEP will "bite".
Note that this method is "officially recommended" by MSI now, see
this blog entry!
For the Z890 boards with Core Ultra, due to the many architectural changes in Core Ultra, i cannot promise the same results, especially since the power draw reading in HWinfo (CPU Package Power) can be inaccurate due to the way Core Ultra is designed. It can be "calculated wrongly" depending on some other settings. So for now, i can only guarantee proper results up to 14th gen. I've used this CPU Lite Load setting all the way back from my old 9600K, across generations in between, and up to my current 13th gen, it's always the same procedure to optimize it.
My other guides:
Guide: How to find a good PSU
The following is for geeks only, others can stop reading :)
In CPU Lite Load Advanced, you can select values for AC and DC Loadline separately, without having some preset combination which can have the wrong DC Loadline value. So now you can set the DC Loadline so it results in the correct power draw numbers. Doing that involves using HWinfo Sensors, creating full CPU load, then looking at the CPU's VID requests (in the "current values" column), which is the voltage the CPU asks for from the board, and comparing it to the current VCore value (note that i don't mean current as in Amperes, i mean current as in, actual live values, not Min/Max/Avg). If those are near-identical, the correct DC Loadline value has been found. The correct DC Loadline value depends on the LLC mode, another setting which influences the voltage (and not to be confused with CPU Lite Load / CLL, completely different). A table of the AC/DC loadline values is here, but it's only a rough one, because each board model is built differently and would also need a bit different values, presumably.
However, this last step doesn't quite pan out in my ow testing on a PC I was building for someone. Because even if i set CPU Lite Load "Advanced" AC Loadline to 1 (the lowest possible value) and select a mild LLC setting like Mode 7 (where the VDroop is still relatively big), i can't get anywhere near the low voltages and low power draw under full load that i can reach with just a lowered CPU Lite Load mode and keeping LLC on Auto. I'm talking a coupled dozen Watts difference here under full load, measured at the wall. In other words, lowered CPU Lite Load with LLC on Auto results in the lowest possible VCore and power draw under full load (while staying stable) in my testing, which is arguable one of the most important scenarios for which to keep the power draw low (to avoid cooling problems and improve the CPU's efficiency).
I played with lots of settings, but no matter what I change PL1 / PL2 stayed greyed out, with no option to change.
What you refer to as "greyed out" is actually just the BIOS displaying the currently active values. They will change automatically once you managed to set them further on the right. To change them, make sure Num Lock is engaged on your keyboard, then just type in the number and then press Enter. I don't think you have to press Enter first. The value should change from [Auto] to what you typed. If NumLock is not on, you can't type the number on the numberpad! But the number key row above the alphabet should still work.
If it was really greyed out, then the [Auto] on the right would be grey. But those grey values in the middle, they just show what values are active at the moment.
Hi! I have a 14700k on an msi z790-p ddr4, cooled with a deepcool LE360 v2.
First here's what my stock performance looks like:
This was on the latest msi bios with xmp off, basically default values, lite load by default is set to normal which was mode 16. First I would like to know whether these voltage numbers are normal or not? I saw other 14700k owners running at 1.1-1.2v under full load, and I also saw some people achieving up to 2000 points in r24 multicore.
For the past week I've been testing different types of undervolts and I've only become more confused as time went on. With hyperthreading on I cannot go below mode 12 lite load without getting L0 cache errors, but since I mostly game I decided to test with hyper threading off given the minimal performance impact while gaming. With HT off my best test was using mode 6 lite load, but even that threw out a single L0 cache windows after a couple hours of use, I want to know whether I should just ignore these errors and just use the PC normally? Of course there were no benchmark crashes (I tested 7 zip benchmark and r24 and also shader compilation for monster hunter wilds). Currently I'm testing AC 25 DC 65 lite load, I'm not sure what it's equivalent to in normal modes but yeah.
Thanks!
The power limits seem ok, apparently you have set 250W, or maybe the 253W preset, with your 360mm AIO this is alright, and I would never allow more than that anyway. Your RAM, why is XMP disabled? DDR4-2666 is a bottleneck. For Cinebench it doesn't matter (CB only measures CPU performance), but for other workloads and gaming it can be more important.
Every CPU is unique, they have different IA core quality according to the silicon lottery, which manifests in requesting different voltages from the board, as well as their undervolting potential. So even with the same CPU model, you cannot really compare numbers directly, you just have to find the best operating point for your individual CPU, no matter if you won or lost in the silicon lottery.
Now, the score, yes, it does seem a bit low, more like a 13700K. Running HWinfo can cost some points, as well as other things going on in the background that take up CPU time. You could do a run where you close most other things, including HWinfo.
There are many different ways of undervolting. In this thread I show what is perhaps the simplest one, while still achieving good results, so I would recommend this one.
No, any errors hint to an instability, so the mode should be raised by another notch and then re-tested. Don't worry, one or two modes up will not make or break the end result, even at Mode 8 it would be much better than Mode 16 default.
Benchmarks are benchmarks, they don't necessarily test for errors specifically. To validate stability, it's better to use a stress-test like OCCT, which constantly verifies the calculations.
Don't randomly enter things. In this thread you can read up on the AC/DC loadline values, they are mostly for fine-tuning the sensor readings, so that they end up being correct. You can do this step after having found the lowest stable mode of CPU Lite Load "Normal", with one step on top as a stability headroom. Then you can check in HWinfo, it displays the resulting AC and DC loadline values under the CPU properties (not in Sensors, in the main window).
CPU Lite Load "Normal" will modify AC and DC loadlines to the same values. The AC loadline is what undervolts the CPU and causes the improvements in lower power consumption, heat, temperatures. The DC loadline being at the same value of the AC loadline doesn't do much, apart from causing readings that are slightly off here and there, so then you can fine-tune the DC loadline setting in CPU Lite Load "Advanced" to have the proper readings, I explain it in the thread. But this step doesn't change the effect of the undervolting.
AC loadline on 25 means 0.25 mΩ, this is likely a very aggressive undervolt, corresponding to Mode 3 or so. Revert back to CPU Lite Load "Normal", test Mode 7 for full stability, and if it's stable, I would recommend to set Mode 8 as the final mode. Then you can check in HWinfo what AC loadline Mode 8 corresponds to, then you can set that as the AC loadline in CPU Lite Load "Advanced", and fine-tune the DC loadline as explained in the thread. That is then only the icing on the cake, the main job is already done.
Thanks for the reply! xmp was disabled by default i just wanted to do a quick stock test to see if something is wrong or not (I guess there wasn't anything wrong just an unlucky chip).
I wanted to ask you about a few other things, in my motherboard I have 3 option for cooler tuning, intel default 253W/MSI performance 253W/MSI unlimited 4096W. For the past week I kept it at default which was "intel default", but after looking at your guide I swapped it to msi performance and noticed that my undervolts are a lot more stable somehow. Now I'm able to go down to mode 5 without any errors (so far at least)
This is with hyper threading off which is why the score is lower.
This was done on mode 5 as well but on the intel default settings option for cooler tuning. Of course this threw out a bunch of L0 cache errors right after stopping the test and idling. I can already see the voltage is slightly lower here and its using 10W less power, but of course not stable.
I looked it up online and found that the current limit on the msi performance settings is higher than intel default, even if they share a similar pl1/pl2 power limit of 253W.
Do you think I should keep it in MSI performance settings? and do further testing using it or just go back to intel default?
Thanks again
Actually the first image was mode 4 not mode 5 which makes it extra interesting
Which post are you referring to? The post seems to be gone now. You are shown as having posted two messages until now, and the first one I replied to, but there was no mention of Mode 5.
It says the post is waiting for approval by the moderators, I'm not sure why it requires approval. Anyways I've been doing testing using intel default settings in the cooling preset, which has the same power limit as MSI performance mode at 253W, the only difference was the current limit I think. Anyways after changing it to MSI performance settings I was able to go down to mode 4, which usually would give me decoding errors in 7 zip benchmark and a lot of L0 cache errors, but I also noticed the mode 4 in MSI performance settings performed about the same as mode 5 in intel default settings, and drew 10W of power more than mode 5 and the almost the same voltage temps were also nearly the same. After some testing I found that mode 7 in intel default settings was identical to mode mode 4 in MSI performance settings, I couldn't do nearly enough testing, but I was able to replicate the same results multiple times. I wish the mods would approve the post because it includes everything I wanted to talk about. Also sorry if my writing seems incomprehensible.
Thanks once again
Ok, while it's awaiting approval, I can already comment on your latest reply here. The differences that you observed in the modes are most likely tied to the different power and current limits. When you select the "MSI performance settings" preset, that will basically allow the CPU more room to breathe, as it will set both Short and Long duration power limits to 253W, and the Current limit to 400A (as opposed to perhaps 253W Short, 125W Long, and 200A in the "Intel default" preset). Whatever the exact numbers may be, the "Intel default" will be lower than the "MSI performance" preset. This then affects how high the CPU can clock (and clocking higher means using higher voltages), if it hits the limits sooner vs. later.
The performance will also vary. If the power/current limits are quite low, the CPU is quite restricted, and every little step that you undervolt will yield greater performance improvements, as it can suddenly clock higher within those restrictions, since it uses less voltage for the same clock speeds, so it can use higher clock speeds in the end. Whereas with the higher "MSI Performance" limits, it can already clock very high and it sits around 250W under full load constantly, so the steps in undervolting don't translate into the same performance improvement there. They can cause a nice lowering of the power draw in all sorts of load states, but at around 250W when all cores are fully loaded, the available performance gains are limited, wether you undervolt or you allow 300W (if your cooling would be able to cope). The bulk of the performance should already be there.
Ah, now your other post appeared, with the two screenshots.
I would keep using the "MSI Performance Settings" preset, with your cooler plus the undervolting it's ok. All the better if it's more stable. But as mentioned, test with proper stress-tests, not just benchmarks or waiting for a crash.
@citay
MSI MAG Z790 Thomahawk ddr5 wifi, I5 13600K bios E7D91IMS.HG0 CPUID 0671 Microcode 12C
Since it was running fine after applying your recommendations (CPU Lite Mode 6, IA CEP disable) I hesitate to update to BIOS E7D91IMS.HJ0 with Microcode 1.3someting. Are there any issues with updating, like fixed entries in the bios that can no longer be changed, or quite different outcome of Mode 6? I also changed CPU Over temp to 95, so it will throttle earlies to prevent damage.
Since 12C and the settings I monitor cpu temperature closely, it stays below 45 degrees most of the time, equal to the nvidia gpu temp ( humble 1650 oc).
Should I update the bios, none of the "issues" that this would solve do seem to apply to my usage.
Thanks for your time,
Regards, Peter
With a 13600K, you should update to the latest BIOS version, since your current vHG / .HG0 version doesn't have the latest fixed microcode revision 0x12F yet. Only 0x12F onward have all the fixes against voltage spikes. With any earlier revision, there are still certain load scenarios where voltage spikes can occur and slowly damage the CPU.
That's the beauty of using the CPU Lite Load method from this thread: You can enter the same Mode as before again, and the results will be identical again. Whereas, people who undervolt by directly changing VCore voltages, they can get different outcomes than before if they enter the same numbers again, because the default mode for CPU Lite Load might have changed in a new BIOS version. But with you changing CPU Lite Load, this will prevent any bad surprises. It should be exactly like before.
Instead of changing TJMax (Thermal Junction Maximum), the CPU overtemperature point, it's better to set the power limits in Watts to a safe level, resulting in ~90°C maximum (or lower) during Cinebench. With the power limits, you are using the proper way to prevent your cooler from being overpowered. If you rely on TJMax, you are relying on thermal throttling, an emergency mechanism. The power limits should already act before that.
Also, neither power limits nor TJMax can prevent damage from voltage spikes due to buggy microcode. Only the latest microcode in the later BIOS versions can prevent that.
Yes, update the BIOS, then enter your ideal settings again, both for the power limits (which you hopefully found, if not, do that) and for CPU Lite Load.
Instead of changing TJMax (Thermal Junction Maximum), the CPU overtemperature point, it's better to set the power limits in Watts to a save level, resulting in ~90°C maximum (or lower) during Cinebench. With the power limits, you are using the proper way to prevent your cooler from being overpowered. If you rely on TJMax, you are relying on thermal throttling, an emergency mechanism. The power limits should already act before that.
Thanks, updated and adapted settings. One setting stands out: previously the default for "CPU Under Voltage Protection" was disabled, now it is enabled. Does that matter?
Thanks!
Good.
It might matter, and you can safely disable it. UVP doesn't make sense for the CPU, there is no risk of damage from undervoltage, just risk of instability, and you can find that out yourself from doing stability tests. UVP makes sense in PSUs, because the PSU voltages leaving specification limits on the bottom range means that there is an abnormal situation going on, as something is drawing way too much current (like a short for example), so it's a good protection circuit to have, cutting the power before something blows. But for the CPU, I don't see a need for such a protection, you are deliberately undervolting to improve things.
Hello, thats a very nice guide for stable use of 13th and 14th gen Intel CPUs, but I had a question here.
I recently upgraded from an i5-12400 to an i5-13600K on my MSI PRO B660M-A DDR4 (BIOS 7D43v1N).
Hardware:
CPU: Intel Core i5-13600K
Motherboard: MSI PRO B660M-A DDR4
RAM: Corsair Vengeance LPX DDR4-3600 C18
Cooler: Phanteks Polar S5
Issue:
With the current BIOS (microcode 0x12F), I tested the following settings:
CPU Lite Load Mode 6
CPU Load Line Calibration = Mode 6
PL1 = 125W
PL2 = 181W
CPU VR Voltage Limit = 1.33V
Under load, both P-cores and E-cores drop in frequency. In my tests the P-cores only reach around 4.9GHz.I also tried other combinations (for example Lite Load Mode 9 + LLC Mode 3), but the P-cores then drop even lower to around 4.7GHz.I suspect IA CEP (Current Excursion Protection) is being triggered and throttling the cores.Previously, on an older BIOS with microcode 0x104 (no UVP), the same power limits (PL1 125W / PL2 181W) combined with a CPU offset of -0.14V kept the frequencies stable with no drops.I also read the discussion about Intel’s baseline settings and the risk of degradation on 13th/14th gen CPUs. It recommend setting IA AC Load Line to 0.5 on MSI boards, which corresponds to CPU Lite Load Mode 6:
My questions:
On this board with BIOS 7D43v1N (0x12F), is the frequency drop under Lite Load Mode 6 + LLC 6 + 1.33V limit expected because of IA CEP?
Which configuration is recommended for the best balance of stability + performance + longevity on the PRO B660M-A DDR4 with a 13600K?
Stay on 0x12F with Lite Load Mode 6 (or another specific mode)?
Or is it acceptable to use the older microcode (0x104) with a moderate undervolt if temperatures and voltages are carefully monitored?
Any advice on the proper Lite Load mode, LLC setting, and whether IA CEP can be managed or disabled on this B660 board would be greatly appreciated.
Thank you!
With a 13th gen -K on a B-series board, your hands are tied behind your back a little. You can only undervolt so much before the performance also drops, because you can't really turn off the unwanted protections like IA CEP.
One note right off the bat though: Don't focus too much on things like clock speeds of the cores. Just run a CPU-only benchmark like Cinebench R24 for example. What's important is not how cores clock, what's important is that you keep similar (or even improved) performance compared to not undervolting. Of course, you are still limited by CPU cooling via the power limits for example, but the idea is to have a baseline performance (you could also look up a ballpark figure from reviews of the CPU), and you want to remain within that range in your undervolting endeavours.
I see you are using power limits of 175W Short / 125W long. This big of a difference is not really ideal. This is what they tend to use in office PCs, where the cooling is just about able to deal with the higher figure for half a minute, but quickly gets heat-soaked and is then brought down to the lower figure. At home, you should have a more capable cooler, where for example a 20W delta is sufficient, so you don't affect long-run performance too much. Looking at your cooler, it's a single-tower 120mm one, already a bit underpowered for a 13600K, I doubt it can cool much above 140-160W. But you could experiment in bringing the two power limits closer together, like trying 155W Short / 135W Long or something, it might be better for long-run performance like the ten minute Cinebench run.
Then, as for LLC, which is of course influencing VCore as well, but in a completely different way than CPU Lite Load. You will see no recommendation of changing LLC in my guide, I mostly talk about lowering CPU Lite Load. Because when you also take LLC into the mix, the results are not that predictable anymore, this is something for people who know what they are doing, not for average Joe trying to improve things for their CPU with basic knowledge. Now, the CPU VR voltage limit, you can use that no problem, it's just a bit of additional protection.
As for the microcode: Absolutely stay on the latest µcode revision. Nothing will save your CPU in the long term if you go back to older µcode which might still cause voltage spikes. The voltage spikes don't really show up in the sensors, they are very short, pulsing away and damaging the CPU on a molecular level over time. What good is a potentially better undervolt on previous BIOS versions if your CPU slowly gets grilled from voltage spikes. But again, to determine how the CPU performs, don't stare at HWinfo clock speeds too much, just run the benchmark. If the benchmark numbers are good, and the power draw etc. is lower, then all is well.
About which mode to choose: Nobody can tell you this, each CPU is individual. The CPUs are tested to become a 13600K, but there is a relatively large variance, the "silicon lottery". Some CPUs barely make the cut to become a 13600K, and another CPU might pass the test with flying colours. Also see here. This also greatly influences their overclocking/undervolting potential (although nobody should think about overclocking such CPUs anymore, but it's basically the opposite side of the coin from undervolting).
So the mode has to be found out individually, primarily by doing stability testing to determine where the CPU becomes unstable, and then going back up with the mode again, until you have full stability with one step stability headroom, as explained in the thread. Additionally, when using a B-series board where IA CEP can "throw a spanner in the works", you also need to closely monitor CPU performance, via Cinebench for example. Because there, usually the mode can only be lowered to certain point like Mode 10 or 9 for example, until the performance starts to suffer. That is, without also meddling with LLC. I advise to only lower CPU Lite Load for the time being, leaving LLC on Auto.
Thank you for the detailed reply, this is very helpful.I tested further based on your advice:
Cooler is handling the load well — even at around 157W the temperatures stay under 90°C.
I changed the power limits to PL1 140W / PL2 175W.
Cinebench R23 multi score is 21,785, which is similar to my previous results.
I understand that on a B-series board IA CEP cannot be fully disabled, so I can accept some performance drops if necessary.I will now follow your recommendation and keep LLC on Auto, then test different Lite Load modes while checking the score/frequency.
I also have two quick questions:
Regarding IA AC Load Line — some guides (the Reddit discussion I linked earlier) suggest setting it to 0.5 on MSI boards for better stability/longevity. On this board, Lite Load Mode seems to control that value (for example, Lite Load Mode 5 shows IA AC Load Line as 0.5). Is aiming for ~0.5 still a good target when using the latest 0x12F microcode, or should I just focus on finding the lowest stable Lite Load mode without worrying too much about the exact 0.5 value?
About LLC — I read that on MSI boards, a higher LLC number causes the CPU voltage to drop more under heavy load (source: https://forum-en.msi.com/index.php?threads/cpu-loadline-calibration-control-lcc.390959/).
Thanks again for the guidance!
I made some comments here and here before about the guide you linked. It's not that it's a bad guide, it's that it's not very MSI-specific, and when also trying to optimize LLC, it can become too complicated for the average user. So this is not something I suggest in my guide, plus I can describe the easy MSI method of CPU Lite Load, which is only described in passing on the reddit guide.
There is no fixed AC Loadline value you should target, this doesn't work well, because as I mentioned, every CPU has to looked at individually. There can be no cookie-cutter-approach when it comes to undervolting, the individual CPUs of one model have too different requirements in regards to voltage per frequency. That's why I only describe the method to get to the best result, I don't give specific values for the best result, because that is impossible without sitting at the PC with that CPU and testing it.
You want to find the lowest stable mode (+1 mode up for headroom) where you still have proper performance, not worrying about hitting any specific mode or AC Loadline value. Your CPU, your board and your testing will determine the best end result.
I would suggest to do one run of Cinebench R23 with just the power limits in place, but all the voltage stuff on Auto, that can be a baseline score. As long as you stay close to that score, or even improve the score (as the cores can clock higher within the same power limits once you undervolt them), it's good. If the score drops, then some unwanted protection has kicked in.
I understand now that there is no fixed AC Loadline value to target.
However, I want to share my testing results so far:
When I leave everything on Auto (only setting the power limits), the CPU requests over 1.5V according to VID in HWiNFO. This causes:
- Very high temperatures
- Cinebench R23 multi-core score dropping below 20,000 [test1]
After several tests, I found that Lite Load Mode 5 is currently stable for me. With Mode 5:
- All P-cores can reach 4.9 GHz
- The Cinebench R23 score is better than when I used Mode 9
When I previously used Mode 9, the P-cores only stayed around 4.7 GHz [test2] and the Cinebench score(21000<) was lower than Mode 5.
So in my case, the lower Lite Load mode (Mode 5) with LLC 6 is actually giving better performance than the higher modes so far.
Would you recommend I continue testing from Mode 5, or should I stay around Mode 6 for safety?
Thanks again for your help.
You can continue, some CPUs can go down all the way to Mode 1. So I wouldn't stop at a value just because it's quite low already, that's like playing an FPS game and not going around a corner because you already hear that an end boss must be there. You can go around the corner, the end boss might kill you at some point, but you have a savegame to go back to, no problem. It's the same here: You can try lower and lower modes until it becomes unstable (use proper stress tests for stability testing of course, not just Cinebench), and then you simply raise the mode again, confirm the first stable mode, and add another mode on top for stability headroom.
And as mentioned, keeping an eye on the performance too. You don't even have to do the full 10-minute run each time to judge the performance. After the first pass of rendering it will already draw the orange result bar, there you can guesstimate if the result is ok or not.
