How to use serial ATA cables?
Grunberg
SECOND LIEUTENANT
With my MSI K8T Neo motherboard, I received these serial cables?
- 2 orange 1/2" cables
- 1 power cable, power plug on one end, 2 black 3/4" plugs on the other
But my hard drives do not have ports for these connectors.
What do I do? Am I supposed to buy a serial hard drive to take advantage of this 150MB/sec speed, or is it in the cables?
Any info is appreciated. Thanks!
You need S-ATA HDD's to take advantage of it.
But there is P-ATA to S-ATA converters out there, but I'm not sure on how that affect the performance.
I have seen these adapters that connect to IDE drives and allow you to use the SATA connectors. I know that HighPoint makes some called RocketHeads.
http://www.ewiz.com/detail.php?p=HI-HEAD_SE&c=pw
And on www.pricewatch.com , you can search for SATA to IDE and you find others like this:
http://www.pcmicrostore.com//PartDetail.aspx?q=p:10500819
http://galaxy3000.com/Itemdesc.asp?Cartid={75ACED06-6F8A-4344-BE60-831C8392FCD0}&ic=AC%2DIDE%2DTO%2DSATA&Tp=
These claim to give you the full speed of SATA, even though, I dont see how.
